T5-R Gearbox; issues and replacement questions
Post 773955 by j@mie on 2015-05-24 07:11:07
Hi guys, 4th gear on my car crunches; its terrible now. Looking into getting the standard M56 5 speed manual box out and reconditioned. Been looking also at the possibilities of swapping it for the M59 5 speed manual box found in the R. Can this be done and a straight swap? If so, might be on the lookout. Friend of mine was even mentioning about putting a Quaife differential in the M56 box instead. What do you guys think?
Post 773957 by p fandango on 2015-05-24 07:38:45
the Quaife will give better results, but the M59 can be swopped if you have the longer driveshaft as well
Post 773959 by Shinsplintz 101 on 2015-05-24 07:54:46
Don't bother with the m59, any you find now will be past their best & were a bit fragile to start with. As above, get a standard box & lsd. Much more reliable & will stand up to increased power if your cars modified (to a point!). Lsd - either gripper or quiaffe. Good luck, Morgan
