bye bye 8v hello 16v
Post 735820 by t5 pete on 2014-09-17 16:21:00
Image Image Its been a long time coming and must itch the rwd fun to be had
Post 735829 by smithy on 2014-09-17 17:58:34
Nice I would like a evo head for mine in the future
Post 735833 by t5 pete on 2014-09-17 18:08:45
Yep wanted one of these for along time just got to buy a late 940 now for rest of bits
Post 735835 by Jamest5r on 2014-09-17 18:10:29
[QUOTE=t5 pete;735833]Yep wanted one of these for along time just got to buy a late 940 now for rest of bits[/QUOTE] I know a man that just got one lying around doing nothing :)
Post 735837 by no1tosh on 2014-09-17 18:25:09
very nice, are you keeping it stock or are you gonna have a play with it?
Post 735852 by t5 pete on 2014-09-17 19:13:25
[QUOTE=no1tosh;735837]very nice, are you keeping it stock or are you gonna have a play with it?[/QUOTE] Oh no got to have a nice turbo on there custom manifolds etc etc
Post 735868 by t5 pete on 2014-09-17 19:48:17
[QUOTE=Jamest5r;735835]I know a man that just got one lying around doing nothing :)[/QUOTE] Yep minds well donate it
Post 735880 by jamesy12345 on 2014-09-17 20:14:18
eh which car is this going in?
Post 735884 by t5 pete on 2014-09-17 20:30:20
It will go in the next one going to build it up over winter and source rest of parts then will be on the look out for another 240
Post 735890 by jamesy12345 on 2014-09-17 20:35:50
16v red block a rare beast
Post 735892 by t5 pete on 2014-09-17 20:39:30
[QUOTE=jamesy12345;735890]16v red block a rare beast[/QUOTE] Yep certainly is will probably donate the gul to the other half when its done and this will be the new toy need to start looking into stand alone ecus shouldnt be too hard to tune as it will virtually be the same set up as the cosworth
Post 736060 by t5 pete on 2014-09-18 20:50:42
Come on then Mr Smith when are you donating me this car you have laying around so Jimbob says ?
Post 736141 by barkster1971 on 2014-09-19 19:01:00
Are you sticking with the b234 complete engine or just putting the 16v head on a b230 block. Silveruser has still got the yoshifab tensioner conversion for sale. So you buying a hx40 next? and forged internals and megasquirt and a top banana clutch and exhaust manifold!
Post 736151 by t5 pete on 2014-09-19 20:13:08
[QUOTE=barkster1971;736141]Are you sticking with the b234 complete engine or just putting the 16v head on a b230 block. Silveruser has still got the yoshifab tensioner conversion for sale. So you buying a hx40 next? and forged internals and megasquirt and a top banana clutch and exhaust manifold![/QUOTE] Please point me in the direction of silveruser the head will be mated to a b230ft block forged rods either cossy intake or custom and custom exhaust manifold with regards to megasquirt ive yet to do my reaserch and weather ill tune it my self or have it done else where. The set up will be nearly the same a as cosworth T34 turbo. also if you know of any one with a b20 oil pan let me know
Post 736159 by barkster1971 on 2014-09-19 21:13:24
do a seller search on ebay for him, it's the retro turbo stuff. You looking to mount it vertically then. If you're putting it in a rhd 240 you'll need it vertical to free up some space.
Post 736161 by t5 pete on 2014-09-19 21:26:44
That's correct that's why I need it vertically will do the search now for silveruser
Post 736162 by t5 pete on 2014-09-19 21:29:59
Unless he sells candy floss that's the only user ebay comes up with for silver user
Post 736811 by barkster1971 on 2014-09-23 20:14:29
retro turbo on facebook, peter is his name.
Post 736812 by t5 pete on 2014-09-23 20:17:05
Found him bud cheers its actually his own kit which he makes up butneed to order all sorts from josh so going to get them from there
Post 737005 by AshDVS on 2014-09-25 13:46:11
[QUOTE=barkster1971;736159]do a seller search on ebay for him, it's the retro turbo stuff. You looking to mount it vertically then. If you're putting it in a rhd 240 you'll need it vertical to free up some space.[/QUOTE] [QUOTE=t5 pete;736161]That's correct that's why I need it vertically will do the search now for silveruser[/QUOTE] Not neccessarily, you can mount it slanted as per normal in a 240 - this make life easier from a sump and engine mount point of view. If you do this though, you'll need to re-think clutch master cyl (if running hydraulic clutch and manual) - you could use an aftermarket cyl and/or pedal box here and mount on the inside of the cabin. It may also be worth re-thinking the brake booster if you plan to run a very elaborate exh manifold. There are a few different 240 steering columns, with the knuckle in different places from different years that you could make use of when you're chasing exhaust system clearance. Obviously you wont run a head mounted dizzy as it just wont clear. Having the engine on the slant also frees up some space on the intake side too so you can get creative there. If you go vertical though, you can make use of a B20 sump for clearance but you're then thinking about mounts, etc. I'd personally go slanted and I'd go with a real ECU rather than a hobbyist ECU like Megasquirt. Looking forward to some progress pics!
