Volvo c70 cruise control light
Post 712602 by MaxiSNK on 2014-05-18 08:54:32
Hey guys been a member in here years ago owned a blue Volvo c70 and then a black c70. Anyways just picked up a c70 2.0t convertible 53 reg, all is perfect few nigly bits but that's expected, anyways the cruise control works perfect however no light comes up on the dash to inform that it's actually on? Any ideas? The obvious one is fuse but I'm not sure which one it would be. Much appreciated, Paul
Post 712604 by stribo on 2014-05-18 09:17:40
My C70 doesn't have a cruise control light.
Post 712605 by MaxiSNK on 2014-05-18 09:33:40
Oh I thought it did! Just thought my last c70 a few years ago did. Also my reverse sensors don't work they beep for 5 seconds I know this is a fault but any easy way around it or is it a trip to Volvo?
Post 712611 by deathrider311271 on 2014-05-18 10:06:36
if its an ME7 car which yours is, it should have the cruise light bottom left on the dash should be lit once engaged, basically late 98 cars onwards
Post 712616 by MaxiSNK on 2014-05-18 11:05:05
Ah ok thanks, well it doesn't so what would cause that? A fuse?
Post 712617 by deathrider311271 on 2014-05-18 11:23:13
[QUOTE=MaxiSNK;712616]Ah ok thanks, well it doesn't so what would cause that? A fuse?[/QUOTE] probably bulb blown
Post 712618 by MaxiSNK on 2014-05-18 11:31:58
Thanks much appreciated! Where would one check the bulb for this? It's been a long time since I last owned a Volvo and I'm out of touch
Post 712682 by AAnickmac on 2014-05-18 18:36:33
Mine has cruise control light in left hand bottom of display. Probably a blown bulb I expect.
Post 712683 by foammanmark on 2014-05-18 18:37:12
[QUOTE=MaxiSNK;712618]Thanks much appreciated! Where would one check the bulb for this? It's been a long time since I last owned a Volvo and I'm out of touch[/QUOTE] My C70 is a 2000 T5, and has the light for the cruise control. You will need to remove the dash top and tackle the bulb from the back of the clocks. There is a guide to where all the screws are somewhere on here, as I used it and it was fairly easy really.
