S60 2.4
Post 722131 by zoidberg on 2014-07-02 23:47:12
Well bought a cheap S60 2.4 on a 03 plate, and on looking through the booklets there are apparently 3 different power engines, 140,170,200 bhp. So how do I tell which one I have got ??? It has factory fit LPG (reason I bought it !) if that makes a difference !:wave23d:
Post 722146 by jamesy12345 on 2014-07-03 05:35:35
Here's a vin number explanation http://www.volvoclub.org.uk/vin_60.shtml With that you should be able to identify the engine code....if it hasn't got a turbo I would discount the 200 hp...!
Post 722258 by zoidberg on 2014-07-04 01:19:27
By looking through your link..... it appears (if I've read it correctly ) that I have the B5244SG2 engine ...........which is 140 bhp ! :shhh:
Post 722274 by jamesy12345 on 2014-07-04 08:16:27
[QUOTE=zoidberg;722258]By looking through your link..... it appears (if I've read it correctly ) that I have the B5244SG2 engine ...........which is 140 bhp ! :shhh:[/QUOTE] sorry to be the bearer of bad news! I can't see any 170 hp versions of the 2.4, only in the S80 AFAIK....maybe it's worth looking into that to see what is the difference?? Just a thought http://www.parkers.co.uk/cars/reviews/facts-and-figures/volvo/s60/saloon-2000/
Post 722283 by zoidberg on 2014-07-04 08:51:53
IT says their is a 170bhp version in the owners hand book that came with it. Just looked again, says the engine code is B5244S and the 140 bhp version has an engine code of B5244S2 and 200bhp one is B5244T3.
Post 722285 by M-R-P on 2014-07-04 08:54:33
Engine code will be on a white sticker, on the side of the timing belt cover, facing the o/s strut tower.
Post 722291 by jamesy12345 on 2014-07-04 09:06:05
also, the VIN should be on the dashboard on the passenger side (visible through the windscreen from outside the car). If it had a B5244S engine the vin would start with YV1RU61....
Post 722295 by stephenevans99 on 2014-07-04 09:39:40
Stick an R badge on.....no-one will be the wiser ;)
Post 722305 by partsforvolvos.com on 2014-07-04 10:13:51
its the other way around b5244s is 170bhp, s2 is the 140bhp . reduced as a way of meeting emissions standards ........ I am pretty sure a bi fuel is 140 anyway.- yep the pocket data book confirms it- 140bhp as bi fuel sg or sg2 engines. here you go - an sg is for cng, and sg2 is for lpg on the bi fuels.
Post 722306 by partsforvolvos.com on 2014-07-04 10:15:25
there is a tiny element filter (looks like a thumbnail sized k&n filter) in the side of the fuel guvenor unit on those. this must be changed at the same time as the obvious in line metal gas filter but often people miss them and they gum up .
Post 722487 by zoidberg on 2014-07-05 00:30:45
Ahhh, that might explain why today (well yesterday ) the thing cut out on me on 3 different occasions, then restarted for no reason later.........................that is on gas, petrol was fine.
