Post 756764 by pwalker on 2015-01-20 19:53:18
Quick one, do b230's usually have a tensioner on the alternator belt? Mines had the aircon removed and the belt is starting to squeak a bit just wondering if there is normally a tensioner and if it has been removed with aircon etc
Post 756778 by Dangerous Dave on 2015-01-20 21:19:08
The tensioner is built into the support bracket underneath the alternator. If you look at the end of the bracket you'll see a 10mm headed bolt which is the adjustment
You have to loosen the bracket bolts and then screw in the bolt at the end of the bracket to tighten the belt. This should be similar for the aircon pump too.
Post 756781 by pwalker on 2015-01-20 21:33:17
Ahh I should have had a proper look, cheers for that :)
