V70R Lost AWD
Post 746959 by Craigy t5 on 2014-11-07 16:34:47
Hi all. Was going down motorway slip road last night when an almighty bang came from the front end of car, it was such a bang i thought i had hit something, Almost certain it had jumped out of gear aswell - anyhow carried on and came off at next junction, when pulling away got wheelspin from the front so AWD is lost, almost certain it wont be just the sleeve,,, Will investigate when rain stops and report back,,,.
Post 746962 by Santa on 2014-11-07 16:44:03
Eeeerrrrrrr.......not good. Hopefully its just the sleeve though :)
Post 746965 by Ettienne on 2014-11-07 17:08:18
Sounds like angle gear has self destructed. Not a lot of people service them.
Post 746968 by stribo on 2014-11-07 17:12:54
[QUOTE=Ettienne;746965]Sounds like angle gear has self destructed. Not a lot of people service them.[/QUOTE] Yeah, the problem is they all seem to weep, but people never check them, and top them up when the car is serviced. Ours is done every year.
Post 746969 by Ettienne on 2014-11-07 17:15:05
Mine only lost 50mls from its last service (if it ever had one) but it's the later type, maybe they have better seals.
Post 746971 by Ettienne on 2014-11-07 17:17:50
Mines on the original angle gear and collar, which has been inspected, both were said to be ok, when engine was put back together. Fortunately I've serviced all 4 gearboxes now, not that, that makes them fool proof just a better chance of being more reliable.
Post 746972 by stribo on 2014-11-07 17:19:35
Ours has been resealed twice, but still weeps, just have to keep it topped up.
Post 746975 by Craigy t5 on 2014-11-07 17:39:23
[QUOTE=stribo;746968]Yeah, the problem is they all seem to weep, but people never check them, and top them up when the car is serviced. Ours is done every year.[/QUOTE] Had all the oils done last month, angle gear, diff, aol, and gearbox oil, had the car 2 years angle gear was bone dry back then,
Post 746976 by Tomcat on 2014-11-07 17:39:50
Oh crap, that doesnt sound good, what year is it?
Post 746977 by Craigy t5 on 2014-11-07 17:42:18
[QUOTE=Tomcat;746976]Oh crap, that doesnt sound good, what year is it?[/QUOTE] 03 manual box.
Post 746978 by Tomcat on 2014-11-07 17:44:55
Arse.. Sorry to hear it, I've got a spare colar and angle gear in the shed but it's off a 99 V70R which I think is a different system isn't it?
Post 746979 by Ettienne on 2014-11-07 17:50:23
[QUOTE=Craigy t5;746977]03 manual box.[/QUOTE] That explains it.
Post 746980 by Craigy t5 on 2014-11-07 17:51:09
[QUOTE=Tomcat;746978]Arse.. Sorry to hear it, I've got a spare colar and angle gear in the shed but it's off a 99 V70R which I think is a different system isn't it?[/QUOTE] Yeh think they different,.
Post 746981 by Craigy t5 on 2014-11-07 17:53:55
Think this R could end up broken for spares needs other work,,,, watch this space,
Post 746991 by Tomcat on 2014-11-07 18:23:36
Be tragic to break it for that, will the car not run without like the Ph1 cars?.. Is it not worth finding a second hand unit?
Post 746996 by Craigy t5 on 2014-11-07 18:41:49
[QUOTE=Tomcat;746991]Be tragic to break it for that, will the car not run without like the Ph1 cars?.. Is it not worth finding a second hand unit?[/QUOTE] Yeh it still runs same as the Ph1 cars, it just spins up now where before it gripped and off, probably can find a second hand unit, but how long would it last is my concern,, early days yet gonna have a nosey over weekend take it from there.
Post 747009 by stribo on 2014-11-07 19:17:56
Hopefully it's just the collar.
Post 747121 by Craigy t5 on 2014-11-08 12:49:08
Jacked the car up all 4 wheels off the ground, put the car in gear front wheels turn with a grinding noise from the angle gear, the prop turns very slowly-think this is just friction, rear wheels don't turn. So still not sure if its the sleeve or angle box, suppose the only way is to get the sleeve off or is there another way of checking? Oh checked the AWD fuse thats ok, lol
Post 747123 by Harvey on 2014-11-08 12:54:45
Sounds like the teeth or bearing have disintegrated. Not good news sorry to hear.
Post 750112 by Craigy t5 on 2014-11-30 11:06:10
OK quick update so far,,, Angle box off and stripped down, bizarrely the sleeve that normally goes is all ok and intact, oil lovely and clean, whats happened with this is where the angle gear meets the gearbox it has stripped the splines there instead ( this is the other end of crown wheel ) the gearbox side does not seem to bad,,,, I know an engineer so will see if he can do anything with it.
Post 750125 by Harvey on 2014-11-30 13:49:27
The main gearbox output shaft is ok?,but the input shaft on the angle gearbox is worn ?. I don't think Volvo sell angle gearbox parts ,they comes as a complete assembly I believe.
Post 750129 by Craigy t5 on 2014-11-30 14:10:39
[QUOTE=Harvey;750125]The main gearbox output shaft is ok?,but the input shaft on the angle gearbox is worn ?. I don't think Volvo sell angle gearbox parts ,they comes as a complete assembly I believe.[/QUOTE] Thats correct gearbox output shaft is ok,and input shaft on angle box is worn,, hopeing to have the end of input shaft re splined/toothed? if possible,, failing that new anglebox,.
Post 750315 by Andy G on 2014-12-01 22:03:14
so is this the transfer box that's gone south and causing the problem?
Post 754391 by Craigy t5 on 2015-01-03 20:12:28
[QUOTE=Andy G;750315]so is this the transfer box that's gone south and causing the problem?[/QUOTE] Yep, angle gearbox knackerd,
Post 754392 by Craigy t5 on 2015-01-03 20:18:46
Quick update, Sleeve now off, one black-eye and cutface later,, used a puller and heat it came off, not easy but do-able,,, Next step, brand new anglebox and sleeve,,,, dont know what hurts more, the cost of it all or the injured face, lol,
Post 754401 by Ettienne on 2015-01-03 21:11:55
[QUOTE=Harvey;750125]The main gearbox output shaft is ok?,but the input shaft on the angle gearbox is worn ?. I don't think Volvo sell angle gearbox parts ,they comes as a complete assembly I believe.[/QUOTE] They are sealed unit but can be rebuilt, have a look on the p2 tuning thread there is a guide. Early ones had chocolate shafts and splines, that wear smooth out, however you can save a fortune by welding the collar on so it doesn't fail again, even on worn out parts, again in the p2 tuning thread.
