855 T5 manual issues
Post 730850 by prc on 2014-08-21 17:39:37
As i mentioned in my intro thread there are 1 or 2 issues i'll need to address on the T5. Thought i'd post some here and pick the collective brain of you guys! The car strikes me as having been very well cared for until a few years ago then used and abused a bit. A few of the modifications such as exhaust are very poorly done and i'm working through a list of jobs to do. The car has a Rica remap, homebrew decat exhaust (JDMYO gay backbox), cheapo cone filter, mbc and a dump valve. I don't know what the mbc is there for as surely the remap handles boost? Also i'm getting what feels like fuel cut when in higher gears on full throttle. Obviously boost is lower in 1st and 2nd gear so it doesn't happen then. Has a gauge fitted and seems to be hitting about 12-13psi but difficult to watch it, might be spiking. Standard turbo gauge goes to about 1mm off the end of the white. Image Seems legit and is a lot faster than a standard T5. No invoice in history however. Image This is the mbc. Just not sure the need for it. Also does anyone know what this is? Was found down behind the battery??? Image Cheers in advance folks!!!
Post 730853 by Nealevo on 2014-08-21 18:02:27
The bottom pic is BCS (boost control solenoid) take the pipes off the MBC and throw it in the bin, reconnect the vac lines to BCS and your engine will last a bit longer :)
Post 730854 by martin_r_smith on 2014-08-21 18:03:00
That is the standard boost control solenoid. The map can't regulate boost without that!
Post 730855 by martin_r_smith on 2014-08-21 18:03:33
Beaten to it!
Post 730856 by claymore on 2014-08-21 18:06:06
I still prefer a map and mbc :)
Post 730857 by stribo on 2014-08-21 18:38:37
[QUOTE=claymore;730856]I still prefer a map and mbc :)[/QUOTE] I prefer a map and a bleed valve.;)
Post 730861 by T5frankie on 2014-08-21 18:47:58
The reason for the mbc over remap is so you get full boost in every gear unlike restricted in 1St two with the map, not really a good idea though as others will tell you
Post 730864 by p fandango on 2014-08-21 19:14:30
[QUOTE=T5frankie;730861]not really a good idea though as others will tell you[/QUOTE] its perfectly fine as long as you don't go silly
Post 730865 by T5frankie on 2014-08-21 19:16:42
[QUOTE=p fandango;730864]its perfectly fine as long as you don't go silly[/QUOTE] I can't stand 1St and 2nd gears feels like there's no power with just a map
Post 730867 by p fandango on 2014-08-21 19:20:23
[QUOTE=T5frankie;730865]I can't stand 1St and 2nd gears feels like there's no power with just a map[/QUOTE] i swear by mbc's. I was disagreeing that they can't be used with a map, you just have to be carefull
Post 730873 by Jamest5r on 2014-08-21 20:18:12
I love my mbc :)
Post 730909 by prc on 2014-08-21 22:36:26
I guess the best bet is to plumb back in the bcs and see how it runs. Anyone know what kind of boost i should expect roughly with a Rica map? All the hoses are tired so will replace them bit by bit as i go along This is horrendous too: Image
Post 730913 by t5 pete on 2014-08-21 22:37:27
normally a rica 304 you will see around 16psi
Post 730929 by prc on 2014-08-21 23:54:14
I'm not getting 16psi. I'll take someone with me on a run tomo and see what it says. Anyone know the fuel cut level with the Rica map?
Post 730932 by prc on 2014-08-22 00:14:20
Which pipes go where on the bcs also? Does it fit in where the mbc is just now?
Post 730933 by t5 pete on 2014-08-22 00:14:21
There shouldn't be fuel cut is it a violent cut of stuttering when on full boost in the higher gears if its the latter most likely the plugs also before doing any more hard runs do a good stage 0 service
Post 730958 by prc on 2014-08-22 09:04:14
I'm going today to buy the stuff to service over the weekend. It's like a stuttering that you can drive through if that makes sense. I've had fuel cut on imprezas before and it is more violent that what i'm getting. Uprated plugs a must then? Going to try locate a standard airbox too. At the power i'm running i'm sure it will be fine.
Post 730966 by t5 pete on 2014-08-22 10:02:23
Yep sounds like a break down of the ignition system always use genuine volvo plugs
Post 730970 by T5frankie on 2014-08-22 10:15:49
my car is stuttering too, the reason: cos i put 95 ron in the tank
Post 730987 by Hotz on 2014-08-22 12:56:43
Hello, I do not understand much of Acronym posted here and not much of some translated words (this trans drive me crazy .. lol). But I always good to check the fuel injectors relative to its sealing and flow can be great variations which leave the rich mixture. For the ignition system (cables plugs) spray water always shows leakage along the path of the cables. Hope I'm not talking nonsense and within the contest.
Post 731085 by Unknown on 2014-08-23 07:59:23
Had a MBC fitted to both of my cars 854 and 855 guls! And never ever had any problems or issues what so ever just make sure you don't over boost :D
Post 731088 by Ettienne on 2014-08-23 08:19:41
[QUOTE=prc;730932]Which pipes go where on the bcs also? Does it fit in where the mbc is just now?[/QUOTE] Iirc With the BCS fitted back on the air box,top pipe goes to the re circ, middle to the air intake and bottom to the compressor housing. 4mm silicon 2m of will replace it and costs not much. The boost can also be held back by the mbc, this could be a problem also the original BCS usually die around 100k so v70r etc me7 ones are good replacements.
