dash board lights and various switches with lights out
Post 746129 by Andy G on 2014-11-02 20:16:23
850 T5R estate Is it straight forward to replace these bulbs either in the switches or on the dash?
Post 746135 by Saaamon on 2014-11-02 20:29:43
Yes very simple, remove switch with a bone tool or flat headed screw driver, then turn the white part in the picture 1/8th of a turn then remove. ImageImage To replace the bulbs in the cluster is also very simple and takes ten mins to remove the top of the dash.
Post 746137 by stribo on 2014-11-02 20:35:54
I believe if you have skinny arms, you can reach up behing the dash to change them without having to take it out.
Post 746172 by Andy G on 2014-11-02 22:10:35
right, they seem to be the perfect answers, many thanks.
Post 746176 by AcidicDavey on 2014-11-02 22:34:08
Also, the bulbs in the dash switches are called 'grain of wheat bulbs' in those tiny tall white bulb holders. You just have to thread the bulbs into the holders. These are the bulbs out of their holder but clear obviously. Or you can obviously get them from Volvo but I believe they are like £4 each, sod that!
