rip kit fitting
Post 736002 by polak t5r on 2014-09-18 14:04:42
Hi all I need to know if a rip kit of a 850 t5 will fit my s70r manual cheers I was worried about the hose going onto the turbo as I know mine has a larger turbo then a 850 cheers
Post 736003 by MoleT-5R on 2014-09-18 14:09:28
I don't see why it should not fit, as you say your turbo is larger, you may need a different reducer/adaptor for that bit, easily available from someone like Ash silicone hoses
Post 736004 by polak t5r on 2014-09-18 14:12:02
Cool thanks does anyone know what size adapter id need
Post 736005 by stribo on 2014-09-18 14:17:44
The hose that goes on the turbo is normally bigger anyway so there's a bit of slack, on the aftermarket kits, don't know about the Volvo one, but I suppose you could use the hose that's already there.
Post 736007 by polak t5r on 2014-09-18 14:22:01
Cool ill have to have a play and see what happens cheers
Post 736008 by MoleT-5R on 2014-09-18 14:24:42
the first question is whether the turbo's outlet pipe is larger than the standard one and what turbo is it ??
Post 736009 by p fandango on 2014-09-18 14:42:57
All td04's have the same size outlet
Post 736011 by stribo on 2014-09-18 15:00:51
[QUOTE=p fandango;736009]All td04's have the same size outlet[/QUOTE] Are you sure? You told me all TD04s had the same hot side, and that turned out not to be the case.
Post 736016 by Ettienne on 2014-09-18 15:09:48
51mm iirc all the same. The 12t has a different exhaust housing the rest are the same.
Post 736017 by p fandango on 2014-09-18 15:10:35
[QUOTE=stribo;736011]Are you sure? You told me all TD04s had the same hot side, and that turned out not to be the case.[/QUOTE] Sorry, all Volvo td04's do
Post 736020 by Ettienne on 2014-09-18 15:22:38
The 3" angle exhaust housing is different on the 12t as they have a smaller exhaust turbine wheel. So the hit side is different on the 12t, but that's the only one that is.
Post 736115 by polak t5r on 2014-09-19 13:02:00
it has the standard s70r manual turbo on is it 18t
Post 736117 by stribo on 2014-09-19 13:14:18
[QUOTE=Ettienne;736020]The 3" angle exhaust housing is different on the 12t as they have a smaller exhaust turbine wheel. So the hit side is different on the 12t, but that's the only one that is.[/QUOTE] And guess which one I bought for the angle flange. :slap:
Post 736121 by MoleT-5R on 2014-09-19 13:52:52
[QUOTE=p fandango;736009]All td04's have the same size outlet[/QUOTE] that's what I thought, but I wasn't going to post it just in case I'd heard it wrong..:hidesbehi
Post 736129 by Biff on 2014-09-19 15:28:28
[QUOTE=polak t5r;736115]it has the standard s70r manual turbo on is it 18t[/QUOTE] Yes mate should be an 18t
Post 736563 by AshDVS on 2014-09-22 14:51:58
Assuming that both are stock and havent been fitted with non-volvo or aftermarket turbos, there should be no issue at all.
