Will this fit?
Post 695695 by rikcougar on 2014-03-17 14:30:44
2005 55 reg S60 T5 ex plod Will this fit my airbag connectors? http://www.ebay.co.uk/itm/360869152588?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649 The car is a 2005 registered model but some bits of it are 2004 (stereo surround etc) which makes me unsure when it was manufactured I have also ordered a leather steering wheel with audio and cruise controls, is it possible to retrofit cruise to a non cruise car? Final question, if I isolate battery prior to disconnecting air bags will it stop it throwing a fit? Many thanks in anticipation to those that know
Post 695696 by M-R-P on 2014-03-17 14:36:59
Battery off for an hour minimum before buggering about with the SRS system mate ;) You'll need the cruise control activated via Vida. I think the seats will be a straight swap, if not, a bit of bodging will get you there.
Post 695700 by T5RatherAmusin on 2014-03-17 15:35:15
straight fit bud. yours will be a facelift. whoever put in preface if it is one? cd was cos of cost... use your old window switches
Post 695701 by M-R-P on 2014-03-17 15:42:16
Oh yeah - window switches. Good idea :)
Post 695745 by rikcougar on 2014-03-17 17:53:41
[QUOTE=T5RatherAmusin;695700]straight fit bud. yours will be a facelift. whoever put in preface if it is one? cd was cos of cost... use your old window switches[/QUOTE] Thanks guys Wasn`t sure because you mentioned in your build thread that when you fitted HU603 in yours that you had to trim it to fit, mine went straight in My local Indy guy has Vadis and I need him to switch on backlighting on my HU so will get him to do cruise as well (and audio controls on wheel as well presumably?) Will all cruise components be already there?
Post 695764 by graemewelch on 2014-03-17 18:43:24
you might need the sensor/switches that go on the clutch and brake.
Post 696308 by T5RatherAmusin on 2014-03-19 18:04:33
[QUOTE=rikcougar;695745]Thanks guys Wasn`t sure because you mentioned in your build thread that when you fitted HU603 in yours that you had to trim it to fit, mine went straight in My local Indy guy has Vadis and I need him to switch on backlighting on my HU so will get him to do cruise as well (and audio controls on wheel as well presumably?) Will all cruise components be already there?[/QUOTE] do you have the surround trim for the cd then??
Post 696313 by rikcougar on 2014-03-19 18:09:02
[QUOTE=T5RatherAmusin;696308]do you have the surround trim for the cd then??[/QUOTE] I bought the head unit and cup holder complete, ripped out the double din adapter and it fitted straight in it`s place Looks factory and sounds bloody good
Post 696315 by T5RatherAmusin on 2014-03-19 18:14:00
[QUOTE=rikcougar;696313]I bought the head unit and cup holder complete, ripped out the double din adapter and it fitted straight in it`s place Looks factory and sounds bloody good[/QUOTE] pic?
Post 697160 by rikcougar on 2014-03-23 10:50:49
HU pic [ATTACH=CONFIG]24185[/ATTACH]
Post 697161 by stribo on 2014-03-23 10:57:36
[QUOTE=rikcougar;697160]HU pic [ATTACH=CONFIG]24185[/ATTACH][/QUOTE] Your dash is missing loads of buttons. ;)
Post 697230 by rikcougar on 2014-03-23 16:34:04
[QUOTE=stribo;697161]Your dash is missing loads of buttons. ;)[/QUOTE] I`m poor Steve :cry: Progress thread starting shortly
Post 697240 by stribo on 2014-03-23 16:54:23
[QUOTE=rikcougar;697230]I`m poor Steve :cry: Progress thread starting shortly[/QUOTE] That's what comes from buying a 3 door Cossie, though you'll never lose money on it. :D
Post 697259 by rikcougar on 2014-03-23 17:32:50
[QUOTE=stribo;697240]That's what comes from buying a 3 door Cossie, though you'll never lose money on it. :D[/QUOTE] Fair point mate, wouldn`t change it though!
