Post 659039 by claymore on 2013-11-09 20:54:54
I need to source a brake caliper with a handbrake mechanism that will bolt onto the front hubs of a Volvo 850, any thoughts, I think the later s40 uses a handbrake but I wonder if there is any chance it will fit onto the 850?
Post 659040 by Kingsford G on 2013-11-09 20:56:22
££££roen C5`s have them too.
Post 659042 by claymore on 2013-11-09 21:01:12
there are plenty of calipers out there with handbrake leaver, but I want to keep it as simple as possible.
Post 659044 by Nealevo on 2013-11-09 21:04:29
I have some brembo S type R rears at work! Any use?
Post 659045 by graemewelch on 2013-11-09 21:09:20
[QUOTE=Nealevo;659044]I have some brembo S type R rears at work! Any use?[/QUOTE]
they dont have a hand brake mech but on another note are they for sale if they are no use to claymore
Post 659046 by 850 T5s on 2013-11-09 21:09:39
iam sure the old saab 99/900s had the handbrake on the front calipers
Post 659047 by graemewelch on 2013-11-09 21:10:53
[QUOTE=claymore;659039]I need to source a brake caliper with a handbrake mechanism that will bolt onto the front hubs of a Volvo 850, any thoughts, I think the later s40 uses a handbrake but I wonder if there is any chance it will fit onto the 850?[/QUOTE]
ive got a c5. i can check the mounting on those if you want. will get sizes and pics to see if its up to the job
Post 659049 by T5RatherAmusin on 2013-11-09 21:13:07
you also need brakes that will actually stop the car too :rotfl:
if your gonna be using ££££run rear calipers up front thats gonna be one ££££e setup colin...
Post 659051 by graemewelch on 2013-11-09 21:16:05
[QUOTE=T5RatherAmusin;659049]you also need brakes that will actually stop the car too :rotfl:
if your gonna be using ££££run rear calipers up front thats gonna be one ££££e setup colin...[/QUOTE]
i suspect theres going to be a twin caliper set up.
Post 659052 by Nealevo on 2013-11-09 21:16:48
he's putting an engine in the boot so it will need a handbrake mech on the front/rear set.
Post 659053 by claymore on 2013-11-09 21:18:58
Need the hand brake mate, cheers for the offer
[QUOTE=graemewelch;659047]ive got a c5. i can check the mounting on those if you want. will get sizes and pics to see if its up to the job[/QUOTE]
That would be great if you could mate :)
The brakes will still be on the back of the car, just attached to front hubs.
Post 659054 by T5RatherAmusin on 2013-11-09 21:20:28
[QUOTE=Nealevo;659052]he's putting an engine in the boot so it will need a handbrake mech on the front/rear set.[/QUOTE]
i know that but was thinking say its soley that caliper up front stopping 2 300 odd hp engines.....
Post 659055 by claymore on 2013-11-09 21:22:56
[QUOTE=T5RatherAmusin;659054]i know that but was thinking say its soley that caliper up front stopping 2 300 odd hp engines.....[/QUOTE]
it won't be on the front, and you don't need fantastic brakes on the back, the front has Aston Martin 4 pots.
Post 659056 by T5RatherAmusin on 2013-11-09 21:23:14
im with ya now, your pretty much putting a whole 850 front end frame in the rear
Post 659057 by claymore on 2013-11-09 21:24:58
[QUOTE=T5RatherAmusin;659056]im with ya now, your pretty much putting a whole 850 front end frame in the rear[/QUOTE]
Yes :), and I will be very very disappointed if I've only got 300bhp per engine :)
Post 659059 by T5RatherAmusin on 2013-11-09 21:33:11
mk2 focus should be an easy and cheap option then me thinks ;)
Post 659103 by T5frankie on 2013-11-10 09:04:34
i think you'll find citroen brakes to be some of the best as they work off that green slime suspension
Post 659106 by hybriduno on 2013-11-10 09:12:33
citroen brakes may be an issue as I believe they require hydrolastic oil rather than the usual dot 4.
Post 659109 by claymore on 2013-11-10 09:25:52
[QUOTE=Harvey;659107]How's about one of theses.
http://www.ebay.com/itm/BLUE-HYDRAULIC-VERTICAL-DRIFT-RALLY-RACING-HANDBRAKE-E-BRAKE-LEVER-KIT-W-GRIP-A-/321195449776[/QUOTE]
Can't use hydraulic for the MOT, it has to have a cable.
Post 659125 by Harvey on 2013-11-10 10:36:27
[QUOTE=claymore;659109]Can't use hydraulic for the MOT, it has to have a cable.[/QUOTE]
I see
Post 660255 by claymore on 2013-11-13 08:04:49
How does the handbrake work on a v70r awd?
Post 660262 by MoleT-5R on 2013-11-13 08:28:51
Apparently this is no longer so with the new changes, as it came up in conversation with a local mechanic the other day whilst working out ideas for the MGB GT5-R
[QUOTE=claymore;660255]How does the handbrake work on a v70r awd?[/QUOTE]
same as the rest, badly....lol. seriously it's on the rear, drum within the disc
Post 660268 by claymore on 2013-11-13 08:43:54
wilwood make an electric operated handbrake caliper for kitcars, so if kitcars don't need a cable then it must be true for normal road cars as well.
Post 660278 by stribo on 2013-11-13 10:16:20
Alot of production cars have electric hand brakes now, so a cable isn't mandatory. My understanding is you can have a hydraulic hand brake, but it has to be a separate circuit, I could be wrong though.
Post 660288 by Harvey on 2013-11-13 10:52:43
[QUOTE=MoleT5-R;660262]Apparently this is no longer so with the new changes, as it came up in conversation with a local mechanic the other day whilst working out ideas for the MGB GT5-R
same as the rest, badly....lol. seriously it's on the rear, drum within the disc[/QUOTE]
Pair of AWD rear hubs then any idear of drive shaft size re splines are they the same as the fronts (that would be to easy )
Post 660340 by claymore on 2013-11-13 16:09:31
I was thinking along the same lines
Post 660344 by Harvey on 2013-11-13 16:31:00
[QUOTE=claymore;660340]I was thinking along the same lines[/QUOTE]
I do know on the phase 2 cars the rear shafts are half the dia of the fronts I guess as max power is 150 bhp on paper that can go through them.
But what size is inside the hub.
Post 660346 by MoleT-5R on 2013-11-13 16:34:03
well, there is one here that you can have a look at if you want to gather any info from it mate
