anyone used a standard rb25 turbo on a b200 or b230 before?
Post 681076 by pwalker on 2014-01-17 01:40:42
as title, anyone used one?, how did it perform, hopefully i will have a b230 soon and seen as though i already have a good skyline turbo sat around i thaught it might be ideal, only 200cc off the difference in engine capacity just a couple of cylinders missing, standard rb25 is 250bhp at .7bar iirc which is what id like in the volvo. also as a benefit i still have an aftermarket downpipe and screamer for it.... bonus. rb25 turbo is supposidly t28 size
Post 681085 by smithy on 2014-01-17 02:29:43
You can make any turbo fit any car mate .if the turbo has a t3 stamp it does make things easier .just custom oil and water lines and set the fueling for the extra air and off you go mate .peeps fit hx40/50 on to 940 with the stock manifold so you shouldn't have a problem with space .
Post 681086 by pwalker on 2014-01-17 02:34:55
Yeah there t3 standard, not worried about fitting more just spool up times etc, I'm proberbly going to use it regardless like seen as tho I have it, got a ct26 sat about aswell but silly ct flange
