Another what is this question?
Post 718656 by handyandyrta on 2014-06-12 23:29:24
Can anyone tell me what this part of the turbo is and what it does? Pic below.... [ATTACH=CONFIG]25525[/ATTACH]
Post 718657 by p fandango on 2014-06-12 23:30:32
thats the recirc valve, works a bit like a dump valve
Post 718658 by handyandyrta on 2014-06-12 23:36:54
Ah right........... Then begs the question, if I was to want to fit a dump valve instead could this be blanked off so that the dump valve worked to full effect?
Post 718659 by stribo on 2014-06-12 23:47:51
[QUOTE=handyandyrta;718658]Ah right........... Then begs the question, if I was to want to fit a dump valve instead could this be blanked off so that the dump valve worked to full effect?[/QUOTE] Yes, you just need a blanking plate to replace the recirc valve.
Post 718660 by p fandango on 2014-06-12 23:48:24
[QUOTE=handyandyrta;718658]Ah right........... Then begs the question, if I was to want to fit a dump valve instead could this be blanked off so that the dump valve worked to full effect?[/QUOTE] it can LINK Image
Post 718662 by handyandyrta on 2014-06-13 00:15:23
Cheers guys :B_thumb:
Post 718671 by M-R-P on 2014-06-13 07:23:31
Much easier to stick a one-way valve in the hose that operates the recirc ;)
