Post 725893 by Wobbly Dave on 2014-07-24 23:58:41
I thought that the ETM shenanigans experience recently, was part and parcel of having a stupid big turbo and various other none-standard bits on my engine.
I actually believe its now the ETM itself.
So which is better - 2nd hand http://www.ebay.co.uk/itm/VOLVO-S60-S80-V70-S70-C70-THROTTLE-BODY-ELECTRONIC-THROTTLE-MODULE-P-Nr-8644347-/281388367779?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item41840dbfa3
refurb?? - If so which firm?
Or brand new?
Post 725895 by Kingsford G on 2014-07-25 00:23:41
Get it refurbed with a 2 years warranty
Post 725899 by M-R-P on 2014-07-25 06:13:51
If it's not Bosch then new or refurbed mate.
Post 725919 by Wobbly Dave on 2014-07-25 10:23:41
No its the italian job - Magnetti Marelli a la conchille pomodoro - but can't complain after it has gone this long. It was replaced under warranty 7 years ago, when I first bought Betsy!
Post 725921 by M-R-P on 2014-07-25 10:37:29
Shame. The Bosch ones either work or they don't - no buggering about for a month stalling etc. And they're plug n play too, as I found out a few months back... Is having an S60R throttle bragging rights? as long as nobody you're bragging to knows that it's the same throttle as a T5 one, I spose it is lol.
Post 725926 by partsforvolvos.com on 2014-07-25 10:57:18
imo you cannot fit a second hand part.
because it is coded by software when replaced, a secondhand part would work initially because it is coded to the previous car but as soon as you try to do any download or upgrade to any unit on the network, it will mismatch and cause all sorts of problems.
if you had discarded the old part it that instance, you would be in big trouble.
the way to get out of it is to refit the old part, and perform the smallest piece of software download.
if have never looked in detail at the refurb ones - do the company wipe them somehow so you can code them in? the problem of the 'mismatch' is the part serial number and part number of each module is checked against the car file before it actually starts the download itself.
if your car never ever goes back to Volvo needing a download you'll be ok, but you cant guarantee that especially if you owned a p2 where it even includes door switches.
hope this helps to know if you didn't already dave .
Post 725927 by M-R-P on 2014-07-25 11:17:08
Refurbing the old one retains the pcb but converts the potentiometer to a contactless version. Negating the need for a recode.
Post 725944 by Wobbly Dave on 2014-07-25 13:00:17
I think then I will throw it upto these people
http://volvodiagnostic.com/shop/index.php?id_product=18&controller=product
Post 725945 by M-R-P on 2014-07-25 13:39:45
[QUOTE=Wobbly Dave;725944]I think then I will throw it upto these people
http://volvodiagnostic.com/shop/index.php?id_product=18&controller=product[/QUOTE]
Yep - they've got a very good reputation on VOC mate.
Post 725948 by deathrider311271 on 2014-07-25 13:59:50
[QUOTE=partsforvolvos.com;725926][SIZE=5]imo you cannot fit a second hand part.[/SIZE] wrong
[SIZE=5]because it is coded by software when replaced, a secondhand part would work initially because it is coded to the previous car but as soon as you try to do any download or upgrade to any unit on the network, it will mismatch and cause all sorts of problems. [/SIZE] wrong again
hope this helps to know if you didn't already dave .[/QUOTE]
This mis information really pisses me off, have you actually tried it?? i have.
Dave ignore this wrong information, if you want to use a second hand unit you can with no issues, just make sure its off a turbo model and same year car as yours. Im assuming yours is the white sticker model??
If so once you have fitted the second hand ETM take your car to Volvo to get the 50p software upgrade for the wider peramiters (delaying the problem). Will also cost you half hours labour.
Alternatively go onto VOC and contact a guy called SPOZNIK he will rebuild yours with contactless potentiometeres for under £140, i personally wouldnt use the more expensive companies as they do exactly the same as this guy.
Post 725950 by M-R-P on 2014-07-25 14:27:35
I thought Spoznik was Volvodiagnostic?
Post 725952 by JamesT5 on 2014-07-25 14:29:18
Personally Dave, I'd get a second hand unit and put it on. They don't need a re-code because I've tried different ETM's on my T5 off other T5's and it ran fine.
