anyone had any experience with ebay turbo's?
Post 663709 by wiganer31 on 2013-11-25 18:37:08
as above really but dont shoot me just yet, im having trouble finding a 19t for my 940. Someone asked me if i i had considered ebay turbos and i straight away said no not a chance there ££££ etc. but then got to thinking have they improved over the years? and if not any they do fail after a while could i rebuild it with genuine parts? i know i could modify a actuator but thats about all im sure off, i know ebay turbos were a no go at one point but these days on a 940 running 250hp ish? not saying im thinking of useing a ebay turbo but just looking at all the info first before i even think about it. something like this:http://www.ebay.co.uk/itm/VOLVO-850-2-3-T5-R-1996-1997-TD04HL-TURBO-CHARGER-New-Express-Delivery-/400613953447?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Car+Make%3AVolvo&hash=item5d4673cfa7 cheers
Post 663713 by BoostWagon on 2013-11-25 18:43:42
Ebay turbo's is a draw of luck. Some are fine and will last a while, others are ££££, blow up and maybe even damage more then that. Also fitment/overall quality can be lacking behind. I would opt Volvo brand parts (or other "big brands"), but that's my opinion
Post 663714 by claymore on 2013-11-25 18:43:43
I use a Chinese Ebay turbo, as does Adam in the Volvaxo :)
Post 663728 by stribo on 2013-11-25 19:16:26
It says it's for a 850, but has an angled exhaust flange, so you'd have to change your downpipe.
Post 663788 by artfulflounder on 2013-11-25 21:27:52
you could always buy a genuine 15g/16t and fit a 19t compressor housing and wheel....even with a refurb kit its still cheaper and you know exactly what you've got. for example.....http://www.ebay.co.uk/itm/Upgrade-Turbo-Compressor-Housing-Wheel-VOLVO-S70-850-TD04-19T-/121098504671?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item1c320889df Should be o.k for the power your looking for.
Post 663792 by p fandango on 2013-11-25 21:32:03
[QUOTE=artfulflounder;663788]you could always buy a genuine 15g/16t and fit a 19t compressor housing and wheel....even with a refurb kit its still cheaper and you know exactly what you've got. for example.....http://www.ebay.co.uk/itm/Upgrade-Turbo-Compressor-Housing-Wheel-VOLVO-S70-850-TD04-19T-/121098504671?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item1c320889df Should be o.k for the power your looking for.[/QUOTE] the centre cartridge of the turbo will need machining to accept the 58mm wheel
Post 663857 by wiganer31 on 2013-11-26 02:09:08
[QUOTE=BoostWagon;663713]Ebay turbo's is a draw of luck. Some are fine and will last a while, others are ££££, blow up and maybe even damage more then that. Also fitment/overall quality can be lacking behind. I would opt Volvo brand parts (or other "big brands"), but that's my opinion[/QUOTE] appreciate your opinion mate, i think the same really, never considered ebay turbos before until i spoke to someone with a sierra cosworth with one on. [QUOTE=claymore;663714]I use a Chinese Ebay turbo, as does Adam in the Volvaxo :)[/QUOTE] ahh cool what size turbo you useing? [QUOTE=stribo;663728]It says it's for a 850, but has an angled exhaust flange, so you'd have to change your downpipe.[/QUOTE] cheers mate, i plan on running a 3" down pipe anyways so not to much trouble cheers
Post 663858 by wiganer31 on 2013-11-26 02:14:01
[QUOTE=artfulflounder;663788]you could always buy a genuine 15g/16t and fit a 19t compressor housing and wheel....even with a refurb kit its still cheaper and you know exactly what you've got. for example.....http://www.ebay.co.uk/itm/Upgrade-Turbo-Compressor-Housing-Wheel-VOLVO-S70-850-TD04-19T-/121098504671?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item1c320889df Should be o.k for the power your looking for.[/QUOTE] this was going to be my next question because you can also do it to the 13g i think? and i do have a spare standard turbo so need to look at the codes. [QUOTE=p fandango;663792]the centre cartridge of the turbo will need machining to accept the 58mm wheel[/QUOTE] im waiting to hear back from a place about the cost of machining cheers guys
Post 663866 by claymore on 2013-11-26 08:16:39
[QUOTE=wiganer31;663857] ahh cool what size turbo you useing? [/QUOTE] I'm using a GT3076
Post 664158 by wiganer31 on 2013-11-27 02:37:48
[QUOTE=claymore;663866]I'm using a GT3076[/QUOTE] sweet, need to get mine sorted
Post 664425 by redbaron on 2013-11-28 10:36:00
