Post 765937 by S40kieran on 2015-03-29 13:57:09
Now there seems to be split opinion on doing this, does anyone know the pros and cons I can't personally see the point in it being there.i know a lot of the land rover boys blank them any advice appreciated :)
Post 765942 by stribo on 2015-03-29 14:07:27
I'd definitely bin the EGR, as I said in the other thread, why would you want to send sooty inert gas through the engine?
Post 765954 by c70geoff on 2015-03-29 14:43:47
I have no real opinion on this but will tell u that I have picked up more vehicles with egr issues where they have been blanked off
Post 765960 by Orca2 on 2015-03-29 14:54:40
It seems like a mad idea making an engine, ingest its own exhaust, they say it makes them burn cooler on a run , why bother with an intercooler when the engine is going to be fed dirty hot exhaust half of the time.
Its one of those baloney ideas that they dreamed up to cut cruising emissions thatdoesnt really work anywhere but in a laboratory test rig.
Imho clean cold air is all any engine should be getting.
Post 765963 by Doingitsideways on 2015-03-29 14:58:21
Yeah, bin it.
Load of crap.
Post 765966 by Harvey on 2015-03-29 15:03:59
My work VW transporter has had lots of dash lights around EGR faults,it's going in for cracked exhaust manifold housing to turbo,just drive around with the windows open.:worried:
It's not 2 years old yet.
Post 767246 by S40kieran on 2015-04-02 19:23:34
Egr blanking plate on its way egr binned :)
Post 767252 by Matt86 on 2015-04-02 19:38:44
EGR blanking is generally the preferred option. FYI - Be careful about MOT time as it's meant to reduce NOX emissions and you might be caught out on your next MOT.
Post 767254 by S40kieran on 2015-04-02 19:43:49
Yes I did wonder about where i stood on that matt, also eml light etc, people have said they get theirs through with it blanked I know it's electric and is pretty pointless.
Post 767258 by jamesy12345 on 2015-04-02 19:57:58
[QUOTE=Matt86;767252]EGR blanking is generally the preferred option. FYI - Be careful about MOT time as it's meant to reduce NOX emissions and you might be caught out on your next MOT.[/QUOTE]
?? how? on the NOx measuring machine? it would need to be a sharp eyed tester to spot that
Post 767260 by T4PAT on 2015-04-02 20:02:02
Bin it Kieran its probably full of ££££ by now...lol
Post 767282 by T4PAT on 2015-04-02 20:33:20
[QUOTE=S40kieran;767280]What about eml pat ;)[/QUOTE]
pm sent lol
Post 767303 by Orca2 on 2015-04-02 21:06:00
If your egr has never been off Kieran it almost certainly is 90% blanked anyway, those things are absolutely choked with crap by 140 k.
Post 767310 by MVR on 2015-04-02 21:31:02
I did it on my old van,
First off I fully blanked it off but after a few miles of driving it around the ecu didn't like it and put it in limp mode. So with abit of research the answer was to drill a 6mm hole in it. I know it kind of defeats the objective of blanking it off but it stopped the ecu from having a fit and with a tiny hole it will of slowed down the recirculating of the gases
Post 767374 by S40kieran on 2015-04-02 23:04:26
Mvr I've uploaded my two bikes in that cycling thread, anyway yes I've heard of people ripping the guts out of them so you are left with the shell :) and no eml light it's got to go lmao one way or the other :)
Post 767389 by Orca2 on 2015-04-02 23:43:36
Isnt that DPF's that people gut out? Your EGR system has next to nothing in it , just a valve and a pipe full of soot
Post 767442 by Timo. on 2015-04-03 13:20:06
I've just slipped in a blanking plate in my V50. I took the throttle body to clean it as it was sticking. It was a mess. I looked up into the inlet manifold and it was caked up to hell. Took it off and treated it to some oven cleaner. The amount of stuff that came out was crazy. I reckon it was probably restricting airflow by a good 15 to 20%. No more egr gases for me. Mine is an early euro 3 so no error messages. Hoping it helps fuel economy as 41-43 mpg is not floating my boat at the moment and that's me driving like a Granny.