Post 737011 by t5 pete on 2014-09-25 15:10:10
[QUOTE=AshDVS;737005]Not neccessarily, you can mount it slanted as per normal in a 240 - this make life easier from a sump and engine mount point of view. If you do this though, you'll need to re-think clutch master cyl (if running hydraulic clutch and manual) - you could use an aftermarket cyl and/or pedal box here and mount on the inside of the cabin. It may also be worth re-thinking the brake booster if you plan to run a very elaborate exh manifold. There are a few different 240 steering columns, with the knuckle in different places from different years that you could make use of when you're chasing exhaust system clearance. Obviously you wont run a head mounted dizzy as it just wont clear. Having the engine on the slant also frees up some space on the intake side too so you can get creative there. If you go vertical though, you can make use of a B20 sump for clearance but you're then thinking about mounts, etc. I'd personally go slanted and I'd go with a real ECU rather than a hobbyist ECU like Megasquirt. Looking forward to some progress pics![/QUOTE] I know it doesn't 100% need to be vertical but as im sure as you know it frees so much spare room up. also custom making some engine mounts, altering the pick up tube and making a adapter plate for the gear box is not much work for us and much cheaper and simpler than having to fit either a new pedal box or farting around with a custom clutch set up and also with it being vertical It will give me more clearance for the steering rack which also save time and money messing about with different steering columns and trying to source them. I will be looking into fitting a slim brake servo and as I have lots of room on the intake side I can make a custom inlet or I may look into the cosworth manifold. I need to have a talk to a decent tuner with regards what way to go for the ecu as it will be near enough the same as a cosworth so ill see what they recommend and what they use, what would you call a real ecu? Pic's will be here but may me awhile as ive still got to finish the gull and then this project will be put on the back burner while I source parts and another 240.
Post 737204 by AshDVS on 2014-09-26 03:49:28
There's definately pros and cons of both and if you're not using a Volvo gearbox, mounting vertically can make a lot of sense. Regarding ECUs, Autronic SMC and Motec M84 are fairly well featured and not rediculously expensive. The Haltech E6X was quite popular a few years ago and was very good, but has been discontinued for some time - there is still some good support out there for it though.
Post 762477 by t5 pete on 2015-03-06 14:15:48
Well found a nice 240 glt and will hopefully be picking it up soon also got the fk block been looking at rods and going to order a set just over £200 for all four I will also get new pistons. Going to lakes at the weekend and will be on the look out for a 1041 axel and after that I just need to get hold of a borgwarner warner t5 gear box and I can start fabrication on the vert set up
Post 762566 by barkster1971 on 2015-03-06 18:48:46
If you find an early 960 there get the 1041k axle off it. Meant to be a little bit stronger than the 1041 mainly on the 2litre Wentworths.
Post 762570 by t5 pete on 2015-03-06 18:55:54
Thank you Barkster hopefully there will be one there
Post 762573 by barkster1971 on 2015-03-06 19:04:28
There's a nice set of galaxy alloys on a white motor and a decent set of comets too on a reddish motor.
Post 762577 by martin_r_smith on 2015-03-06 19:11:51
He'll get the Galaxies! Lol
Post 762802 by t5 pete on 2015-03-07 20:24:43
[QUOTE=martin_r_smith;762577]He'll get the Galaxies! Lol[/QUOTE] Lol i think there wanting to sell that car as a whole ill just have to make do with the polaris.
Post 762941 by t5 pete on 2015-03-08 18:04:38
Awesome day at lakes and look what I've bagged Image
Post 762942 by oblark on 2015-03-08 18:07:17
What does the K after 1041 stand for ?
Post 762944 by stribo on 2015-03-08 18:16:08
[QUOTE=t5 pete;762941]Awesome day at lakes and look what I've bagged Image[/QUOTE] You got a barcode?
Post 762945 by t5 pete on 2015-03-08 18:20:01
[QUOTE=oblark;762942]What does the K after 1041 stand for ?[/QUOTE] Kool I'm hoping lol dunno tbh but Barkster and all the info on the net point to the 1041 k being stronger than the 1041
Post 762946 by t5 pete on 2015-03-08 18:20:31
[QUOTE=stribo;762944]You got a barcode?[/QUOTE] Yeah it's been a life long dream of mine to have one just like this
Post 762947 by t5 pete on 2015-03-08 18:26:29
The k looks more well built http://www.turbobricks.com/forums/showthread.php?p=2524368
Post 762948 by oblark on 2015-03-08 18:27:25
[QUOTE=t5 pete;762945]Kool I'm hoping lol dunno tbh but Barkster and all the info on the net point to the 1041 k being stronger than the 1041[/QUOTE] I thought it could have meant it was locker diff.
Post 762949 by jamesy12345 on 2015-03-08 18:33:00
[QUOTE=oblark;762942]What does the K after 1041 stand for ?[/QUOTE] [QUOTE=t5 pete;762945]Kool I'm hoping lol dunno tbh but Barkster and all the info on the net point to the 1041 k being stronger than the 1041[/QUOTE] Google says..http://forums.turbobricks.com/showthread.php?t=175164
Post 762953 by t5 pete on 2015-03-08 18:41:12
The 1041 diffs are locker diffs the k means that it's from a 960
Post 762976 by barkster1971 on 2015-03-08 20:11:58
K is for kick ass.