Post 731089 by oblark on 2014-08-23 08:48:56
You want to early v70 bcs not the me7 tcv. just remember what mbc stands for M - may B - bend C - conrod
Post 731108 by prc on 2014-08-23 12:59:40
[QUOTE=oblark;731089]You want to early v70 bcs not the me7 tcv. just remember what mbc stands for M - may B - bend C - conrod[/QUOTE] Haha i like that! Well i took your advice on plugs. Our local Volvo dealer isn't helpful. So i went to the factors and i got a set of NGK Iridium plugs. Home, fitted, test run, sorted. Has stopped the stuttering and is pulling nice and smooth. Very pleased! So next onto boost. It was going to around 13psi and tailing back to 10psi so first thing done was remove the dump valve and plug it. It doesn't drop back as quick now so there is slight improvement. However it does still tail off. The mbc isn't the best. Fittings are damaged slightly so i will need to go, my mate has a new one i'll fit just now. In the process of ordering some piping to replace the worn cut standard stuff. Then i can plumb in bcs. Cheers for the info on where the pipes go. Tbh if i was careful and kept the mbc at 16psi there is no real need for bcs other than i hate seeing a mbc in my engine bay!
Post 731114 by t5_jim on 2014-08-23 14:56:21
would 16psi not cause boost cut?
Post 731115 by prc on 2014-08-23 15:20:28
[QUOTE=t5_jim;731114]would 16psi not cause boost cut?[/QUOTE] It has a rica map
Post 731118 by claymore on 2014-08-23 16:01:30
i run my remaped T-5R with an MBC at 22psi.
Post 731120 by t5_jim on 2014-08-23 16:31:32
clearly i didnt read the full post and appologise for being a dumbass.....:slap:
Post 731121 by Nealevo on 2014-08-23 16:31:49
[QUOTE=claymore;731118]i run my remaped T-5R with an MBC at 22psi.[/QUOTE] and i will remind you if Robs post above M - may B - bend C - conrods o yeah you did lol
Post 731123 by prc on 2014-08-23 16:43:53
To be honest it's fast just now so if i get it it holding a nice steady 16psi i think i'll be a happy chappy. Just been another run and it is a lot better without the bov. Throttle response better and smoother. At what stage does the recirc valve need to be uprated? Seen the Forge one is readily available. Been in today to see my mate who owns a custom exhaust place, going for a 2.5" turbo back system. Open downpipe obviously too so i'd imagine that'll help things move a bit quicker. £45 on plugs and a couple hrs tinkering and i'm very pleased with improvement. Also forgot to mention i filled it with Tesco 99ron fuel so that may have helped too
Post 731126 by claymore on 2014-08-23 17:02:37
[QUOTE=Nealevo;731121]and i will remind you if Robs post above M - may B - bend C - conrods o yeah you did lol[/QUOTE] Na, just a noisy tappet mate :)
Post 731130 by stribo on 2014-08-23 17:48:10
[QUOTE=claymore;731126]Na, just a noisy tappet mate :)[/QUOTE] Haha, that's what Frankie says. ;)
Post 731289 by prc on 2014-08-25 10:00:44
Just going to order a new mbc, any recommendations???
Post 731294 by Biff on 2014-08-25 11:09:19
Most use forge unos mate.
Post 731299 by prc on 2014-08-25 12:25:12
Any benefit in buying a decent ebc? A mate of mine has a HKS one he's never fitted. I remember having one similar fitted on a Rover 620ti years ago (another totally under rated turbocharged barge!)
Post 731302 by claymore on 2014-08-25 12:49:07
I've got a Greddy one, I could never get it to work nice.
Post 731309 by prc on 2014-08-25 14:33:09
[QUOTE=claymore;731302]I've got a Greddy one, I could never get it to work nice.[/QUOTE] In what way?
Post 731310 by p fandango on 2014-08-25 14:43:35
[QUOTE=prc;731299]Any benefit in buying a decent ebc? A mate of mine has a HKS one he's never fitted. I remember having one similar fitted on a Rover 620ti years ago (another totally under rated turbocharged barge!)[/QUOTE] i've got an Apexi AVC-R, & i prefer a normal mbc. I can't get the Apexi to be as aggressive an mbc
Post 731311 by claymore on 2014-08-25 15:18:26
[QUOTE=prc;731309]In what way?[/QUOTE] When it reached the boost level set, it would pulse the boost on and off.
Post 731318 by prc on 2014-08-25 17:00:27
Hmmm i'll save a few pennies and stick with a mbc. Are there any other common places for them to leak pressure? Really appreciate all the help and info so far.
Post 732383 by prc on 2014-08-30 12:40:10
Righto, update time. After changing the plugs it solved the stuttering. Discovered mbc was leaking so got me a new one. Got a Turbosmart Boost Tee. Image Fitted this morning and gradually increased it until i was getting 16psi. However in lower gears the stuttering is back when on fuel throttle. Not all the time but most of the time. I decided to have a look in the ecu to check it actually has a rica chip and i think it does, can anyone confirm by looking at the pics...... Image Image I've ordered a standard airbox and panel filter too. That ebay cone thing won't be helping anything flopping about in there. I'm not chasing numbers or anything for that matter i just want my car running right!
Post 732969 by prc on 2014-09-02 09:56:15
Anyone able to confirm if the ecu is standard or not? Looks like one of the chips on the left isn't standard.
