Red block guru's Help
Post 758738 by Plodmonkey on 2015-02-05 21:15:16
Hi my mate has a 940 2.3 lpt 1996 he put a manual boost controller turned it up to 15psi. The car hits 15psi the goes back down to 4psi anyone no the problem. Cheers
Post 758758 by dant5r on 2015-02-06 13:51:12
You'd be better off asking that question on voc.
Post 758764 by pwalker on 2015-02-06 14:55:11
its not fuel cut is it? or is it chipped? the fuel cut is only like 0.9bar isnt it?
Post 758765 by 960kg on 2015-02-06 15:13:57
It probably IS fuel cut as it should happen at 1bar 14 to 15psi... My 940 2litre turbo was set on 13psi and went great but just a bit more and fuel cut.
Post 758808 by Plodmonkey on 2015-02-07 00:13:03
Cheers that was the reason sorted it today thanks
Post 758889 by barkster1971 on 2015-02-07 19:41:06
Keep it at 10. As it's been quite cold you'll just about hit it at 15.