Post 764069 by t5 pete on 2015-03-16 13:59:54
Picking the 240 up tomorrow also got a t5 gear box and just waiting on classic swede fining me a b20 oil pan and bell housing
Post 764198 by t5 pete on 2015-03-17 18:03:05
It's home Image
Post 764235 by Sweep on 2015-03-17 20:24:56
Being a proper Brick fan I shall be watching this with intent! Waiting for a 940 to turn up myself so I can build myself a weapon.
Post 764304 by t5 pete on 2015-03-18 10:22:41
Gear box should be here today
Post 777821 by t5 pete on 2015-07-08 22:31:43
Spoilt for choice dug all the parts out so should be making a start got to break the white one first for the manual conversion Image
Post 777823 by Doingitsideways on 2015-07-09 00:06:04
I know it's late, but I see TWO white ones?
Post 777825 by AcidicDavey on 2015-07-09 01:03:23
I see one white and two silvers? Your eyes must be failing you in your old age :P
Post 777828 by Ettienne on 2015-07-09 07:25:34
My friends putting a 16v head on frankies old 744, the engine came up for stupid money in local breakers so I grabbed it. I do like a turbo charged old brick, silver is not a bad colour to start with either I may well t5 a 242/244 in the future when last few bits are finished up, but a few home things to do as well.
Post 777837 by t5 pete on 2015-07-09 10:13:50
Lol ones white ones silver and the other is green The silver one will be painted same colour as the green one quite a rare colour I believe and I certainly haven't seem many like it
Post 777888 by AcidicDavey on 2015-07-09 22:44:17
Which one's the green one? The far away one? :P
Post 777889 by t5 pete on 2015-07-09 22:57:49
The closest
Post 777890 by t5 pete on 2015-07-09 23:01:58
Paint code 178Green metallic/Silver green metallic240 260 760 It's one of them weird colours some times it looks green then silver
Post 777891 by Doingitsideways on 2015-07-09 23:10:07
Image I really like the red one :)
Post 777900 by t5 pete on 2015-07-09 23:23:00
[QUOTE=Doingitsideways;777891]Image I really like the red one :)[/QUOTE] Ah yes good choice sir the one next to the two white ones
Post 789241 by barkster1971 on 2015-10-24 21:04:35
progress?
Post 789244 by Jamest5r on 2015-10-24 22:29:29
He's been busy buying lots of nice bits but don't tell his Mrs :)
Post 789245 by Nealevo on 2015-10-24 23:24:24
[QUOTE=Jamest5r;789244]He's been busy buying lots of nice bits but don't tell his Mrs :)[/QUOTE] I'm going to tell her tomorrow...
Post 789262 by t5 pete on 2015-10-25 12:00:57
Haha yes ide forgot about this thread ill up date later on
Post 789286 by Sweep on 2015-10-25 19:03:59
What rods did you go for in the end? I had second thoughts on the eBay specials, think I'm going to go with a set from Sten Palmer from KG Trimning.
Post 789579 by barkster1971 on 2015-10-29 21:17:07
Chinese specials. The one's from Sweden are made there I believe. Less than £200 on ebay.
Post 789582 by t5 pete on 2015-10-29 22:14:24
No chinky specials I've gone all wiseco fully forged
Post 789583 by t5 pete on 2015-10-29 22:29:11
Image Image Image Image Image Image Image Image
Post 789589 by martybelfastt5 on 2015-10-29 23:00:31
:eye-poppi
Post 790152 by t5 pete on 2015-11-06 14:24:33
Image Image Image
Post 790625 by timbo on 2015-11-12 10:23:23
Haha! Little Pete loving the 240 revamp!!! Lol! [QUOTE=t5 pete;789582]No chinky specials I've gone all wiseco fully forged[/QUOTE] Where did you get rods and pistons from Pete? The Don?? Trying to find a dealer for wise co stuff but struggling!
Post 790634 by smithy on 2015-11-12 16:34:10
[QUOTE=timbo;790625]Haha! Little Pete loving the 240 revamp!!! Lol! Where did you get rods and pistons from Pete? The Don?? Trying to find a dealer for wise co stuff but struggling![/QUOTE] Coordsport do the stuff for the redblock mate .i got wesco pistons and rods from them for mine
Post 790639 by timbo on 2015-11-12 16:54:07
Cheers smithy!
