850 speaker change query
Post 717191 by woz on 2014-06-05 22:56:40
A little bit of advice needed if anyone can help? I changed my two dash "tweeter" speakers which were pretty shot. Got a pair off the web someone on here reommended. So they were listed for teh 850 but not a direct fit - some minor mods needed. Question is... When I changed them , I wasn't sure whether to keep the capacitor which was in series with the speaker on the outgoing Volvo one, or bin it? In the intrestes of safety I kept it in although it meant unsolder and re-solder rather than just a plug in job. I figured it must be there to stop a DC current going through the power amp circuits or something. Any thoughts?? Would I get a better sound if I took it out and would I kill my stereo? (based on Experience please not surmisements - i can do that myself:>)) Cheers WOZ p.s its a 96 855 GLT with a Volvo CD/cassette radio SC805 I think, if that makes a difference.
Post 717201 by p fandango on 2014-06-06 06:27:48
the capacity works as a frequency blocker, it stops the tweeter trying to do frequencies out of its efficiency range (ie mid-range & bass) & creating distortion
Post 717263 by woz on 2014-06-06 17:24:24
Thanks PF - so I leave it in right?
Post 717264 by p fandango on 2014-06-06 17:36:20
[QUOTE=woz;717263]Thanks PF - so I leave it in right?[/QUOTE] The new tweeters should have there own capacitor on them anyway, inless part of a component set that includes an external cross-over. Having a second one on won't hurt as you've done it, but you could of just used the normal speaker wires directly
Post 717445 by woz on 2014-06-07 19:01:11
[QUOTE=p fandango;717264]The new tweeters should have there own capacitor on them anyway, inless part of a component set that includes an external cross-over. Having a second one on won't hurt as you've done it, but you could of just used the normal speaker wires directly[/QUOTE] OK - I will take it out and see what happens. Pretty sure there is no capacitor in the new ones. I suppose I could just ring the vendor.... Will update when i have done it - thanks for your input:>)))
Post 740880 by Theador on 2014-10-08 23:08:08
I'd leave the cap on of you can't see one on the tweeters you bought. They're usually fairly visible if they're there. In my past experience with ice. A set of tweeters bought on their own would be shipped with an off-board cap so you had the option of using it or not, depending on whether you had active crossovers, or other passive ceossovers already installed. If however you do have a capacitor in your tweeter. Adding another one will change the value at which frequencies are cut. I'm afraid I can't remember the equations for working out the frequency ranges. [QUOTE=woz;717445]OK - I will take it out and see what happens. Pretty sure there is no capacitor in the new ones. I suppose I could just ring the vendor.... Will update when i have done it - thanks for your input:>)))[/QUOTE]
Post 741080 by craigoodwood on 2014-10-09 19:53:18
the cap is there for a reason, if you did away with it it wouldn't be a tweeter it would just be a tiny speaker getting all sound frequencies though it :)
