1998 V70r obd2?
Post 667672 by bongodave on 2013-12-09 18:59:19
Ok, I am confused. Found the hook-up port under arm rest and it says OBD2 on it. I thought that only came in to play after 2001? Big bonus if it is as presume this means I can get one of the port dongles for a tenner and hook it up to my phone?
Post 667674 by V70 Graham on 2013-12-09 19:02:23
Big bonus time, my 1998 V70 is OBDII as are most Volvos 1996+
Post 667680 by bongodave on 2013-12-09 19:04:49
They were way ahead of the game there then! Just noticed the bluetooth dongles are a mere £6.25 now! Happy days! lol
Post 667681 by Kingsford G on 2013-12-09 19:06:21
The connector is in the centre compartment
Post 667684 by jamesy12345 on 2013-12-09 19:09:59
I think it came in around '96, yours should be M4.4 management and OK for OBD
Post 667686 by bongodave on 2013-12-09 19:10:55
[QUOTE=Kingsford G;667681]The connector is in the centre compartment[/QUOTE] Seriously? Bonus mate! Cheers!!! lol. Time to play and search for app.
Post 667687 by bongodave on 2013-12-09 19:17:57
Blimey. Even the app is free and claims to be able to read horsepower!
Post 667688 by stribo on 2013-12-09 19:18:42
I use this on my C70, also hooks up to the S60R. Now the bad news, to turn the service light off you're going to need one of these: http://www.powertoolworld.co.uk/draper-expert-volvo-service-and-airbag-indicator-reset-tool-69007.html Almost impossible to find new, there is one for hire on Ebay, or if you're lucky someone on here has one who lives close, and will let you borrow it. I have one, but you're a bit far away.
Post 667689 by Kingsford G on 2013-12-09 19:19:07
[QUOTE=bongodave;667687]Blimey. Even the app is free and claims to be able to read horsepower![/QUOTE] Give it a go and let us know mate.Have you had a play with the boost controller yet?
Post 667692 by bongodave on 2013-12-09 19:22:08
[QUOTE=Kingsford G;667689]Give it a go and let us know mate.Have you had a play with the boost controller yet?[/QUOTE] Tad wary about using it as know I can be heavy footed and rod-bendy! lol. I will no doubt give it a go at some point mind you. Will keep you posted.
Post 667693 by bongodave on 2013-12-09 19:23:20
[QUOTE=stribo;667688]I use this on my C70, also hooks up to the S60R. Now the bad news, to turn the service light off you're going to need one of these: http://www.powertoolworld.co.uk/draper-expert-volvo-service-and-airbag-indicator-reset-tool-69007.html Almost impossible to find new, there is one for hire on Ebay, or if you're lucky someone on here has one who lives close, and will let you borrow it. I have one, but you're a bit far away.[/QUOTE] That's a bit daft if service light can't be knocked off. Clearly quite cunning there then. lol. Thanks for advice and offer there mate.
Post 667695 by t5 pete on 2013-12-09 19:28:36
[QUOTE=stribo;667688]I use this on my C70, also hooks up to the S60R. Now the bad news, to turn the service light off you're going to need one of these:http://www.powertoolworld.co.uk/draper-expert-volvo-service-and-airbag-indicator-reset-tool-69007.html Almost impossible to find new, there is one for hire on Ebay, or if you're lucky someone on here has one who lives close, and will let you borrow it. I have one, but you're a bit far away.[/QUOTE] There is actually a procedure you can do to turn it off but ive forgot
Post 667697 by bongodave on 2013-12-09 19:30:09
[QUOTE=t5 pete;667695]There is actually a procedure you can do to turn it off but ive forgot[/QUOTE] Lol. CHEERS pETE! ;-)
Post 667699 by V70 Graham on 2013-12-09 19:37:40
[QUOTE=t5 pete;667695]There is actually a procedure you can do to turn it off but ive forgot[/QUOTE] I'll help you mate..... 1. Press and hold odometer reset button 2. Turn ignition switch to pos 2 3. After SRL flashes, release odometer reset button 4. Confirm by turning your Volvo off, then on again Doesn't do 1998 models though, my light came on tonight too......and the Draper tool is now discontinued !