Post 790656 by t5 pete on 2015-11-12 19:52:51
[QUOTE=smithy;790634]Coordsport do the stuff for the redblock mate .i got wesco pistons and rods from them for mine[/QUOTE] Snap same here, looking like December for stuff all out of stock
Post 790657 by t5 pete on 2015-11-12 19:53:44
Should also be picking the new exhaust housing up for the gt30 tomorrow roll on external wastegate
Post 790667 by smithy on 2015-11-12 22:36:25
[QUOTE=t5 pete;790657]Should also be picking the new exhaust housing up for the gt30 tomorrow roll on external wastegate[/QUOTE] Sounds nice enjoy mate
Post 790713 by t5 pete on 2015-11-13 16:46:11
New exhaust housing for external wastegate Image Image Image
Post 790930 by t5 pete on 2015-11-15 22:47:55
Fitted the new housing today so it's all set for external wastegate now also received my throttle body yesterday if frickin huge I'm also going to try a Fiat throttle body to see the fit cheer to colin. Image Image [URL=http://s595.photobucket.com/user/t5pete/media/20151115_110808_zpse3k9ybgb.jpg.html][IMG]http://i595.photobucke t.com/albums/tt39/t5pete/20151115_110808_zpse3k9ybgb.jpg[/IMG][/URL] Image Image
Post 790936 by Doingitsideways on 2015-11-15 23:16:08
Mmmmmm...... :)
Post 791165 by barkster1971 on 2015-11-18 21:42:30
needs more turbo!
Post 791170 by t5 pete on 2015-11-18 22:18:26
[QUOTE=barkster1971;791165]needs more turbo![/QUOTE] :cuckoo:
Post 791174 by Biff on 2015-11-18 22:55:33
Car of the year 2016? I think so. Never fail to impress big man.
Post 791210 by t5 pete on 2015-11-19 17:44:11
Just got word from bell supplier the custom bells are near completion so roll on ap brakes for the 240
Post 791212 by Ettienne on 2015-11-19 18:22:45
Just looking at the turbo'd 2.0 16v 940/960s it would work out quite cheap to buy one from Europe for the engine.
Post 791213 by Ettienne on 2015-11-19 18:24:27
[QUOTE=t5 pete;791210]Just got word from bell supplier the custom bells are near completion so roll on ap brakes for the 240[/QUOTE] Oblarks used some of my 850 discs to fit 312s 4 pots on his 244, under 16" steelies. Bells and rotors are very nice though
Post 791215 by oblark on 2015-11-19 18:52:28
[QUOTE=Ettienne;791213]Oblarks used some of my 850 discs to fit 312s 4 pots on his 244, under 16" steelies. Bells and rotors are very nice though[/QUOTE] I thought I had some photos of the brakes with the wheels but I can't find them but I did find this one. Image
Post 791230 by t5 pete on 2015-11-19 20:10:20
Very nice but I dropped on a set of ap brakes so it would be rude not to run 325mm under polaris something no one has been able to do same for mat with his 330mm s60r brakes to run with no spacers. I'll also have a set of ap calliper brackets and bells for sale for the fwd t5's
Post 791232 by t5 pete on 2015-11-19 20:11:00
[QUOTE=Ettienne;791212]Just looking at the turbo'd 2.0 16v 940/960s it would work out quite cheap to buy one from Europe for the engine.[/QUOTE] For a standard car possibly but with what I'm running it would need every thing uprating anyway.
Post 791964 by t5 pete on 2015-11-24 23:04:45
And the 240 is a step closer to some great stopping power Image Image Image Image
Post 791976 by Nealevo on 2015-11-25 08:09:09
doesnt it need to be moving to be able to STOP...
Post 791979 by t5 pete on 2015-11-25 08:25:37
[QUOTE=Nealevo;791976]doesnt it need to be moving to be able to STOP...[/QUOTE] It'll be moving by next year showing your pink car up on the 1/4 a little like that yellow one did lol
Post 791985 by Nealevo on 2015-11-25 09:53:01
[QUOTE=t5 pete;791979]It'll be moving by next year showing your pink car up on the 1/4 a little like that PISS yellow one did lol[/QUOTE] YAAWWWWWWWWWWWWWwwwwnnnnnnnnnnnnnnnnnnnnnnnnnnnnnn, sorry did you say something, i dont understand Northern
Post 792009 by t5 pete on 2015-11-25 14:53:36
[QUOTE=Nealevo;791985]YAAWWWWWWWWWWWWWwwwwnnnnnnnnnnnnnnnnnnnnnnnnnnnnnn, sorry did you say something, i dont understand Northern[/QUOTE] Haha funny guy NOT
Post 792112 by t5 pete on 2015-11-27 13:10:08
Pink poly bush kit as every one needs a bit of pink every now and again. Image
Post 792114 by Doingitsideways on 2015-11-27 13:41:34
I heard you prefer brown :lol:
Post 792115 by t5 pete on 2015-11-27 14:19:12
[QUOTE=Doingitsideways;792114]I heard you prefer brown :lol:[/QUOTE] Haha don't believe a word of it
Post 792123 by stribo on 2015-11-27 19:44:02
I'd say Wobbly Dave is a fairly reliable source. ;)
Post 792382 by t5 pete on 2015-12-01 17:03:06
Image Image
Post 792383 by Doingitsideways on 2015-12-01 17:42:09
[QUOTE=t5 pete;792382]Image Image[/QUOTE] I hate you
Post 792384 by Nealevo on 2015-12-01 17:49:35
[QUOTE=Doingitsideways;792383]I hate you[/QUOTE] Long long queue mate...
Post 792385 by t5 pete on 2015-12-01 18:05:07
Haha nob heads
Post 792387 by jdavis on 2015-12-01 18:24:27
Looks great Pete.
Post 792388 by martin_r_smith on 2015-12-01 18:42:03
I'm pitching a tent in my pants right now...
