Post 697368 by LeeT5 on 2014-03-24 01:15:50
Can anyone advise me whether a HU-850 will direct swap with a HU-803? I know HU-850 has Dolby II, but what other differences are there and will it work?
850 is for facelift frame. For preface its a 603 and 803 Facelift is 650 and 850 Basically the 6 is single cd 8 are multi cd
[QUOTE=T5RatherAmusin;697369]850 is for facelift frame. For preface its a 603 and 803 Facelift is 650 and 850 Basically the 6 is single cd 8 are multi cd[/QUOTE] So stick with what I got then? The 803.
if you where to change to the 850 youd have to change the heater unit too with surround to fit. doing this will then leave a lil gap between that and the console. which then youd have to get a 05+ centre console... [ATTACH=CONFIG]24216[/ATTACH]
Ah I see. Thanks for the info dude! (crosses off 'To Do' list)
Also if you have the in car phone the trim changes as well.
[QUOTE=T5RatherAmusin;697382]if you where to change to the 850 youd have to change the heater unit too with surround to fit. doing this will then leave a lil gap between that and the console. which then youd have to get a 05+ centre console... [ATTACH=CONFIG]24216[/ATTACH][/QUOTE] Is you car LH drive !.
[QUOTE=Harvey;697707]Is you car LH drive !.[/QUOTE] Yes and those holes look nasty in the dash! More to the point, why is there half of Brighton beech in the footwell and all over the dash?
not my car, robbed the image from google ;)
[QUOTE=Harvey;697649]Also if you have the in car phone the trim changes as well.
[/QUOTE]
How did you do the VPCUK thing in the display??
[QUOTE=rikcougar;697917]How did you do the VPCUK thing in the display??[/QUOTE] With the imiv box and saved a folder as whats in the display to the iPhone.
