Post 746468 by Dream3r on 2014-11-04 19:21:43
I was wondering what spring pressure (if you've measured it) the piston opens?
I have mine set up and it seems to be running fine, -0.8bar, just musing for more info as I might try it lower but it involves a fair bit of fiddling!
John.
Post 746505 by Dangerous Dave on 2014-11-04 22:54:27
Think Wobbly Dave is running one on his beastie
Post 746993 by LeeT5 on 2014-11-07 18:27:37
I'm using a Forge Motorsport recirc valve with the stock spring removed and a yellow one in it's place.
Post 747130 by Dream3r on 2014-11-08 13:41:44
[QUOTE=LeeT5;746993]I'm using a Forge Motorsport recirc valve with the stock spring removed and a yellow one in it's place.[/QUOTE]
External? Which one?
Post 747134 by LeeT5 on 2014-11-08 14:14:48
What do you mean by external? Do you mean seperate to the turbo? IE, the oe recirc valve blanked off and a seperate valve? If so, ignore my post.
Post 747144 by Dream3r on 2014-11-08 15:57:43
[QUOTE=LeeT5;747134]What do you mean by external? Do you mean seperate to the turbo? IE, the oe recirc valve blanked off and a seperate valve? If so, ignore my post.[/QUOTE]
I'm not sure how else it can be interpreted, lol. Yes external from the turbo, i.e. not built in-to the compressor cover and not stock.
