Post 744473 by hemihusky on 2014-10-25 06:29:14
Hey all got a emergency issue need help badly. Replaced my water pump.n got a timing belt kit from pfv but I cant get the belt back on! It looks way too small Im out of ideas n need to be on the road at 11am. Help!
Post 744475 by stribo on 2014-10-25 07:34:23
Have you measured it against the old one? You probably have to release the tensioner, though not sure how you do it.
Post 744479 by merc85 on 2014-10-25 08:14:48
There's to different lengths of belt Upto and from engine number's one kit is usually cheaper than the other so when peeps shop around for prices make sure your looking at the same belt. ;)
21 x143th is upto 131154
23 x148th from eng 131155
Worth baring in mind Your car may have had a engine change at some point.
Post 744500 by hemihusky on 2014-10-25 12:20:21
Other lads came in n we sussed it 1 horid quality cam tool was allowing on to wobble around n throwing me off and I needed someone to hold the pulley up while I put the tentioner in what a faf!
