Post 709153 by expolicev70t5 on 2014-05-05 18:34:28
:pants:Well I finally got to the bottom of the intermittent engine management light, down side is code was air intake sensor fault, so I'm guessing the MAF is goosed .
[QUOTE=expolicev70t5;709153]:pants:Well I finally got to the bottom of the intermittent engine management light, down side is code was air intake sensor fault, so I'm guessing the MAF is goosed .[/QUOTE] iat sensor and maf sensor are two different things. What code are you getting?
Garage used snap on solus which came up with message air intake sensor fault
I don't think it will be the maf then.
Any ideas what it might be?