Go for a 16t and stick a 19t wheels and housing until you get all the supporting work done, then move up to the gt30. I think the young people call it 'hellaboost' nowadays
Post 665000 by wiganer31 on 2013-12-01 02:18:44
[QUOTE=redbaron;664425]Go for a 16t and stick a 19t wheels and housing until you get all the supporting work done, then move up to the gt30. I think the young people call it 'hellaboost' nowadays[/QUOTE] i could go for some of this hellaboost :eclipsee_
Post 665905 by wiganer31 on 2013-12-04 02:01:21
anyone know what turbo i could use instead of a td04 that works out about the same as a 19t? still not found a turbo so was wondering if i could use something like a t3 or something? also what dose the 3" maf come off? i hear its a 960 maybe? cheers
Post 665916 by Mongo on 2013-12-04 07:09:53
Ive got a 19t that came off of mine before i rebuilt it all pm me if your intrested mate
Post 666065 by wiganer31 on 2013-12-04 19:15:51
[QUOTE=Mongo;665916]Ive got a 19t that came off of mine before i rebuilt it all pm me if your intrested mate[/QUOTE] pmed mate cheers
Post 668828 by wiganer31 on 2013-12-13 01:59:35
been offered a cheap 16t and white injectors off a v70r that i know are in good condition, would the white injectors be ok to run 13 ish psi on my 940 with the 16t and 3"maf?
Post 668834 by smithy on 2013-12-13 05:17:32
[QUOTE=wiganer31;668828]been offered a cheap 16t and white injectors off a v70r that i know are in good condition, would the white injectors be ok to run 13 ish psi on my 940 with the 16t and 3"maf?[/QUOTE] Yes as long as you use a 4 bar fpr then you could run 18 psi on that turbo .but get the car on the dyno to check afrs before and set the boost till you start to run lean then back it off
Post 669039 by wiganer31 on 2013-12-13 19:42:45
[QUOTE=smithy;668834]Yes as long as you use a 4 bar fpr then you could run 18 psi on that turbo .but get the car on the dyno to check afrs before and set the boost till you start to run lean then back it off[/QUOTE] sweet cheers mr ££££h, so use the 3" maf and 4 bar fpr and i should be sorted? what bar is the v70r fpr? if the one off the v70r will be ok i think i can get that to cheers guys
Post 669040 by claymore on 2013-12-13 19:46:00
V70r will be 3bar
Post 669041 by wiganer31 on 2013-12-13 19:48:55
[QUOTE=claymore;669040]V70r will be 3bar[/QUOTE] ahh damm cheers mate
Post 669800 by wiganer31 on 2013-12-15 19:21:34
hopefully going picking up a good condition 16t tomorrow :) its a good price to but its a job lot of parts that was built for a project so will have some selling of bits to do, it dose come with a m90 box and i have a spare b230fk sat here and a sierra saff? just looking into the exhaust now, want a 3" down pipe into a 2.5" system, but im not sure if im going to make my own or get one made? im no fabricator but i did make my own 2.5" exhaust on my 360 turbo but that was pretty simple but im not as confident looking at the 940, has anyone on here made there own? would like to see pics and here peoples opinions. cheers
Post 669811 by T5frankie on 2013-12-15 19:40:26
[QUOTE=wiganer31;669800]hopefully going picking up a good condition 16t tomorrow :) its a good price to but its a job lot of parts that was built for a project so will have some selling of bits to do, it dose come with a m90 box and i have a spare b230fk sat here and a sierra saff? just looking into the exhaust now, want a 3" down pipe into a 2.5" system, but im not sure if im going to make my own or get one made? im no fabricator but i did make my own 2.5" exhaust on my 360 turbo but that was pretty simple but im not as confident looking at the 940, has anyone on here made there own? would like to see pics and here peoples opinions. cheers[/QUOTE] graeme "the steel" welch makes his own
Post 669818 by graemewelch on 2013-12-15 19:55:44
[QUOTE=wiganer31;669800]hopefully going picking up a good condition 16t tomorrow :) its a good price to but its a job lot of parts that was built for a project so will have some selling of bits to do, it dose come with a m90 box and i have a spare b230fk sat here and a sierra saff? just looking into the exhaust now, want a 3" down pipe into a 2.5" system, but im not sure if im going to make my own or get one made? im no fabricator but i did make my own 2.5" exhaust on my 360 turbo but that was pretty simple but im not as confident looking at the 940, has anyone on here made there own? would like to see pics and here peoples opinions. cheers[/QUOTE] i can bore you with some pics. i build everything including the silencers.