Post 667701 by stribo on 2013-12-09 19:40:12
[QUOTE=t5 pete;667695]There is actually a procedure you can do to turn it off but ive forgot[/QUOTE] That's only for ME7 engines [QUOTE=V70 Graham;667699]I'll help you mate..... 1. Press and hold odometer reset button 2. Turn ignition switch to pos 2 3. After SRL flashes, release odometer reset button 4. Confirm by turning your Volvo off, then on again Doesn't do 1998 models though, my light came on tonight too......and the Draper tool is now discontinued ![/QUOTE] As Graham has just said. ;)
Post 667702 by V70 Graham on 2013-12-09 19:42:37
This might do the job..... http://www.ebay.co.uk/itm/Volvo-Service-Reset-Tool-ITCVSR-/160986313516?_trksid=p2054897.l4275
Post 667705 by bongodave on 2013-12-09 19:51:33
so many choices lol ta all
Post 667782 by jamesy12345 on 2013-12-10 02:43:01
Your '98 model should be covered by VOL-FCR software....my service light is on too so I'm going to try and get a copy of this: http://www.ilexa.co.uk/diagnostic-tools/vol-fcr/38-vol-fcr-quick-guide.html
Post 667843 by 960kg on 2013-12-10 12:49:39
[QUOTE=bongodave;667687]Blimey. Even the app is free and claims to be able to read horsepower![/QUOTE] If you are not EXACT with the profile you input to the app you can get very wide readings eg: the weight of the car....don`t forget to add your own weight!! I had a reading of 313bhp and that was with only a remap and standard 16T and exhaust....not correct... i have a good engine but not that good! I checked the coolant temp. and it gave 133 degrees Celcius in which case the engine would be toast but the reliable temp. guage only said normal reading of 91.....
Post 667856 by bongodave on 2013-12-10 13:22:48
[QUOTE=960kg;667843]If you are not EXACT with the profile you input to the app you can get very wide readings eg: the weight of the car....don`t forget to add your own weight!! I had a reading of 313bhp and that was with only a remap and standard 16T and exhaust....not correct... i have a good engine but not that good! I checked the coolant temp. and it gave 133 degrees Celcius in which case the engine would be toast but the reliable temp. guage only said normal reading of 91.....[/QUOTE] As with many of these things, sounds more like a gimicky toy than a useful tool. Ta for heads-up.
Post 667858 by M-R-P on 2013-12-10 13:25:36
Yep - I have the torque app. Although it's brilliant for live data logging and fault finding etc, the torque and Bhp meter is total balls, regardless of how long you spend setting it all up.
Post 667873 by V70 Graham on 2013-12-10 15:18:07
[QUOTE=V70 Graham;667699]I'll help you mate..... 1. Press and hold odometer reset button 2. Turn ignition switch to pos 2 3. After SRL flashes, release odometer reset button 4. Confirm by turning your Volvo off, then on again Doesn't do 1998 models though, my light came on tonight too......and the Draper tool is now discontinued ![/QUOTE] After trying this method a couple of times, my 'service' light has been reset :D
Post 667875 by jamesy12345 on 2013-12-10 15:22:24
[QUOTE=V70 Graham;667873]After trying this method a couple of times, my 'service' light has been reset :D[/QUOTE] good to know, cheers, will try it on mine also! edit: curses! foiled again... after ogling your garage, I see u have ME7, I have 4.4
Post 667921 by Kingsford G on 2013-12-10 16:47:56
Its a key procedure on pre me7
Post 668073 by deathrider311271 on 2013-12-10 20:11:41
[QUOTE=V70 Graham;667873]After trying this method a couple of times, my 'service' light has been reset :D[/QUOTE] lol i was going too say you need to do it twice same as you do on the ME7 cars
Post 668088 by V70 Graham on 2013-12-10 20:35:07
[QUOTE=deathrider311271;668073]lol i was going too say you need to do it twice same as you do on the ME7 cars[/QUOTE] Mine is ME7 lol
Post 668096 by stribo on 2013-12-10 20:45:51
[QUOTE=Kingsford G;667921]Its a key procedure on pre me7[/QUOTE] Please share, as that's news to me.
Post 668099 by deathrider311271 on 2013-12-10 20:50:07
[QUOTE=stribo;668096]Please share, as that's news to me.[/QUOTE] you do Grahams sequence twice thats it, i did my S70 last week which is 4.4
Post 668118 by Kingsford G on 2013-12-10 21:18:28
[QUOTE=stribo;668096]Please share, as that's news to me.[/QUOTE] Put the key into the ignition and turn it to position "I." Press the trip odometer button in and hold it. Turn the ignition key to position "II Wait about 5 seconds until the service engine light begins to blink. After the 4th blink, turn the ignition key back to position "I." Release the button and start the engine. The light should have turned off. If not, repeat steps 1 through 4 again.
Post 675745 by jamesy12345 on 2013-12-30 17:12:10
[QUOTE=Kingsford G;668118]Put the key into the ignition and turn it to position "I." Press the trip odometer button in and hold it. Turn the ignition key to position "II Wait about 5 seconds until the service engine light begins to blink. After the 4th blink, turn the ignition key back to position "I." Release the button and start the engine. The light should have turned off. If not, repeat steps 1 through 4 again.[/QUOTE] Doesn't work for me :( I'm going to try VOL-FCR
Post 675762 by T5frankie on 2013-12-30 18:05:17
[QUOTE=jamesy12345;675745]Doesn't work for me :( I'm going to try VOL-FCR[/QUOTE] think that only works on me7 cars
Post 675789 by stribo on 2013-12-30 18:59:49
[QUOTE=T5frankie;675762]think that only works on me7 cars[/QUOTE] That's what I said, but was told different, haven't tried it yet though.
