Post 674440 by charlie-r on 2013-12-27 12:22:50
So I've had the 850 for a few months and done loads of miles and had it dyno'd and it pulled REALLY well, was driving up north the other day and as I was driving along I noticed the lambda light popped up on the dash. Then as I was pulling out of a service station I noticed the car wasn't as quick as normal, still pulling but not as much as usual.
Floored it and checked the boost gauge and the car's not boosting above 5psi, but drives perfectly normally below that.
Anybody in the North/South Yorkshire area got a code reader they wouldn't mind me popping round and scanning in exchange for some beer tokens or even cash if you prefer it? Or another solution if anyone has one? I'm guessing MAP sensore or TPS but won't be sure until I plug it in I suppose.
Cheers, Charlie.
Post 674441 by shepbomb on 2013-12-27 12:26:37
Hi mate, I have volvo fcr which will help you, aldo have a obd reader, what year is ur 850
Post 674442 by charlie-r on 2013-12-27 12:29:55
Awesome, shoulda said it's a 95 so OBD-I, whereabouts are you bud? :)
Post 674443 by MoleT-5R on 2013-12-27 12:30:46
[QUOTE=charlie-r;674440]So I've had the 850 for a few months and done loads of miles and had it dyno'd and it pulled REALLY well, was driving up north the other day and as I was driving along I noticed the lambda light popped up on the dash. Then as I was pulling out of a service station I noticed the car wasn't as quick as normal, still pulling but not as much as usual.
Cheers, Charlie.[/QUOTE]
as you said you really need to plug it in to find out whats up, its obviously gone into limp mode, lambda light came up on mine recently when messing about with the maf swapped ecu's to clear it, someone recently said that ecu only stores a limited amount of information and should it be a one off fault it will clear itself after 5 cold starts.
Post 674444 by shepbomb on 2013-12-27 12:32:27
Im in donny mate, I normally reside with pete and wayne but my project is taking up so much of my time lol, when are you about
Post 674446 by munster732 on 2013-12-27 12:37:15
[QUOTE=shepbomb;674444]Im in donny mate, I normally reside with pete and wayne but my project is taking up so much of my time lol, when are you about[/QUOTE]
It's my old car Ste, if you get stuck Charlie give me a shout and I'll come upto Sheps as well. No OBD2 plug under that panel tho remember :-)
Wayne
Post 674448 by shepbomb on 2013-12-27 12:40:33
Good to see u got it working dude, you making an appearance tomorrow
Post 674454 by merc85 on 2013-12-27 12:57:57
[QUOTE=charlie-r;674442]Awesome, shoulda said it's a 95 so OBD-I, whereabouts are you bud? :)[/QUOTE]
obd 1 has its own code reader, by the ecu box. Plug the fly lead into A3 port press the button for 1 second then count the flashes, that will be your code
Post 674460 by munster732 on 2013-12-27 13:21:47
Have a gander at this Charlie, its what I used when I had an ABS light on once.
Hope it helps, if not pop up if ur close by, be good to see the Grandad-mobile again :smile:
http://www.matthewsvolvosite.com/read-codes-volvo-850
Post 674463 by charlie-r on 2013-12-27 13:51:59
Cool stuff cheers lads, I'll be back in Donny tonight but won't bother you on a friday night, I'll be about tomorrow until wednesday so whenever's easiest really? :) Thanks!
Car's been running wicked so far cheers Wayne!
Post 674465 by t5 pete on 2013-12-27 14:08:22
Vacume hose or intercooler system leak
