Mbc
Post 762504 by MRTREE on 2015-03-06 15:59:44
quick question guys ang girls, i just had a look under the bonnet and have realised the screw from my MBC is missing so can i just get a new screw or will i have to replace the MBC all together? also whats the potential problems this can cause?
Post 762506 by MaxTS on 2015-03-06 16:03:21
Do you mean the adjuster that tensions the ball and spring? If so then remove that straight away and feed the gate directly as it is more that likely not feeding the actuator at all like that!
Post 762509 by MRTREE on 2015-03-06 16:12:49
[QUOTE=MaxTS;762506]Do you mean the adjuster that tensions the ball and spring? If so then remove that straight away and feed the gate directly as it is more that likely not feeding the actuator at all like that![/QUOTE] yeah the ajuster screw, it still boosts but i guess it isnt safe and the last thing i want to do is mess anything up
Post 762514 by MaxTS on 2015-03-06 16:16:06
It will be leaking boost and not feeding the actuator so your poor turbo is working over time right now due to the gate not opening. I would avoid boosting it till it's sorted. You'd be better off feeding the actuator straight from the boost pipe for now, you will get wastegate creep but it's much better for your turbo :)
Post 762516 by MRTREE on 2015-03-06 16:22:08
[QUOTE=MaxTS;762514]It will be leaking boost and not feeding the actuator so your poor turbo is working over time right now due to the gate not opening. I would avoid boosting it till it's sorted. You'd be better off feeding the actuator straight from the boost pipe for now, you will get wastegate creep but it's much better for your turbo :)[/QUOTE] Fair enough ill get that sorted then thanks for the advice
Post 762545 by martin_r_smith on 2015-03-06 17:56:45
You could just put the pipes back on the bcs, same as standard. Not sure how it managed to unscrew itself out though, vibration I guess.
Post 762634 by MRTREE on 2015-03-06 22:23:16
[QUOTE=martin_r_smith;762545]You could just put the pipes back on the bcs, same as standard. Not sure how it managed to unscrew itself out though, vibration I guess.[/QUOTE] Yeah I didn't change it from the setting you had it on and I looked today and it was gone lol It will be getting some goodies soon
