starting issue
Post 700826 by T5frankie on 2014-04-04 19:40:40
i had to change the in tank fuel pump on my 740t, now the car starts every time but dies straight away, ive had the pump back out and tested it and it works, dunno if its a co-oincidence but i also changed the leads. dizzy/rotor arm whilst in the middle of doing the pump but i thought any problem there would cause rough running, doing my head in now as running out of free retest time, and you also have to be double jointed to do this job
Post 700829 by merc85 on 2014-04-04 19:44:07
Could be the fuel pump relay mate, ive just sold one of these to a customer who had exactly the same issue, and it sorted it
Post 700833 by T5frankie on 2014-04-04 19:46:21
[QUOTE=merc85;700829]Could be the fuel pump relay mate, ive just sold one of these to a customer who had exactly the same issue, and it sorted it[/QUOTE]
on a 740?
Post 700835 by merc85 on 2014-04-04 19:48:02
[QUOTE=T5frankie;700833]on a 740?[/QUOTE]
yes a blue 740 turbo intercooler estate, Manual too :)
Post 700839 by AAnickmac on 2014-04-04 20:04:47
these are really common as a breakdown. i thought it was a green relay behind radio area. but may be blue in colour.
Post 700842 by merc85 on 2014-04-04 20:15:44
[QUOTE=AAnickmac;700839]these are really common as a breakdown. i thought it was a green relay behind radio area. but may be blue in colour.[/QUOTE]
The one the gentleman had in my shop was a white relay, cant remeber the part number of it tobe honest.
Post 700844 by T5frankie on 2014-04-04 20:18:30
i know its common on 850's, will try that dunno why it should suddenly go as i change the pump though
Post 700847 by stribo on 2014-04-04 20:22:25
[QUOTE=merc85;700842]The one the gentleman had in my shop was a white relay, cant remeber the part number of it tobe honest.[/QUOTE]
I hope you're not pushing your business. ;)
Post 700849 by MoleT-5R on 2014-04-04 20:23:08
[QUOTE=T5frankie;700844]i know its common on 850's, will try that dunno why it should suddenly go as i change the pump though[/QUOTE]
may be your new pump is drawing more power though the old relay than the old tired one did....just a thought
Post 700850 by merc85 on 2014-04-04 20:23:33
[QUOTE=stribo;700847]I hope you're not pushing your business. ;)[/QUOTE]
no im not, but as a registered trader on here, if i feel the need to i can. :)
Post 700851 by MoleT-5R on 2014-04-04 20:23:45
stirrer.......lol
Post 700852 by t5 pete on 2014-04-04 20:25:47
Yeah the relays are bad had the same problem on the 240 but in my case it wouldn't start a quick bash to the relay and it would be fine its the solder inside of them that goes dry I re soldered mine and was all fine.
One thing to do frank is get some one to start it while you listen for the pump and see if it cuts out once its started
Post 700854 by T5frankie on 2014-04-04 20:28:44
[QUOTE=MoleT5-R;700849]may be your new pump is drawing more power though the old relay than the old tired one did....just a thought[/QUOTE]
i tried the new one and the old one as it wasnt actually the pump that went just rusted through joints, they both work,
i ran a live straight from the battery to the pump worked but still didnt stay running
Post 700857 by MoleT-5R on 2014-04-04 20:34:16
[QUOTE=T5frankie;700854]i tried the new one and the old one as it wasnt actually the pump that went just rusted through joints, they both work,
i ran a live straight from the battery to the pump worked but still didnt stay running[/QUOTE]
so if I'm reading this right, you've got 2 duff pumps then ??
Post 700859 by T5frankie on 2014-04-04 20:39:56
[QUOTE=MoleT5-R;700857]so if I'm reading this right, you've got 2 duff pumps then ??[/QUOTE]
no you're not reading it right, i have 2 good pumps
Post 700861 by oblark on 2014-04-04 20:47:38
The fuel pump relay is also the ignition relay.
If my memory is right the fuel pump side of the relay comes in first then the ignition side comes in and it is behind the radio.
So if the fuel pump side fails then the ignition will not come in.
