Removing air con on a 96 940....
Post 687505 by pwalker on 2014-02-06 14:11:45
Basically iv already removed the air con but just wondering if there's anything else I need to do before I scrap everything, Iv kept all the plugs etc. reason being I know when you removing it on a gt4 you have to do some short a wire or the radiator fans run constantly....I didn't know that untill I binned everything haha, so yeah just checking I don't have to do anything simelar on this, iv kept all plugs etc incase
Post 687507 by artfulflounder on 2014-02-06 15:00:15
Did a quick search and found this: Leave the belt in place but disconnect the electrical wires to the compressor/clutch. The clutch on the compressor will spin freely and the compressor will no longer pull hp from the engine.
Post 687508 by smithy on 2014-02-06 15:04:01
Remove everything and put a none aircon belt on job done
Post 687511 by pwalker on 2014-02-06 15:13:57
Why put the belt on? Iv removed the pump itself
Post 687512 by pwalker on 2014-02-06 15:14:40
Or does the alternator normaly run off the same belt and someone's already swapped it? As there was no aircon belt on to start but the pump was there
