s60 central locking problem
Post 685335 by classicswede on 2014-01-29 13:36:34
2001 S60 Remote central locking has an intermitant problem where when you look the car all the doors lock but the drivers door will pop right back open. It might lock first time but other it can take ten or more goes to get it locked. Are any common faults that cause this. It will not lock on the key so a bit of a pain to lock the car
Post 685340 by T5RatherAmusin on 2014-01-29 14:24:13
Try a uem reset - Close all of the doors and bonnet. - Key in position II engine not running. - Hold both the driver window and passenger window switches in the driver door panel in the closed or up position for 5 to 8 seconds after the windows are closed. - Release buttons. - Remove the ignition key. - Operated the remote twice. lock/unlock lock/unlock if no good u need a new lock
Post 685364 by mikealder on 2014-01-29 18:24:36
After trying the UEM reset look closely at the bonnet catches, one has a couple of wires from it, if this one isn't working correctly it can cause your issue, clean it up as dried grease can make it fail to work correctly - Mike
Post 685374 by Harvey on 2014-01-29 18:46:39
The catch with the switch is the n/s one, but I would have thought if the switch was at fault the lights would not flash when you set the alarm. I had this fault with my car but if I locked some times the indicators would not flash untill the bonnet was droped shut then they would work,but the car would always locked ok. Just to say I did change the switch as I got one when I did the alarm siren unit as part of the kit. But you should get the codes looked at as they will say what is wrong,anyone near you with a volvo code reader ?.
Post 685461 by classicswede on 2014-01-29 21:37:56
I had a look at it today for my friend and resetting the UEM and that made no difference. If it was the bonnet switch would you get the bonnet open warning? I'm fairly sure the issue is with the drivers door lock as the barrel is not sitting correctly. Are there any problems with replacing the door lock/barrel? I do need to buy myself a Dice unit and have been meaning to for a long time but just not got around to it yet.