Post 700864 by MoleT-5R on 2014-04-04 20:53:39
[QUOTE=T5frankie;700859]no you're not reading it right, i have 2 good pumps[/QUOTE]
so why do they stop pumping when as you say "[COLOR=#333333]i ran a live straight from the battery to the pump worked but still didnt stay running" [/COLOR][COLOR=#333333]or do you mean the pump continued to run but the ignition cut [/COLOR][COLOR=#333333][/COLOR]
Post 700881 by stribo on 2014-04-04 21:06:21
[QUOTE=MoleT5-R;700851]stirrer.......lol[/QUOTE]
me? never ;)
Post 700917 by T5frankie on 2014-04-04 21:49:51
[QUOTE=MoleT5-R;700864]so why do they stop pumping when as you say "[COLOR=#333333]i ran a live straight from the battery to the pump worked but still didnt stay running" [/COLOR][COLOR=#333333]or do you mean the pump continued to run but the ignition cut [/COLOR][COLOR=#333333][/COLOR][/QUOTE]
I didn't say they stopped pumping just my car won't run for more than a second
Post 700940 by MoleT-5R on 2014-04-04 22:26:24
[QUOTE=T5frankie;700917]I didn't say they stopped pumping just my car won't run for more than a second[/QUOTE]
but you didn't say that when the car cut out, the pump was still working, but all that aside it looks like an ignition fault afaik
Post 700974 by jks on 2014-04-05 06:00:45
Ignition and fuel is controlled by two relays, fuel pump (white) and radio suppression relay..
Sounds like ignition problem..
Post 700976 by oblark on 2014-04-05 07:23:09
[QUOTE=jks;700974]Ignition and fuel is controlled by two relays, fuel pump (white) and radio suppression relay..
Sounds like ignition problem..[/QUOTE]
NO.
one relay controls the fuel pump and ignition.
I should no.............. I've had a 740 turbo intercooler which had a starting problem.
One minute I had fuel but no spark or no fuel and a spark.
Got a new relay and had years of trouble free motoring.
Post 700978 by jks on 2014-04-05 07:48:07
[QUOTE=oblark;700976]NO.
Got a new relay and had years of trouble free motoring.[/QUOTE]
YES. Lol
Radio suppression relay is connected to fueling.
http://www.davebarton.com/volvorelays.html
Post 700990 by T5frankie on 2014-04-05 09:48:42
[QUOTE=jks;700978]YES. Lol
http://www.davebarton.com/volvorelays.html[/QUOTE]
where is the radio supression relay? bearing in mind the 940 is different
Post 701017 by artfulflounder on 2014-04-05 10:51:10
http://www.volvoclub.org.uk/faq/EngineFuelinjection.html#Radio_Suppression_Relay
The radio suppression relay is also fuel injection relay.
Post 701032 by oblark on 2014-04-05 12:58:01
Surely you cant miss a relay that controls the fuel pump, ignition, fuel injection and the radio........... it must be the size of shoe box.
Post 701088 by T5frankie on 2014-04-05 16:37:27
[QUOTE=oblark;701032]Surely you cant miss a relay that controls the fuel pump, ignition, fuel injection and the radio........... it must be the size of shoe box.[/QUOTE]
no just a normal size,
Post 701129 by artfulflounder on 2014-04-05 18:35:07
Dont know if it helps but The cooling fan relay is same part number so could just swap that in and see if it works.
know the relay is at fault then.
Post 701137 by 960kg on 2014-04-05 18:46:03
Frankie , just trying to help again as others think i am a complete arsole........but i owned 4x 740`s and on 3 of them the motor misfired and also stopped while driving and it was traced to the earthing of this Amplifier Ignition Unit or Power Unit on the inside of the right hand wing looking at the car from the front.
Undo the bolts holding it and scrape the rust off the body and re bolt up and it should if the problem be ok..........it is a very common thing with 740`s as the 940 is different....it is just the Earthing of the unit!
Hope it helps you!
Post 701138 by T5frankie on 2014-04-05 18:50:22
[QUOTE=960kg;701137]Frankie , just trying to help again as others think i am a complete arsole........but i owned 4x 740`s and on 3 of them the motor misfired and also stopped while driving and it was traced to the earthing of this Amplifier Ignition Unit or Power Unit on the inside of the right hand wing looking at the car from the front.
Hope it helps you!
..................................[/QUOTE]
thanks for the help but its running again now, i took the fuel pump relay out, put it in again and it works now lol WTF?? i'm not complaining though lol
car is now ready for its retest
Post 701141 by 960kg on 2014-04-05 18:54:12
Despite all sarcasm everywhere i am glad you are sorted........but do check the rusted bolts on this power unit as it does cause problems on the 740
Post 701143 by T5frankie on 2014-04-05 18:56:02
[QUOTE=960kg;701141]Despite all sarcasm everywhere i am glad you are sorted........but do check the rusted bolts on this power unit as it does cause problems on the 740[/QUOTE]
every nut and bolt has rust on it, when i tried to replace the intank fuel pump, all the jubilee clips had no heads on they were that rusted
