sqealing motor
Post 57464 by fireclown on 2005-11-16 01:18:39
hi all. my heater motor has started squealing. v annoying. is it an east job or do i have to rave out half the dash. appreciations in advance. :remybussi
Post 57723 by vt5 on 2005-11-16 21:31:48
The bearings have gone dry. You need to pull out the motor and lub it. Dont know how much of a ball ache it is though.
Post 57739 by Al115 on 2005-11-16 22:34:05
Easy-ish. Glovebox out, unbolt the motor which is behind it (big black circular item), unplug the connector, remove it. Lubing it is a challenge though (how to get to the bearings...)
Post 57762 by fireclown on 2005-11-17 00:06:35
thanks for the replys. might be a case of a small drill bit and some duck oil i reck. thanx again