Post 792390 by Doingitsideways on 2015-12-01 19:10:01
[QUOTE=martin_r_smith;792388]I'm pitching a tent in my pants right now...[/QUOTE] Yeah, Pete's used to that when he's down The Blue Oyster bar on Friday nights!
Post 792399 by t5 pete on 2015-12-01 22:28:55
[QUOTE=Doingitsideways;792390]Yeah, Pete's used to that when he's down The Blue Oyster bar on Friday nights![/QUOTE] Lol I had to Google it blue oyster bar, you must have some good memories there from there
Post 792402 by Biff on 2015-12-01 23:46:01
Volvo porn right here. When I grow up I want to be Pete.
Post 792403 by Doingitsideways on 2015-12-01 23:52:56
[QUOTE=t5 pete;792399]Lol I had to Google it blue oyster bar, you must have some good memories there from there[/QUOTE] Yeah. I don't go though any more, it's not as good as it used to be.
Post 792406 by Nealevo on 2015-12-02 07:27:34
[QUOTE=Biff;792402]Volvo porn right here. When I grow up I want to be [COLOR="#FF0000"]IN [/COLOR]Pete.[/QUOTE] errrrrr, that the Blue oyster bar from earlier comments
Post 792419 by t5 pete on 2015-12-02 15:07:55
What's better than one quaife Two quaifes Image Image
Post 792425 by barkster1971 on 2015-12-02 18:13:42
When you've finished queefing, what turbo you putting on and what power are you expecting. I may get my 16v head up to 300-320 cfm from the stock 220, that should give me easily 500 bhp at 2 bar boost.
Post 792426 by Doingitsideways on 2015-12-02 18:23:37
[QUOTE=barkster1971;792425]When you've finished queefing...[/QUOTE] :lol:
Post 792429 by timbo on 2015-12-02 19:04:55
Get a grip Pete, you won spot the (mens) ball(s) comp or have you been signed up to be a model for Puka pies? See you down the pink flamingo sideways, usual cubical ;) Cant wait to see this car btw..............................
Post 792432 by Doingitsideways on 2015-12-02 19:24:57
Don't be daft. Pete would never lower himself to being sponsored by Pukka Pies, the pale southern imitation of a proper northern pie like Hollands!
Post 792435 by t5 pete on 2015-12-02 19:50:22
[QUOTE=barkster1971;792425]When you've finished queefing, what turbo you putting on and what power are you expecting. I may get my 16v head up to 300-320 cfm from the stock 220, that should give me easily 500 bhp at 2 bar boost.[/QUOTE] I will be seeing around 500 but with good spool times unlike the bus turbos
Post 792442 by barkster1971 on 2015-12-02 22:06:40
might be putting a gtw3884 on mine. A gt30 might be a bit too small, but I've seen the odd one that looks huge, must depend on version. The hx40 is heavy, will need a good manifold!
Post 792460 by t5 pete on 2015-12-03 12:32:21
Great big turbos are fine for bragging rights but tbh that's where it ends also our engines are of a small diplacment even with a low a/r there going to take a time to spool. A good 500 hp with decent traction off the line will take some beating. Just for instance james t5r has a much bigger turbo and much more power than my custom 19t but setting off on the 1/4 the 19t just leaves it it's only till 3rd gear pull and he's on ful power he starts to pull me in by that time the race is over.
Post 792463 by Jamest5r on 2015-12-03 13:10:12
[QUOTE=t5 pete;792460]Great big turbos are fine for bragging rights but tbh that's where it ends also our engines are of a small diplacment even with a low a/r there going to take a time to spool. A good 500 hp with decent traction off the line will take some beating. Just for instance james t5r has a much bigger turbo and much more power than my custom 19t but setting off on the 1/4 the 19t just leaves it it's only till 3rd gear pull and he's on ful power he starts to pull me in by that time the race is over.[/QUOTE] Raced you twice beat you twice, end of that argument :)
Post 792464 by t5 pete on 2015-12-03 13:12:13
[QUOTE=Jamest5r;792463]Raced you twice beat you twice, end of that argument :)[/QUOTE] Ah you raced me 4 times I beat you twice, the last two times you sabatarged my car first you burnt my clutch out then made me blow a intercooler pipe.
Post 792465 by t5 pete on 2015-12-03 13:13:02
[QUOTE=t5 pete;792464]Ah you raced me 4 times I beat you twice, the last two times you sabatarged my car first you burnt my clutch out then made me blow a intercooler pipe.[/QUOTE] ...
