Need advice, V70R manual gearbox
Post 702695 by saffronR on 2014-04-12 05:15:33
Hi fellow VPCUK members, I've been absent for a while, probably over two years actually, due in part to selling my Saffy, but the good news is I may buy it back! The trouble now, the guy I sold it to has had a problem with the manual gearbox, which I thought would be bomb proof, and it now requires a new one, ive had a quick look around the net, to find a replacement, but can't locate one, does anyone know if a normal T5 manual box would be compatible? If I can locate a box, that's not too expensive, then I would definitely have my old R back, it was a top motor when I had it. Cheers, Scott.
Post 702698 by merc85 on 2014-04-12 08:13:15
It will have a M59 gearbox, the m56 gearbox will fit but you may have to change the clutch release bearing and driveshaft, also the flywheel is solid on the early type unlike this one which will be DMF
Post 702705 by stribo on 2014-04-12 08:28:51
I could be wrong, but if it's AWD, I think the casing's different to accommodate the transfer box.
Post 702706 by stribo on 2014-04-12 08:31:31
[QUOTE=merc85;702698]It will have a M59 gearbox, the m56 gearbox will fit but you may have to change the clutch release bearing and driveshaft, also the flywheel is solid on the early type unlike this one which will be DMF[/QUOTE] I thought all P1s had M56 'boxes, only difference being the pre ME7 had solid flywheels, and ME7s had DMFs.
Post 702712 by munster732 on 2014-04-12 08:42:04
If you message Shem, he is selling anM59 gearbox from a S70R. In fact I will text him and let him know you want one. Wayne
Post 702723 by merc85 on 2014-04-12 09:18:10
[QUOTE=stribo;702706]I thought all P1s had M56 'boxes, only difference being the pre ME7 had solid flywheels, and ME7s had DMFs.[/QUOTE] No bud s70r/v70r ph1 had m59 box with diff and dmf
Post 702728 by stribo on 2014-04-12 10:38:26
[QUOTE=merc85;702723]No bud s70r/v70r ph1 had m59 box with diff and dmf[/QUOTE] So did the early C70s have M59s as well, or have they all got M56?
Post 702730 by T5frankie on 2014-04-12 10:43:43
[QUOTE=stribo;702728]So did the early C70s have M59s as well, or have they all got M56?[/QUOTE] you should know that already mate by driving it
Post 702731 by p fandango on 2014-04-12 10:47:50
[QUOTE=stribo;702705]I could be wrong, but if it's AWD, I think the casing's different to accommodate the transfer box.[/QUOTE] AWD is the M58. The M59 casing is also different to the M56 [QUOTE=stribo;702728]So did the early C70s have M59s as well, or have they all got M56?[/QUOTE] it'll be a M56
Post 702912 by saffronR on 2014-04-12 23:50:37
Thanks for the replies guys, fantastic help. Its a front wheel drive, I'm currently at work (offshore West Africa) but this has been of huge assistance, i'll look around for these M56 type boxes, and keep you posted as to how I get on. Ill also mail the lad who owns my old car, and find out if he can identify exactly the issue, and code of its current box. Thanks again. Scott.
Post 702920 by saffronR on 2014-04-13 05:06:17
[QUOTE=munster732;702712]If you message Shem, he is selling anM59 gearbox from a S70R. In fact I will text him and let him know you want one. Wayne[/QUOTE] Thanks Wayne, If i could have some details of the box he has on offer, (miles/Price/location) then I can work out quite easily if it's going to be cost effective to buy back my old R or not. I would much prefer to buy from a forum member than some unknown knackers yard on fleabay! Scott.
Post 775650 by saffronR on 2015-06-10 23:02:48
Thread update! After over a year of trying to buy my old car back, I final towed her home tonight! What a sorry state she looks! If only the lad would have let me have it last year! Anyway back on track, I NEED A GEARBOX! M59 I understand, Front wheel drive manual 1998 R V70R, anyone able to help??? Cheers, Scott.
Post 775652 by Tomcat on 2015-06-10 23:25:34
You'll need the long drive shaft as well as the one for the M59 is different. What's the problem with your old box?
Post 775653 by saffronR on 2015-06-10 23:33:46
It was damaged by what looks like a large bolder hitting it at speed, punching a hole into the casing, and the box dumping it fluids. How do I find out what box it has? Is it likely to be the M59?
Post 775655 by AcidicDavey on 2015-06-10 23:46:00
It will be a M59 unless it has been replaced previously.
Post 775656 by smithy on 2015-06-11 01:37:30
[QUOTE=saffronR;775653]It was damaged by what looks like a large bolder hitting it at speed, punching a hole into the casing, and the box dumping it fluids. How do I find out what box it has? Is it likely to be the M59?[/QUOTE] Most m59 box end up with a hole in the side .
Post 775663 by Tomcat on 2015-06-11 10:10:34
[QUOTE=smithy;775656]Most m59 box end up with a hole in the side .[/QUOTE] How's that?..
Post 775664 by saffronR on 2015-06-11 10:33:46
[QUOTE=AcidicDavey;775655]It will be a M59 unless it has been replaced previously.[/QUOTE] Thanks, don't have one for sale do you ;)
Post 775665 by Ettienne on 2015-06-11 10:44:10
I don't find them any worse than m56s, but either will fail if mistreated and not serviced, pretty much the same with m66 awd although they are a bit stronger
Post 775666 by Ettienne on 2015-06-11 11:04:00
M59s are interchangable with flywheels you can use either solid or dual mass and either will work with internal or external slaves. I.e internal slave dmf or smf External slave dmf or smf We use smf's from 850 with internal slaves on the m66!!!
Post 776700 by saffronR on 2015-06-24 10:50:22
It appears that finding a manual gearbox for my '70R is like trying to find a vegetarian shark! I'm off to sea for a month, if nothing turns up in the next four weeks looks like I may have to offer the old girl up as spares or repairs :sick: If anyone knows, or hears of a suitable box for sale, please let me know, I'm very keen to save this car from an undignified end. Cheers, Scott.
Post 776719 by Ettienne on 2015-06-24 16:03:11
Put a m56 in or better still a m66, at least then you'll be able to use it
Post 776748 by saffronR on 2015-06-24 21:28:57
Ettienne, thanks for your reply, it appears you know your stuff. The two boxes you mention are both readily available, if you don't mind, and if you can find the time, would you be able to let me know what additional parts I would need to buy to use either box, I guess the m66 is better as it's from a newer model? Much appreciate the feedback I've already received from all the members who posted:B_thumb:
Post 776752 by Ettienne on 2015-06-24 22:14:29
M56 is a straight fit, just need a new / secondhand long shaft and is the easier of the options
Post 776754 by saffronR on 2015-06-24 22:20:12
Thanks mate.
Post 791755 by saffronR on 2015-11-22 22:32:47
Thread resurrection! With the help of a member on here, I was directed to a lad on T5D5 who was planning on a gripper conversion to his R, months of chat, a few calls, and the transfer of funds now put me in possession of very usable M59 manual box. So the plan now, I need to buy a battery, complete a quick oil change, and minor service, I'll entrust the box change to a local garage who looks after my other 'performance' car, then hopefully have it MOT'd and back on the road by the end of the year. It has been a very slow process getting this far, but I just knew the car was too good to give up on, I'm not out of the woods yet, but I recon it's pretty much plain sailing from here on in! Thanks again to all who have helped me out along the way,( particularly red brick) I honestly could not have got this far without the power of this Forum, and it's excellent members, who are willing to offer advice, knowledge, and information, when needed the most. Respect! Scott.
