Fixing the soggy front end
Post 760119 by classicswede on 2015-02-18 18:04:03
Got fed up with the soft front end on my S80, As a Gaz dealer I had some front dampers made up. As I did not know what spring rate and length I would want I altered things around so I could use 240 springs. Also fitted some uprated adjustable rod end ARB links while I was there Image Image Image Image Image Image Image Next job will be changing the rear springs and dampers to sort the rear end out It does drive a lot better and is a lot smoother on hard cornering
Post 761274 by LeeT5 on 2015-02-28 07:45:59
Why is there a jubilee clamp on the bottom of the lower spring? Looks like bodge job to me!
Post 761281 by silverhorse on 2015-02-28 08:31:32
Gaz made bespoke suspension for my old Mk2 Astra GTE 16V racing car. Good bits of kit and reasonably priced too.
Post 761282 by claymore on 2015-02-28 08:35:52
Jubilee clip is a common fitment to keep shorter springs seated when the car is jacked up.
Post 761289 by Harvey on 2015-02-28 09:13:25
So where's the finished photo ? Ride height.