Post 792466 by Doingitsideways on 2015-12-03 13:32:23
[QUOTE=t5 pete;792464]Ah you raced me 4 times I beat you twice, the last two times you sabatarged my car first you burnt my clutch out then made me blow a intercooler pipe.[/QUOTE] Could be worse, you could be Donna. She got so sick of being beaten by a long-haired Manc in an automatic, she gave up! :lol:
Post 792471 by smithy on 2015-12-03 17:32:40
Or[QUOTE=t5 pete;792460]Great big turbos are fine for bragging rights but tbh that's where it ends also our engines are of a small diplacment even with a low a/r there going to take a time to spool. A good 500 hp with decent traction off the line will take some beating. Just for instance james t5r has a much bigger turbo and much more power than my custom 19t but setting off on the 1/4 the 19t just leaves it it's only till 3rd gear pull and he's on ful power he starts to pull me in by that time the race is over.[/QUOTE] I don't think that was the problem with Jim he was too afraid of breaking a shaft or gearbox that he didnot launch the car heavy .and the map still needed adjusting .or he cannot drive lol.larger turbos are good depends what exhaust housing your using .i have a hybrid t4 but with a .63 3in exhaust housing .when I had the t35 on I was on full boost by 2.200rpm .i was using a 960 65mm to at the time too .im using a 75mm to now and custom manifold so the lag should be low still .also the t35 only has a .48 2.5 in exhaust housing so quick spool up too and that's the turbo Jim has on his car now .i still say Jim has a low 13 high 12 quarter mile car when hooked properly imoa
Post 792493 by t5 pete on 2015-12-03 20:01:35
[QUOTE=smithy;792471]Or I don't think that was the problem with Jim he was too afraid of breaking a shaft or gearbox that he didnot launch the car heavy .and the map still needed adjusting .or he cannot drive lol.larger turbos are good depends what exhaust housing your using .i have a hybrid t4 but with a .63 3in exhaust housing .when I had the t35 on I was on full boost by 2.200rpm .i was using a 960 65mm to at the time too .im using a 75mm to now and custom manifold so the lag should be low still .also the t35 only has a .48 2.5 in exhaust housing so quick spool up too and that's the turbo Jim has on his car now .i still say Jim has a low 13 high 12 quarter mile car when hooked properly imoa[/QUOTE] You've only got to look at Dean many cars have more power but none can touch him or catch him till 3rd gear I was only using Jim bob as a instance as carl using a turbo capable of 700+
Post 792503 by smithy on 2015-12-03 21:00:56
[QUOTE=t5 pete;792493]You've only got to look at Dean many cars have more power but none can touch him or catch him till 3rd gear I was only using Jim bob as a instance as carl using a turbo capable of 700+[/QUOTE] Yes deans car is setup properly and has a really excellent map aswell .and my turbo is no good for more than 136 Bhp mate .
Post 792504 by barkster1971 on 2015-12-03 21:08:16
I think it's 850+! Yes may be a bit too big.
Post 792670 by jks on 2015-12-06 12:10:29
Nothing wrong with truck turbos!
Post 792671 by t5 pete on 2015-12-06 12:22:21
[QUOTE=jks;792670]Nothing wrong with truck turbos![/QUOTE] Certainly not if you want to wait a age for it to start building
Post 792678 by jks on 2015-12-06 14:48:47
Not true. Like Smithy earlier stated, it depends on the exhaust size. You can easily match holset to your liking. Affordable, strong and capable.
Post 792791 by barkster1971 on 2015-12-07 20:11:26
Is yours running jay?
Post 792792 by t5 pete on 2015-12-07 20:22:36
I suppose time will tell
Post 792807 by barkster1971 on 2015-12-07 22:54:20
What engine management you using? Bit of nitrous will soon get a big turbo spooled up. The optical dsm cas from yoshifab looks like a good bit of kit.
Post 792810 by t5 pete on 2015-12-07 23:02:56
Just currently going through a few suppliers at the mo as before having custom parts made we need to know what pick ups the chosen choice of management uses and also need to find some one who's happy mapping a system currently talking with Tim
Post 792811 by t5 pete on 2015-12-07 23:03:39
Yes the nitrous would be a good idea
Post 792822 by smithy on 2015-12-08 00:45:52
Jays car has been running reliable for ages now and it's his daily lol.he uses a 25 litre fuel cell with twin Bosch 044 pumps .his car has got a hx40 super with billet wheels and twin external wastgates .and has the yoshi inlet manifold and tubular exhaust .he runs 1000cc injectors on high capacity fuel rail and runs nearly 2 bar of boost lol.and he is still on l.h 2.4 with chips .but he has max tuning Swedish standalone in his cupboard waiting to go on when he fits his forged penta block back in .he also runs BMW gearboxes and explorer axle .take it from me the car is mad lol
Post 792837 by jks on 2015-12-08 10:29:27
My cars running sweet, thanks. Need more power!! Yours?
Post 792840 by jks on 2015-12-08 10:37:39
Maxx ecu, www.maxx tuning.eu, is good piece of kit. Good support and loads of options. You can also use tablet, like nexus 7, as a touch screen dash. I've got this. Nifty piece of kit..
Post 792841 by t5 pete on 2015-12-08 10:39:09
[QUOTE=jks;792840]Maxx ecu, www.maxx tuning.eu, is good piece of kit. Good support and loads of options. You can also use tablet, like nexus 7, as a touch screen dash. I've got this. Nifty piece of kit..[/QUOTE] I'll look into it cheers is there mappers over here who like to tune it
Post 792845 by jks on 2015-12-08 11:02:44
The guys from Sweden come over regularly. First choice of lot of volvo powered cars in Scandinavia. . If you need a hand, let me know..
Post 792846 by jks on 2015-12-08 11:08:02
Don't go Omex. You will regret it..been there..
