53 Plate S60 D5 - Won't start
Post 716351 by edde on 2014-06-02 14:38:34
Well this is rather typical, within days of getting the new car and spending hours cleaning it up the sod doesn't want to start! Symptoms are; - Clock at --.-- - When turning ignition it sounds like the central locking is engaging and disengaging all around - What can best be described as clicking coming from behind the steering wheel I'm taking a stab in the dark that the battery is perhaps low on charge, other than that I am stumped. The car does also tell me that the 'Alarm System Requires A Service', from what I've googled I required a new siren alarm kit from Rufa (i think) as the battery may have perished in the siren. However, I'm not sure if this is related or not. All help appreciated, as I'm well and truly stuck ;(
Post 716352 by M-R-P on 2014-06-02 14:43:09
Yep - dead battery mate. Mine does the same when I have the stereo going too long.
Post 716353 by edde on 2014-06-02 15:02:09
good to know, i was getting a bit worried that it was something more sinister. now this is a completely embarrassing question that will result in a severe loss of man points... where the feck is the battery? I popped the bonnet to find a whole host of plastic covers and trays and for the life of me could only find a positive terminal behind the fuse box.
Post 716372 by bjpub on 2014-06-02 15:57:36
It's in the boot :funkybana
Post 716373 by M-R-P on 2014-06-02 16:02:22
[QUOTE=edde;716353]good to know, i was getting a bit worried that it was something more sinister. now this is a completely embarrassing question that will result in a severe loss of man points... where the feck is the battery? I popped the bonnet to find a whole host of plastic covers and trays and for the life of me could only find a positive terminal behind the fuse box.[/QUOTE] It's in the boot mate, nearside, under the carpet. If it's just a trickle charger you have, stick it on for an hour and you should be fine.
Post 716376 by edde on 2014-06-02 16:12:25
silly swedes lol cheers lads
Post 716474 by Plodmonkey on 2014-06-02 20:30:31
Not going to lie I asked my friend the same question on my rather broken V70
Post 716483 by Harvey on 2014-06-02 20:44:08
[QUOTE=edde;716376]silly swedes lol cheers lads[/QUOTE] No not silly just keeps it warm in the winter & doesn't get cooked from the engines heat,and their not to much room under the bonnet.
