locked out
Post 675806 by WOODY T5 on 2013-12-30 19:28:26
carnt get in to my car as the battery as gone flat and i have delocked it tryed the boot lock but no go it just turns is it smash a window time ;(
Post 675807 by stribo on 2013-12-30 19:29:18
Have you got RAC or AA cover, they'll get in in no time.
Post 675808 by claymore on 2013-12-30 19:30:30
can you jack it up and get jump leads on the chassis and starter?
Post 675809 by graemewelch on 2013-12-30 19:31:36
could always try a coat hanger. its worked for me in the past but claymores idea sounds better
Post 675810 by T5frankie on 2013-12-30 19:32:03
good idea colin
Post 675811 by Rudeyboy18 on 2013-12-30 19:34:54
Aa have broken into 2 of my cars with no permanent damage. Defo worth calling them
Post 675812 by stephenevans99 on 2013-12-30 19:35:04
Can't you remove the weather strip at the bottom of the window and use the old bent coat hanger trick....worth a try
Post 675814 by Jamest5r on 2013-12-30 19:38:11
Pull the top corner of the door it will flex enough then wedge it with something and slide coat hanger in and pull the lever back simples :)
Post 675815 by WOODY T5 on 2013-12-30 19:49:10
[QUOTE=claymore;675808]can you jack it up and get jump leads on the chassis and starter?[/QUOTE]thanks for that col works great me is happy
Post 675816 by stribo on 2013-12-30 19:54:18
Glad you got in without damaging your car mate. :D Nice one Col
Post 675818 by claymore on 2013-12-30 20:00:34
[QUOTE=WOODY T5;675815]thanks for that col works great me is happy[/QUOTE] Better than trying to force things ;) can you tell that I'm talking from previous experience.....lol
Post 675829 by Biff on 2013-12-30 20:32:00
That's an awesome idea Colin. Quick question. Though woody, did you fit a rear handle to de-lock it?
Post 675902 by WOODY T5 on 2013-12-30 23:38:06
[QUOTE=Biff;675829]That's an awesome idea Colin. Quick question. Though woody, did you fit a rear handle to de-lock it?[/QUOTE]no mate back ones don't fit used to left hand c70 ones
Post 675904 by Biff on 2013-12-30 23:39:09
[QUOTE=WOODY T5;675902]no mate back ones don't fit used to left hand c70 ones[/QUOTE] Thanks mate, will keep an eye out! ;)
Post 675913 by Kingsford G on 2013-12-31 00:01:27
You beat me to it Collin.
Post 675914 by Dangerous Dave on 2013-12-31 00:09:52
Or don't de-lock it in case your battery goes flat :P Thought about doing it with mine, but with my luck the battery would die and at some point I would be stuck
Post 676026 by jdavis on 2013-12-31 12:10:09
Had to do the same with a ford explorer that and been left with battery flat and key wouldn't work. works a atreat
Post 679133 by LeeT5 on 2014-01-10 13:05:48
[QUOTE=Jamest5r;675814]Pull the top corner of the door it will flex enough then wedge it with something and slide coat hanger in and pull the lever back simples :)[/QUOTE] For the record James, if the car is deadlocked, that method won't work.
Post 679161 by partsforvolvos.com on 2014-01-10 14:54:28
surely you cannot use a coathanger or whatever impliment because it is deadlocked anyway? the only way is get power to the system. - smashing the window will only allow access to the bonnet pull. can you get in through the grille on these? not sure.
Post 679162 by WOODY T5 on 2014-01-10 14:58:00
Dint think these 850's ad dead locks tho
Post 679426 by jdavis on 2014-01-11 00:32:01
Get power to the car Dean and you'll be sorted. Starter motor, any where really.
Post 679436 by p fandango on 2014-01-11 01:33:41
[QUOTE=WOODY T5;679162]Dint think these 850's ad dead locks tho[/QUOTE] standard across the whole range
Post 680240 by partsforvolvos.com on 2014-01-14 12:57:21
[QUOTE=p fandango;679436]standard across the whole range[/QUOTE] they do for any with a guard 2.1 or 2.2 alarm late 1995-1997. incidentally, I believe these are not thatcham cat1 due to having no immobiilser chip in the key. on the 1992-1994 ones with the early alarm, you put the key in the door and turn 1/4 to lock, then turn again from top and it goes around further to 1/2 turn and activates the deadlocks.