Post 792848 by t5 pete on 2015-12-08 11:29:46
Cool cheers ive been looking at emerald and aem at the min but this good news if we can get the Maxx ecu tuned
Post 792851 by jks on 2015-12-08 11:48:42
Emerald is bit basic, support can be bit hard to get.. AEM, you really need a specialist and leave it to them.not DIY.. Vems is good, I've heard good reports. .
Post 792852 by jamesy12345 on 2015-12-08 12:31:33
Adaptronic..? I have an ECU & loom to fit although haven't done it yet
Post 792861 by t5 pete on 2015-12-08 17:15:07
Image Image Image
Post 792871 by Shinsplintz 101 on 2015-12-08 19:22:28
Ohhhh, shiny bits....
Post 793715 by t5 pete on 2015-12-24 17:37:11
And let the fun begin Image Image Image Image [URL=http://s595.photobucket.com/user/t5pete/media/20151223_195143_zps3cmgqdas.jpg.html]Image[/URL Image
Post 793718 by Doingitsideways on 2015-12-24 17:53:43
You not done this yet? Jesus, Smithy will be done before you at this rate.
Post 793721 by t5 pete on 2015-12-24 18:14:59
Haha I'm taking a leaf out of Smithy's book
Post 794319 by t5 pete on 2016-01-03 17:46:03
That's the diff near enough sorted think I can re use the bearings Image Image Image Image Image
Post 794528 by t5 pete on 2016-01-06 21:41:00
Just got all new bearings for the real axle
Post 794647 by Sweep on 2016-01-09 08:36:26
Have you had the rods checked for balance? I looked at the K1's for mine but yet to see anyone in the Volvo world to use them.
Post 794659 by t5 pete on 2016-01-09 11:04:28
Why would I need brand new rods checking. There's many people running k1 rods espically lots of 16v people who are running big power also wobbly dave and paul uses them in their t5 engines. K1 are highly regarded as one of the leading manufacturers but most people don't like the price tag so use Chinese rods
Post 794675 by Sweep on 2016-01-09 14:29:52
Why wouldn't you? Lotta moneys worth of shiney parts to just throw together without even making sure they're fit for use! 99% of engine builders will balance the entire bottom end before use. Where did you get them from if you don't mind me asking? Other than eGay specials and Sten Palmers from KG Trimning at eye watering prices there's not a lot of middle ground, I found K1's at about £480 which isn't too bad.
Post 794677 by t5 pete on 2016-01-09 14:53:10
[QUOTE=Sweep;794675]Why wouldn't you? Lotta moneys worth of shiney parts to just throw together without even making sure they're fit for use! 99% of engine builders will balance the entire bottom end before use. Where did you get them from if you don't mind me asking? Other than eGay specials and Sten Palmers from KG Trimning at eye watering prices there's not a lot of middle ground, I found K1's at about £480 which isn't too bad.[/QUOTE] They come with a full test spec sheet and have each been fully tested. They can be found at quite a few places on the net.
Post 794799 by jks on 2016-01-10 19:36:59
Absolutely nothing wrong with K1. Quality stuff..
Post 795195 by t5 pete on 2016-01-17 16:28:58
Got the trailing arms and wish bones back from blasting now to add strength. Also got my angle iron to make the brake calliper brackets out of. Got my new plates ready for strut brace. And I think I've decided on a colour. Image Image Image Image
Post 795197 by craigoodwood on 2016-01-17 17:03:28
i bet you just happen to have a set of polaris in the man-cave somewhere too :B_thumb:
Post 795200 by t5 pete on 2016-01-17 17:37:03
Yep and they happen to have my custom fit ap brakes behind them Image
Post 795427 by t5 pete on 2016-01-22 14:58:59
The blocks back also the head is being fixed which is great news and also have another 16v head on its way Image Image Image Image
Post 795432 by timbo on 2016-01-22 17:39:54
What you had done to the head Pete? Have you settled on a colour yet?
Post 795434 by t5 pete on 2016-01-22 18:10:14
[QUOTE=timbo;795432]What you had done to the head Pete? Have you settled on a colour yet?[/QUOTE] The gasket face was badly corroded due to ££££ or no coolant do needed filling it with weld and then skimmed. Are you on Facebook pal as there's loads of pictures on there
Post 795435 by Sweep on 2016-01-22 18:13:48
Shiny! Don't suppose you're relocating the oil filter are you? I can't find a suitable relocating plate anywhere! Plenty of sandwich plates for oil coolers but none to actually move the filter.
Post 795460 by t5 pete on 2016-01-23 12:25:05
That's the brackets don't just need a clean up and plating Image Image Image
Post 795464 by barkster1971 on 2016-01-23 18:10:35
The oil filter is stick on the backward facing heat exchanger bit. To use the external oil cooler that was fitted to the b230et etc , it helps to have the older style engine mounting brackets. If you're tapping the oil drain the fitting is hampered by the oil filter placement. And if you notice the tube back to the water pump it is useful to have the ne shown as the b230fk one has the pipes coming off that loop round the oil drain to the heat exchanger.
