V70R Service
Post 742857 by Craigy t5 on 2014-10-16 19:57:41
Hi all, Had the car in for service today on which they found quite a few jobs that need doing, what i am after knowing is how much of the following is doable at home to avoid the garage labour cost/s,. Front wishbones, Front ABS rings, Rear trailing arm bushes Rear pads (will the pistons push in or do i need a tool to wind them in), I have most tools and a vice but know press. Car is 03 reg.
Post 742890 by M-R-P on 2014-10-16 20:41:40
Front wishbones... polybush - 3 hours if you're good with the spanners ABS rings - do at the same time as the wishbones Rear pads - easy, yes, they push in. Dunno about the trailing arm bushes tbh :)
Post 742895 by Ettienne on 2014-10-16 20:47:18
Delta link bushes, it's quite quite to strip the rear end own 1 hour ish then it's just removing the bushes. See t5pete thread has a guide
