Stiff rear shocks for a 940?
Post 756002 by pwalker on 2015-01-14 17:54:42
What performance shockers are available for a 940? I want some pretty stiff. It's for a drift car which is used on the road but would rather it be a bit stiff for the road rather than too soft for the track if that makes sence
Post 756007 by classicswede on 2015-01-14 19:09:40
I do the adjustables but you are going to need some stiffer springs on the back for drifting
Post 756015 by pwalker on 2015-01-14 19:49:44
[QUOTE=classicswede;756007]I do the adjustables but you are going to need some stiffer springs on the back for drifting[/QUOTE] i got some springs off you already :), front is all coilover'd up and solid, and i have the back springs on i got from you a while ago, just the rear shockers i need now
Post 756068 by jks on 2015-01-14 21:57:40
GAZ do some! they got measurements/pattern, as they made some for me while back..
Post 756089 by pwalker on 2015-01-15 06:29:45
[QUOTE=jks;756068]GAZ do some! they got measurements/pattern, as they made some for me while back..[/QUOTE] cheers :)
Post 756137 by Nari on 2015-01-15 13:59:11
Koni has the yellows. I had them on the 850... not sure if they are good for drifting. As mentioned earlier, try GAZ, they do custom stuff. My buddy contacted them to get a set done for IRS rearend, but it ended up way to expensive..
Post 756208 by jks on 2015-01-15 22:05:47
[QUOTE=pwalker;756089]cheers :)[/QUOTE] Back coilovers are possible and quite easy to make for live axle 940, PM me..I'l explain
Post 756342 by pwalker on 2015-01-16 22:42:47
I think I'm just going to get them off classic swede tbh, they sound spot on and are adjustable :), cheers for the help though