Post 669821 by wiganer31 on 2013-12-15 20:01:21
[QUOTE=graemewelch;669818]i can bore you with some pics. i build everything including the silencers.[/QUOTE] feel free mate, be good to see how its done
Post 669827 by graemewelch on 2013-12-15 20:07:59
[QUOTE=wiganer31;669821]feel free mate, be good to see how its done[/QUOTE] Image Image Image Image Image Image Image Image
Post 669832 by graemewelch on 2013-12-15 20:11:59
Post 670421 by wiganer31 on 2013-12-17 02:43:54
cheers mate, that looks amazing! top work, wish i couldfab/weld like that, if you lived in wigan i would be pestering you for help lol cheers
Post 670476 by wiganer31 on 2013-12-17 15:18:01
forgot to say that yesterday i picked up a 16t with a set of white injectors, adjustable fuel reg and a 3" down pipe for a 850 t5 that i will mod to use on my 940
Post 671319 by wiganer31 on 2013-12-19 14:40:25
my rad has decided to let go :( just when the bills are due! weres the cheapest place to get one from? cheers
Post 671324 by smithy on 2013-12-19 15:17:07
[QUOTE=wiganer31;671319]my rad has decided to let go :( just when the bills are due! weres the cheapest place to get one from? cheers[/QUOTE] Look on voc peeps are breaking them or euro car parts or better parts for Volvo speak to Jamey
Post 671541 by wiganer31 on 2013-12-20 01:17:32
[QUOTE=smithy;671324]Look on voc peeps are breaking them or euro car parts or better parts for Volvo speak to Jamey[/QUOTE] cheers i will ring volvo parts tomorrow, this the correct place? http://www.partsforvolvosonline.com/default.php?cPath=608_611 i did try euro but there prices are strange, rang them and got one price, on there website got another and then i found them on ebay with a different price, think ive found one now for 85 quid posted, don,t seem a bad price
Post 671563 by artfulflounder on 2013-12-20 08:15:18
Theres different rads for the 940.....the autos had an oil cooler for tranny in one of the end tanks and manual didn't. Probably why different prices.
Post 671640 by wiganer31 on 2013-12-20 15:11:44
inno mate, the prices i mean were all for the same rad according to the part numbers lol, could be that they have listed them wrong hence the different prices, last time i ordered form them they sent me the wrong part lol
Post 674694 by wiganer31 on 2013-12-27 21:28:50
got a rad on order now but it will only be here in the new year :( whats peoples opinions about upgrading the inter cooler? is it needed? i hear the standard cooler can take 300hp? or is it worth upgradeing anyway to keep the inlet temps down, also what spark plugs should i go for, the ones that i put in it dont seem to like the extra heat with cheers
Post 675119 by barkster1971 on 2013-12-28 19:57:48
36 x 12 x :funkybana3 in mine.
Post 676563 by wiganer31 on 2014-01-01 22:09:26
[QUOTE=barkster1971;675119]36 x 12 x :funkybana3 in mine.[/QUOTE] im might be being a massive idiot here but i am really slow but not sure what you mean by 36 x 12 x :funkybana3, lol. still waiting for my rad :( cheers
Post 676568 by graemewelch on 2014-01-01 22:19:30
[QUOTE=wiganer31;670421]cheers mate, that looks amazing! top work, wish i couldfab/weld like that, if you lived in wigan i would be pestering you for help lol cheers[/QUOTE] always welcome to come and visit me
Post 676592 by artfulflounder on 2014-01-01 23:10:18
[QUOTE=wiganer31;676563] but not sure what you mean by 36 x 12 x :funkybana3, lol. cheers[/QUOTE] That'll be 36 inch long, 12 inch high and 3 inch deep.
Post 677943 by wiganer31 on 2014-01-06 01:42:02
i get the size but im not sure what the :funkybana was meant to be, obviously a mistake but didn't know if he meant to type something else instead lol. managed to get a rad guys, fitted it with my mate and started to fill it with water and i whent inside to get some more water, leaving my mate to start filling it up, came back and he was looking abit sheepish, then tells me he leaned over while putting the water in and leaned on the rad and snapped the over flow pipe ffs lol
Post 678052 by wiganer31 on 2014-01-06 17:49:38
[QUOTE=graemewelch;676568]always welcome to come and visit me[/QUOTE] sorry i missed your post at first, cheers for the offer, were exactly is chester le street? how long do you think it would take? already have the bit of downpipe that comes out the back of the turbo and into a 90 bend but thats about it apart from maybe a few various bends left over from when i built a exhaust for my 360 t cheers
