Post 695692 by Spooky on 2014-03-17 12:47:19
This is for a P1 V70 R :) used search but can only find one for the P2 :(
For changing the bush or just replacing the whole item?
changing the bush Dave, i have got the old one out and read a few comments on the net that the easiest way to get the new one in is to stick it in the freezer over night (i dont have a puller btw)
Just get a long treaded bolt 2 large washers and 2 bolts and wind it in :)
[QUOTE=Jamest5r;695766]Just get a long treaded bolt 2 large washers and 2 bolts and wind it in :)[/QUOTE] so put the bolt through a washer, through the mount and bush then a washer and 2 nuts on the other end and just tightening it will force it through with no damage? :)
[QUOTE=Spooky;695771]so put the bolt through a washer, through the mount and bush then a washer and 2 nuts on the other end and just tightening it will force it through with no damage? :)[/QUOTE] Yep plenty of wd40 and try to get washers as big as the bush makes it easier worked for me years ago after the the freezer thing was a mif lol
If you're using a bolt, you'll only need one nut, if you're using threaded rod, then you'll need 2 nuts, one for each end.
thanks guys!! thats my mission for 2moz sorted then hahahaha. check me out doing my own repairs! normally i just take her somewhere to get stuff fixed, but i have serviced her myself this weekend, oil, filter and plugs and now this! Its gonna snow tomorrow! ;)
just to check, defo wd40 and not washing up liquid? I would have thought it would be easier with that?
i.i.r.c. I used copper grease, but any lubricant that's not going to perish the bush would do.
Have u tried youtube
I think there is one on therec
[QUOTE=Spooky;695791]just to check, defo wd40 and not washing up liquid? I would have thought it would be easier with that?[/QUOTE] [QUOTE=stribo;695798]i.i.r.c. I used copper grease, but any lubricant that's not going to perish the bush would do.[/QUOTE] [QUOTE=abdul;695799]Have u tried youtube[/QUOTE] I don't think you tube would work as a lubricant, maybe try you lube. :D
[QUOTE=stribo;695831]I don't think you tube would work as a lubricant, maybe try you lube. :D[/QUOTE] hahahah brilliant!
A few good videos on youtube.com
ok, finding washers this big is proving a task hahahahah
[QUOTE=Spooky;695987]ok, finding washers this big is proving a task hahahahah[/QUOTE] Doesn't have to be washers - got any old metal plate? Drill holes in that - you only want a flat surface that can push against the bush face, just try to ensure that the surface is bigger that the bush face or else it'll damage the bush.
[QUOTE=abdul;695931]A few good videos on youtube.com[/QUOTE] Mostly about cats? (feline variety) No sorry that's facebook