Post 725960 by Wobbly Dave on 2014-07-25 15:10:50
[QUOTE=M-R-P;725950]I thought Spoznik was Volvodiagnostic?[/QUOTE]
Me too - that's why I've already paid for it, so it's a done deal now. Going for the contactless Pot solution for peace of mind.
Post 725976 by deathrider311271 on 2014-07-25 16:29:22
it is bud i couldnt remember his business name lol
Wise choice Dave
Post 726110 by Wobbly Dave on 2014-07-26 12:15:37
Took the old spic ETM off last night and sent it this morning to Volvo Diagnostic.
Post 741902 by Pliskin on 2014-10-13 11:01:13
[QUOTE=Wobbly Dave;726110]Took the old spic ETM off last night and sent it this morning to Volvo Diagnostic.[/QUOTE]
Is it much of a job to take it off, my Sept 99 V70 petrol auto (140 none turbo) is exhibiting all the signs described on the company's website.
I don't want to pay my local garage a diagnostic fee if I can do it myself.
Post 741904 by JamesT5 on 2014-10-13 11:02:59
[QUOTE=Wobbly Dave;725893]I thought that the ETM shenanigans experience recently, was part and parcel of having a stupid big turbo and various other none-standard bits on my engine.
Or brand new?[/QUOTE]
The Main Dealer Parts gut told me the other day, that the new ETM's are about £220 + VAT although they may have gone up a little.
Post 741905 by M-R-P on 2014-10-13 11:09:35
[QUOTE=Pliskin;741902]Is it much of a job to take it off, my Sept 99 V70 petrol auto (140 none turbo) is exhibiting all the signs described on the company's website.
I don't want to pay my local garage a diagnostic fee if I can do it myself.[/QUOTE]
Yours "should" have the same inlet manifold as the 850 - meaning the ETM is on the side of the manifold rather than under it. This is pretty easy to get at, you'll need to take the inlet pipe off the throttle and you're there.
Post 741906 by M-R-P on 2014-10-13 11:10:50
[QUOTE=JamesT5;741904]The Main Dealer Parts gut told me the other day, that the new ETM's are about £220 + VAT although they may have gone up a little.[/QUOTE]
Hasn't anybody worked out how to get the Bosch ones to work yet?
That would save so many cars from the scrapper.
Post 741912 by Wobbly Dave on 2014-10-13 12:03:19
Access is the main issue.
I took my rad cowling off to make it easier to get at. It is just 4 bolts, the intercooler pipework jubilee and 1 electrical connector. Mine has RIP pipework fitted - on OEM you'll have to remove the MAP & temp sensors from the stock pipe and disconnect it from the FMIC and the main intake into the ETM itself. As Martin said yours should not be too hard.
Bolts hang upside down on the T5 & the electrical connector sits on a metal plate where the main loom transverses the front spar of the subframe. (quite close to the starter motor).
Post 741938 by JamesT5 on 2014-10-13 14:44:10
[QUOTE=deathrider311271;725948]This mis information really pisses me off, have you actually tried it?? i have.
Alternatively go onto VOC and contact a guy called SPOZNIK he will rebuild yours with contactless potentiometeres for under £140, i personally wouldnt use the more expensive companies as they do exactly the same as this guy.[/QUOTE]
Yes, I inquired about the software upgrade and was amused that it was only 50 pence. It's stupid that the cost is really nominal, it's the labour to do it.
I'm going to have a software upgrade on my ETM, assuming it's not faulty.
Have you had this or know anyone who has? What difference does it make to the performance/behavior of the car?
Post 741939 by Ettienne on 2014-10-13 14:52:38
I have a nice receipt when my p2 had one 18k ago, £400-500 I think it was fitted (bosch)
Post 741940 by Pliskin on 2014-10-13 14:59:41
[QUOTE=M-R-P;741905]Yours "should" have the same inlet manifold as the 850 - meaning the ETM is on the side of the manifold rather than under it. This is pretty easy to get at, you'll need to take the inlet pipe off the throttle and you're there.[/QUOTE]
Thanks M-R-P
Post 741941 by JamesT5 on 2014-10-13 15:17:20
[QUOTE=Ettienne;741939]I have a nice receipt when my p2 had one 18k ago, £400-500 I think it was fitted (bosch)[/QUOTE]
That was with labour I guess.
