Bulb warning light?
Post 738733 by Quicksilver on 2014-10-01 23:28:02
My bulb warning light has started flashing periodically as I brake, all brake lights are functioning, any ideas?
Post 738735 by M-R-P on 2014-10-01 23:53:14
Chances are there's a furry connection on a bulb somewhere. If it's not coming on with the brakes, that's 2 bulbs to rule out.. Check things like headlight wiring and indicator bulbs. Taking the bulb out and refitting is usually enough.
Post 738752 by JamesT5 on 2014-10-02 08:40:17
My bulb warning is on all the time now, I just ignore it. So much for Canbus HID kits......... :hbomb:
Post 738753 by M-R-P on 2014-10-02 08:43:13
Canbus HID kits are a con. I've been saying that for years. It's cheaper, easier and guaranteed to work without warnings if you simply fit a 50W load resistor across the power supply to the ballast.
Post 738796 by Quicksilver on 2014-10-02 11:15:12
I'll have to have a root round, it flickers just as I brake, brake lights all working. I'll check all connections and maybe change the brake switch.
Post 738800 by M-R-P on 2014-10-02 11:19:46
It'll be a furry bulb or at worst, a bulb on it's way out.
