clocks
Post 727531 by moosepowerlee on 2014-08-02 18:26:59
LOoking at some r design clocks from a 2007 v50 for my 2005 model are they plug and play or do i need em prog as with most Stuff if so anyone in sensible area to me that could do it
Post 727635 by M-R-P on 2014-08-03 11:16:29
I know HLM used to reprogram P2 clocks but I don't know what the focus derived cars are like. I doubt they're just plug n play tho.
Post 727636 by jamesy12345 on 2014-08-03 11:36:44
Good info didn't know that I need an mph speedo for the S60R & a cunning plan.....
Post 727638 by volvokid on 2014-08-03 12:30:54
It will need programmed, everything down to your window switches need programmed
Post 727723 by moosepowerlee on 2014-08-03 21:27:42
Thought as much think i will leave them seeing as Might be changing soon thanks for advice
Post 727793 by M-R-P on 2014-08-04 08:27:55
There's the option of just changing the dial faces and trims..?
Post 727807 by jamesy12345 on 2014-08-04 10:36:03
[QUOTE=M-R-P;727793]There's the option of just changing the dial faces and trims..?[/QUOTE] Sounds good to me, anyone tried it or have a link
Post 727813 by stribo on 2014-08-04 10:48:48
[QUOTE=M-R-P;727793]There's the option of just changing the dial faces and trims..?[/QUOTE] [QUOTE=jamesy12345;727807]Sounds good to me, anyone tried it or have a link[/QUOTE] The problem with doing that with the S60R dials is the standard dials are backlit, whereas the R dials are front lit, so you'all need some way of lighting them up.
Post 727815 by jamesy12345 on 2014-08-04 11:04:15
[QUOTE=stribo;727813]The problem with doing that with the S60R dials is the standard dials are backlit, whereas the R dials are front lit, so you'all need some way of lighting them up.[/QUOTE] I am interested in swapping kph dials to mph, so between 2 Rs
Post 727816 by M-R-P on 2014-08-04 11:07:51
[QUOTE=jamesy12345;727815]I am interested in swapping kph dials to mph, so between 2 Rs[/QUOTE] Afaik, the clocks on the focus derived cars only differ in dial and trim. The actual dim is the same.