Post 795465 by t5 pete on 2016-01-23 19:05:51
[QUOTE=barkster1971;795464]The oil filter is stick on the backward facing heat exchanger bit. To use the external oil cooler that was fitted to the b230et etc , it helps to have the older style engine mounting brackets. If you're tapping the oil drain the fitting is hampered by the oil filter placement. And if you notice the tube back to the water pump it is useful to have the ne shown as the b230fk one has the pipes coming off that loop round the oil drain to the heat exchanger.[/QUOTE] All ready ahead of you the oil filter will be fitted with a sandwich plate then line to a external oil cooler. The water pipe tha runs along the block is a new n/a one as no longer need the extra water ports
Post 795599 by t5 pete on 2016-01-26 15:33:25
Image Image Image Image Image Gapping rings Image Image Image Image
Post 795600 by Doingitsideways on 2016-01-26 15:52:30
[QUOTE=t5 pete;795599]Image [/QUOTE] I think you should leave it looking exactly like this! :D
Post 795601 by t5 pete on 2016-01-26 15:56:10
[QUOTE=Doingitsideways;795600]I think you should leave it looking exactly like this! :D[/QUOTE] Looks like a gasser
Post 795602 by jamesy12345 on 2016-01-26 16:01:59
[QUOTE=t5 pete;795599]Image[/QUOTE] ^^gif not working?? Image
Post 795603 by Wobbly Dave on 2016-01-26 16:08:54
[QUOTE=t5 pete;794677]They come with a full test spec sheet and have each been fully tested. They can be found at quite a few places on the net.[/QUOTE] I bought mine from Coordsport - http://www.coordsport.com/index.php/our-brands-and-partners/item/219-k1-technologies and they also sold me the DW300 fuel pump
Post 795604 by t5 pete on 2016-01-26 16:10:52
[QUOTE=Wobbly Dave;795603]I bought mine from Coordsport - http://www.coordsport.com/index.php/our-brands-and-partners/item/219-k1-technologies and they also sold me the DW300 fuel pump[/QUOTE] That's where mine came from good place for parts as good customer service in one of the packs of the rings there were two bottom ring in there so call them up they didn't have any in stock so they came direct from wiseco to my door in two days and sent me two packs instead of just the 1. I'll be going for the aem pump
Post 795665 by t5 pete on 2016-01-27 15:19:56
And managed to source another 16v head so this one will come in as a spare as they managed to repair the other one. ImageImage Image Image Image Also got the gear box and bell housing sorted Image Image
Post 795742 by t5 pete on 2016-01-28 15:44:11
Image Image
Post 795754 by Doingitsideways on 2016-01-28 18:03:54
Classicswede's been busy then :)
Post 795758 by t5 pete on 2016-01-28 19:41:42
[QUOTE=Doingitsideways;795754]Classicswede's been busy then :)[/QUOTE] Yep he has but forgot to send me the panhard bushes
Post 802283 by t5 pete on 2016-06-20 19:33:26
Thought it time to revive this thread Image Image
Post 802284 by t5 pete on 2016-06-20 19:35:32
Post 802285 by t5 pete on 2016-06-20 19:37:39
Post 802286 by t5 pete on 2016-06-20 19:40:31
Image Image Image Image Image Image Image Image Image
Post 802287 by t5 pete on 2016-06-20 19:44:48
Image Image Image Image Image Image Image Image Image Image Image Image Image Image
Post 802289 by t5 pete on 2016-06-20 20:00:51
Post 802290 by t5 pete on 2016-06-20 20:02:32
Post 802291 by martin_r_smith on 2016-06-20 20:25:58
Wow, not messing about are you Pete! Looking awesome mate, can't wait to see it finished.
Post 802293 by Doingitsideways on 2016-06-20 20:36:45
Epic photodump! I'm on my mobile data, you b@stard!!
Post 802303 by Jamest5r on 2016-06-20 21:50:47
Still can't remember my parts though can ya :)
Post 802308 by t5 pete on 2016-06-20 22:04:45
[QUOTE=Jamest5r;802303]Still can't remember my parts though can ya :)[/QUOTE] You're imput is as useful as ever pal
Post 802313 by Jamest5r on 2016-06-20 22:31:04
As always wouldn't want to disappoint you :)
Post 802323 by MoleT-5R on 2016-06-21 11:31:29
Nice update Pete and quality work as always, it will be a stunner when done
Post 803257 by barkster1971 on 2016-07-21 19:51:23
clutch plate details please.
Post 805819 by t5 pete on 2016-09-28 22:20:45
A little more progress now onto the other manifold Image Image
Post 805821 by Doingitsideways on 2016-09-28 22:44:32
Still a shed :lol:
Post 805822 by Ettienne on 2016-09-28 22:53:24
Looking good as always, looks like most of the big stuff is done now. My friend will possibly be selling his 16v engine shortly if your in need of spares.
Post 805823 by t5 pete on 2016-09-28 22:57:13
[QUOTE=Ettienne;805822]Looking good as always, looks like most of the big stuff is done now. My friend will possibly be selling his 16v engine shortly if your in need of spares.[/QUOTE] Cheers for the heads up but all ready got a spare 16v head so fingers crossed u shouldnt need any more
