Post 717296 by deathrider311271 on 2014-06-06 20:37:07
i have aquired one of these, now there seems to be quite a lot of side to side movement but no movement up and down if that makes sense, is this normal with no oil?? it was sold to me as a good turbo, if the worst comes to the worst i will get it hybridized realistically what are these capable of?
cheers
Post 717300 by Jamest5r on 2014-06-06 20:55:56
[QUOTE=deathrider311271;717296]i have aquired one of these, now there seems to be quite a lot of side to side movement but no movement up and down if that makes sense, is this normal with no oil?? it was sold to me as a good turbo, if the worst comes to the worst i will get it hybridized realistically what are these capable of?
Does it move in and out as if your pushing the float if you get what I mean
Post 717301 by deathrider311271 on 2014-06-06 20:58:53
[QUOTE=Jamest5r;717300][QUOTE=deathrider311271;717296]i have aquired one of these, now there seems to be quite a lot of side to side movement but no movement up and down if that makes sense, is this normal with no oil?? it was sold to me as a good turbo, if the worst comes to the worst i will get it hybridized realistically what are these capable of?
Does it move in and out as if your pushing the float if you get what I mean[/QUOTE]
yes james it only probably moves 1mm max but i dont remember my 16T moving that much lol
Post 717304 by Jamest5r on 2014-06-06 21:07:29
[QUOTE=deathrider311271;717301][QUOTE=Jamest5r;717300]
yes james it only probably moves 1mm max but i dont remember my 16T moving that much lol[/QUOTE]
Hard one to call, i've had 2 18's and both times I just paid to have them rebuilt, i reckon the best way is to buy a.knackered one for 40 quid then pay 350 odd to have it rebuilt, least you know it's sorted then but all depends on your build criteria..... no offence meant and i dont mean you but some people throw "performance " bits at a car turn the boost up and expect it to be reliable day in day out then wonder why it isn't lol,
Post 717306 by munster732 on 2014-06-06 21:18:25
My original 18T was the same, ran perfect no smoke or noise but on removal it had a lot of play when moved side to side.
Post 717308 by mike 850 on 2014-06-06 21:19:40
A little up and down is ok, oil will fill the space, in and out isn't. Very easy to rebuild yourself if your confident enough
Post 717411 by deathrider311271 on 2014-06-07 12:35:29
had the car in for its mot today and it flew thro no problem, he also rebuilds standard turbo's so got him to give it the once over and he has confirmed way too much movement so as and when funds permit i will get it hybridized at least that way i know it will be right from day 1 lol
Post 717412 by 960kg on 2014-06-07 13:10:55
Hi Simon,
Remember the 18T i bought off someone on here ( i think originally came from Jamest5r via his friend ) and it had only done about 7,000mls after a refurb ........well when i received it i went onto a website (can`t remember which one) and it gave tolerances for these turbos.
Yes, they seem to move a lot on the hot side wheel but if you can get a 15 thou feeler guage down between the wheel and the side of the housing then this is perfect i believe the tolerance was between 14 and 16 thou when new.
Mine was a tight 15 with no up and down movement.
No smoke on idle or on boost and really howls on 21psi.........completely different sound to the ordinary 16T.
Keith
Post 717413 by Nealevo on 2014-06-07 13:12:31
I run a 18t, had it rebuilt just incase as i had a little play in shaft, with supporting mods it ran 314bhp at 18psi, i run 20psi now so maybe a little more oomph.
Post 717417 by T5frankie on 2014-06-07 13:32:18
[QUOTE=Nealevo;717413]I run a 18t, had it rebuilt just incase as i had a little play in shaft, with supporting mods it ran 314bhp at 18psi, i run 20psi now so maybe a little more oomph.[/QUOTE]
on that dyno neal, wasnt at uxbridge
Post 717421 by t5 pete on 2014-06-07 13:46:42
At aem day when I still had the green one and 18t that made just short of 300bhp at about 14/15psi
Post 717459 by Nealevo on 2014-06-07 20:06:02
[QUOTE=T5frankie;717417]on that dyno neal, wasnt at uxbridge[/QUOTE]
no mate, HLM proper dyno.
Post 717462 by T5frankie on 2014-06-07 20:12:11
[QUOTE=Nealevo;717459]no mate, HLM proper dyno.[/QUOTE]
lol i suppose the other one (the famous one) would have been the proper one if it produced higher figures lol
Post 717470 by Nealevo on 2014-06-07 21:10:43
[QUOTE=T5frankie;717462]lol i suppose the other one (the famous one) would have been the proper one if it produced higher figures lol[/QUOTE]
well there is no point in putting the lower figure, if i wanted i could have just used the dodgey conversion chart and had more, but 12 runs between 311 & 314 seemed the better approach
Post 717487 by Jamest5r on 2014-06-07 23:29:32
On.a maha I've got to be well over 400bhp pmsl :)
Post 717499 by T5frankie on 2014-06-08 07:12:25
[QUOTE=Nealevo;717470]well there is no point in putting the lower figure, if i wanted i could have just used the dodgey conversion chart and had more, but 12 runs between 311 & 314 seemed the better approach[/QUOTE]
only pulling your pisser mate
Post 717500 by T5frankie on 2014-06-08 07:13:04
[QUOTE=Jamest5r;717487]On.a maha I've got to be well over 400bhp pmsl :)[/QUOTE]
dunno how you work that out i got 298bhp on my old 18t at 18psi on a maha
