Fluctuating PSI levels S70R Rica 310
Post 773715 by MaxTS on 2015-05-21 08:27:54
Hello, I've noticed since replacing the leaky intercooler on my R that the boost levels fluctuate between 12-16psi. It's quite strange as at first it peaked at 14 then instantly dropped to 12psi. It now seems to hold higher boost but sometimes fluctuates up and down but there is no noticeable reduction in power. But it held 16psi all through 3rd once and it pulled very very strong! I have a MBC in the boot so I may stich that on to see if it can hold constant PSI which may point to a faulty BCV. Any other ideas before I do this? Never really been a fan on those things. Thanks EDIT- I should add that it has a Forge wastegate fitted!
Post 773776 by MaxTS on 2015-05-22 09:33:23
Any thoughts?
Post 773780 by jamesy12345 on 2015-05-22 11:16:15
Dodgy gauge or boost leak starting to open up? If it was my car I would thrash it mercilessly until something broke more obviously, then fix it :)
Post 773781 by Yosser on 2015-05-22 12:22:13
Might be that the actuator is too tight. Keep adjusting the wastegate actuator down in small increments to see if you find a sweet spot where it's just right.
Post 773784 by merc85 on 2015-05-22 13:32:58
Think you will find the issue is with the Maf
Post 773786 by MaxTS on 2015-05-22 14:00:50
If the actuator is to tight surely it would over boost? 16psi seems about right for a mapped R. I can't see any codes when it's scanned but it might be worth a go.
