Boost leak testing
Post 664977 by Squirtydog on 2013-11-30 22:23:08
Any advice? Apart from not spraying all the electrics is this far off the mark? [video=youtube_share;T963989F3c0]http://youtu.be/T963989F3c0[/video]
Post 664979 by foammanmark on 2013-11-30 22:28:37
When my R went to GRN, it was smoke tested prior to the map being fitted.
Post 664980 by JamesT5 on 2013-11-30 22:29:31
How's the, 'ahem', Astra van....... ;)
Post 664983 by T5frankie on 2013-11-30 22:41:12
[QUOTE=foammanmark;664979]When my R went to GRN, it was smoke tested prior to the map being fitted.[/QUOTE] the map isn't fitted another ecu is slot in lol, 2 seconds
Post 664987 by stribo on 2013-11-30 22:47:20
[QUOTE=T5frankie;664983]the map isn't fitted another ecu is slot in lol, 2 seconds[/QUOTE] So the remapped ECU is fitted. :P
Post 664990 by Squirtydog on 2013-11-30 23:06:38
[QUOTE=JamesT5;664980]How's the, 'ahem', Astra van....... ;)[/QUOTE] Wondering if I have a leak. Hiss audible on boost. Turbo whistle possibly more audible. Worth a check either way before considering a map. ...the 'Astra van' is fine otherwise thanks. "Daddy's green machine" as the little man calls it.
Post 664993 by Squirtydog on 2013-11-30 23:22:28
[QUOTE=foammanmark;664979]When my R went to GRN, it was smoke tested prior to the map being fitted.[/QUOTE] Enlighten me... Smoke testing
