Post 773963 by Blackdog on 2015-05-24 08:36:53
I'm looking to change the head unit in the 98 V70.
I have picked up a 901 unit but did not know it had to have an amp to make it work.
The question is is it an easy job to fit a Volvo amp (ie is the wiring already in place) or is it an electrical nightmare?
Post 774050 by Blackdog on 2015-05-25 06:53:18
Thanks for that. Fortunately I know where the rest of the parts are as I got the 901 from a breakers yard with us removing it from the car.
Post 774157 by AcidicDavey on 2015-05-25 21:14:46
Nice one, easy then :)
The wiring plugs into the harness, those connectors were wrapped in foam just behind the radio.
Was the car at the breakers a S/V70? C70's amp are different (in the boot) and the 2nd aerial you'll need is only in the V70s. The aerials on C70s and S70s are different to V70s.
Post 774177 by Blackdog on 2015-05-25 23:42:41
Reading this alas it was from a C70....
Now sounds like a mission to sort the wiring.
Post 774184 by Wobbly Dave on 2015-05-26 00:11:48
I have a spare amp from a C70 if it helps or easier still a sony headset with cd-multichanger, ipod connectivity and remote.
