Post 56126 by Straker on 2005-11-10 12:32:19
General question
How much oil does your T5 drink. Mine seems to be getting through a rather alarming 0.5 liter every 5000 or so miles (approximately).
I need to know is this normal....
If not then how much is it to service/replace the turbo.
All info greatfully recieved :B_blite:
Post 56130 by Al115 on 2005-11-10 12:49:30
Hold on, half a litre every 5k? That's absolutely fine. Up to a litre every thousand and you can not be worrying... at least, I'm not :)
Post 56131 by Straker on 2005-11-10 12:51:19
Phew I thought I was in trouble for a minute then :troutslap
Post 56143 by Al115 on 2005-11-10 14:00:42
I think that mine actually runs on oil and the petrol is used for cylinder cooling (or something)...
Post 56145 by BlackBeast on 2005-11-10 14:07:57
[QUOTE=Al115]Hold on, half a litre every 5k? That's absolutely fine. Up to a litre every thousand and you can not be worrying... at least, I'm not :)[/QUOTE]
This is why you have to check your oil levels regularly, you could soon find yourself running very low on oil especially if your engine eats a litre every 1k, and as Al has already said, thats nothing to worry about.
Post 56200 by TangoDeltaSierra3 on 2005-11-10 17:20:35
Cozzys can sup a 1litre every 600 mile, yum, slurp, fart!
Post 56327 by Unknown on 2005-11-11 00:04:12
if you think about it its not possble for a engine not to burn a small amount of oil during the course of 5k miles .5 lt in that time is perfectly normal imho
Post 56349 by Straker on 2005-11-11 08:53:40
I realise all cars burn a small amount of oil but this is the first time I have actually owned a turbo car so just wanted a quick sanity check.
My last car was a brand new 1.4 Fiesta and despite thrashing it to within an inch of it's life daily I never once had to top up the oil after 12K miles.
What can I say I have high standards :B_steerin
Post 56357 by Unknown on 2005-11-11 10:13:57
obviously( i would have thought ) a brand new engine should use less than a ten year old car such as your 850, as some wear will have occured in the valve guide /seals oil control rings etc so to compare a old 850 with a brand new car is rather pointless
Post 56362 by Straker on 2005-11-11 10:27:36
Hence my sanity check as I have no frame of referance. A brand new small capacity NA engine is quit different from a 10 year old 2.3 turbo lump.
My question has been answered and my fears put to rest, just have to invest in more oil occasionally.
Post 56369 by lance on 2005-11-11 12:05:32
Ive found durring normal running week to week I dont use any oil, but a 100+mph drive for a tankfull of fuel can result in a drop being used.
My old 850 T5 used 1/4 l of Helex over a 1700 mile trip.
I estimate in my 70 It uses about a litre between 5k oil changes. (151k)
If I have a day where I really thrash it and I mean thrash it I supose I will use a small amount of oil.
If I take my time for a month or 2 and dont take above 4500 rpm very often she seems to use no oil at all.
