Post 716304 by dingbat29 on 2014-06-02 08:34:16
Hi everyone,
My V50 (2009), and I can only presume the S40 is the same, has 2 captive nuts in the boot for the number plate. So naturally, I would expect the nylon yellow/black/white or blue numberplate fixings would fit. . . No, not a chance! Does anyong know what size the are, and if you can infact get different size nylon fixings?
dingbat29
Post 716312 by AAnickmac on 2014-06-02 09:23:52
My 2006 S40 had the number plates riveted on. Have you tried the main dealers?
Post 716313 by M-R-P on 2014-06-02 09:28:12
Yep - I riveted a few plates recently. Permanent and really hard to remove :D
Post 750154 by Cantankerous One on 2014-11-30 20:26:39
I bought these and just used the bolts as the thread matches that of the captive nuts:
http://www.ebay.co.uk/itm/60-Pcs-MIXED-NUMBER-PLATE-BOLTS-NUTS-CAPS-SCREWS-FITTING-FIX-/200941577657?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2ec90d25b9
I did cut them short as if you don't they have a tendency to stick part way in, twist and snap. I also sprayed them with WD40 before screwing them in.
