Ricky the variomatic
Post 661153 by classicswede on 2013-11-16 19:50:27
I had been looking for another 340 for a while but had some criteria that had to be met. 1.4 5 doors prefer no sunroof, not white or red solid body cheap. Then came along Ricky that fitted all of the above but was a Vario! I do like Autos but was looking to build a nice fast road car again so manual would have been preferred. Swapping transmission would not have been to big a job so I had some thinking to do. This how Ricky arrived after my dad had a nice long 960mile day trip picking up a 1.7 for Bogbasic and then collecting Ricky. Image Image Bonnet earth strap broken as usual Image Body needs a very good clean Image Rear wheel arch needs treating before it gets any worse Image As does the door below the mirror Image Front wing is a bit flakey but can be saved Image
Post 661155 by claymore on 2013-11-16 19:53:20
I like, looks in very good nick
Post 661158 by stribo on 2013-11-16 19:56:21
Different, so what have you got planned?
Post 661162 by classicswede on 2013-11-16 19:59:21
For £200 it was hard to go wrong. There are some minor rust issues that need to be addressed. I had to replace the washer jet and refit an earth wire for the head lights to secure the MOT. The clutch was way off adjustment and with the limited shims I had I managed to adjust to just above the top clearance limit. I need to get some more shims to reduce the clearance down to where it needs to be. The belts were very slack and took a lot of adjustment to get enough tension. The diaphrams in the primary transmission have perished and need replacing, at the moment it is running with the vacuum system not functioning. I have a complete spare primary unit ready to fit, just a case of doing it.
Post 661165 by classicswede on 2013-11-16 20:02:11
The other week doing some "local" sight seeing Image On the way to Scotland last week Image and outside Sweetheart Abbey Image I've put a few thousand miles on the clock in the past month or so.
Post 661168 by classicswede on 2013-11-16 20:03:45
One of things that had been bugging me about Ricky is the soggy front springs that had gone very soft to the point that hit any little bump and its on the bumpstops. This is a very common problem on the 300 series and the can drop anything upto 4 inches from original height! The best option was to start rebuilding a replacement set of struts (thanks madseb) The spring cups were in a bad way and the bearing were totally past it and worn through Image Image Image As I have changed to a bearing top mount that I had knocking about the cups were welded up and a thick washer welded in to strengthen them up. Image Image There was also a fair bit of grot around the lower spring cup that had to be cleaned out and some welding to build it back up. While I was at it I decided to brace up the struts. Image Image Image The bracing pieces were trimmed down for tyre clearance and everything given a goog coat of underseal. It might not look pretty but I am only interested in stopping things from rusting not winning a BKV Image Image Image I will get some pictures showing Ricky sitting back at the correct ride height. next job to complete the strut rebuild will be the brake upgrade and that is why the calipers were not done at the same time.
Post 661172 by V70 Graham on 2013-11-16 20:07:40
Nice project thread, different to what we normally get.
Post 661177 by classicswede on 2013-11-16 20:10:21
Future plans are to deal with all the rust issues and sort the transmission out properly. I would like to sort out gearing it up a little as 5000 RPM to do 72MPH is a bit of a joke. My thoughts are to graft a overdrive from a 740 turbo gearbox into the drive line to give a motorway high gear. It will be built for road driving and looking close to original. I like to modify but will try and keep Ricky as close to standard look as I can deal with.
Post 661286 by AndysR on 2013-11-16 22:14:35
Nice little project, will be checking back to see your updates :) 5,000 @ 70 though!! :shockedbi
Post 661335 by Biff on 2013-11-16 23:15:00
A local lad had one of these that was really tatty. He put a Clio Williams engine in, relatively straight forward & 150bhp. Tramp drifting as he put it. Lol My dad used to have a 340. He loved it.
Post 661524 by classicswede on 2013-11-17 19:08:35
My previous 340 was a 1.7 but I swapped to a 2ltr 460 engine. That car is what all me 300 series suspension stuff was built on and everything had to be custom made. The only think you could buy off the shelf was some soggy 40mm lowering springs. The 300 is a very popular drift car
