Quick Hello
Post 658645 by mikealder on 2013-11-07 18:53:14
Just quick hello and a little history from my Volvo ownership years, been driving them for over 16 years, 740, 740 Turbo and more recently a phase one V70, the V70 isn't going to win any prizes in the speed category firstly it has the 140BHP Non Turbo engine coupled to the five speed automatic box. The car was built in March 2000 so must be one of the last phase ones, decent optional extras fitted from new but I have added to the car in the four and half years I have owned it. I will let the pictures do the talking from here on in: When I first got it Image Front end with projectors fitted Image Rear Lights, although the rear reflectors in these failed the MoT earlier this year due to fading so I have had to fit some extra red reflectors to the rear of the car Image Thor 17" Alloys, bargain of the year, £72 for e-bay for all four including tyres, cost me more in fuel to go and pick them up! Image AND Image Optima Red Top Battery adapter leads, Volvo leads don't fit the Optima due to the terminal posts being too far from the edge of the battery, simple little work around: Image TopCat Splitter fitted Image Multi chip LEDs for the rear lights, 112 LEDs per "bulb" Image In the dark the reverse lights are similar to headlights on the rear of the car Image I got a little bored in the evenings last year so decided to use the dremel to add a bit of "bling" for the engine Image Engine bay with it fitted Image In went a set of 850R leather/ Alcantara seats, wooden auto selector and wooden steering wheel Image Freeview TV receiver and iO-Play_2 bluetooth kit installed Image High brightness LED set for the DIM from IPD Image Most recent addition to the car is the rear spoiler with integral high level brake light which is quite a rare part on the phase one V70 Image Some of the low points with this car, the electronic throttle motor packed up and needed repairing, the engine blew up at 155K having put quite some time and money in to the car I located a low(ish) mileage N/A engine out of an S80 and had that fitted, £500 fitted, it now does over 42MPG on a decent run if you stick around 60MPH - Mike
Post 658646 by Harvey on 2013-11-07 19:01:46
Hi and welcome ,Very nice looking car you got there. So what do you charge to do inlet manifolds then ?.
Post 658647 by stribo on 2013-11-07 19:07:48
Welcome to the forum Mike, given some of your other posts, you seem to have a lot of Volvo knowledge.
Post 658648 by Craigtange on 2013-11-07 19:10:41
Hi there, welcome to the forum. Nice car.
Post 658651 by WOODY T5 on 2013-11-07 19:26:07
hello welcome to vpc some nice bits and bobs done there looks great keep up the good work
Post 658653 by Jamest5r on 2013-11-07 19:51:11
Welcome, so come on tell how come you know so much about the auto electrics always needed around here :)
Post 658656 by T5frankie on 2013-11-07 20:03:11
Post 658657 by M-R-P on 2013-11-07 20:07:03
welcome aboard, it's nice to see someone putting some love into a non turbo. good work.
Post 658658 by mikealder on 2013-11-07 20:07:29
[QUOTE=Harvey;658646]So what do you charge to do inlet manifolds then ?.[/QUOTE] It took about 80 hours in total, five hours per week when the MIL comes around, great way of escape....... The picture with the manifold off the car was only about half finished when that picture was taken, first step is to grit blast a secondhand manifold then use a flap wheel in the angle grinder to remove the casting flashings, after that comes hours of work with various grades of wet-n-dry before metal polish, look far better than the standard light grey oxidised lump you normally see attached to the front of the engine when you pop the bonnet but it is a heck of a lot of work. [QUOTE=Jamest5r;658653]Welcome, so come on tell how come you know so much about the auto electrics always needed around here :)[/QUOTE] The wiring diagrams I am used to working with are for products capable of Mach 2 so car electrics are something that kind of comes naturally, having been in the same industry for 32 years and 23 of those have been in the field of electrical design. I am more than happy to help out with electrical questions or if people want explanations as to how a circuit works, troubleshoot electrical "gremlins" or work around failures that can be costly to fix using replacement OEM parts - Mike
Post 658675 by JUDGENINJA on 2013-11-07 20:35:15
[QUOTE=mikealder;658658]It took about 80 hours in total, five hours per week when the MIL comes around, great way of escape....... The picture with the manifold off the car was only about half finished when that picture was taken, first step is to grit blast a secondhand manifold then use a flap wheel in the angle grinder to remove the casting flashings, after that comes hours of work with various grades of wet-n-dry before metal polish, look far better than the standard light grey oxidised lump you normally see attached to the front of the engine when you pop the bonnet but it is a heck of a lot of work. [/QUOTE] I know how you feel... Took mine on my 850 quite a few days at work during breaks just to prepare for powder coating.. And I used a grinder to take off the cast mark. Image
Post 658698 by V70 Graham on 2013-11-07 21:12:49
Welcome to the club, nice looking car there.....all except that steering wheel ! It's horrid.....when you see the light and decide to get rid of it let me know how much you want for it lol :redface:
Post 658701 by stribo on 2013-11-07 21:15:27
[QUOTE=V70 Graham;658698]Welcome to the club, nice looking car there.....all except that steering wheel ! It's horrid.....when you see the light and decide to get rid of it let me know how much you want for it lol :redface:[/QUOTE] You've already had one, and didn't like it, are you getting so old your memory's going?
Post 658705 by V70 Graham on 2013-11-07 21:19:57
[QUOTE=stribo;658701]You've already had one, and didn't like it, are you getting so old your memory's going?[/QUOTE] The one I had was the 'thinner' one, I didn't even know they did 2 sorts.
Post 658706 by andyb1375 on 2013-11-07 21:28:15
Post 658711 by jdavis on 2013-11-07 21:41:01
welcome to Vpcuk Nice looking car, not very often you see much love given to the n/a v70's. Looks great for it. What difference did the Dash bulbs make?
Post 658714 by mikealder on 2013-11-07 21:46:47
[QUOTE=jdavis;658711]What difference did the Dash bulbs make?[/QUOTE] In daylight with the dash lit it is obvious it is lit unlike the stock illumination, in the dark I tend to dim it down as it is a little too bright! The Dash lights on the car are illuminated all the time irrespective of the position of the master headlight switch which has also been altered to only give side lights at position "0" that go off when you take the key out, this saves burning the HIDs out during the day, I still have the option for headlights in the day by turning the switch to the 12 o'clock position - MIke
Post 658721 by Biff on 2013-11-07 22:14:13
Nice v70. I quite like the Thor wheels on a ph1. You've certainly spent plenty of man hours on the car & it shows. Cracking example & nice choice of mods especially the spoiler & led bulbs. I could do with some reverse lights like that myself! Lol I saw pics of the car on volvo tuning & asked about it. Welcome to vpcuk. :)
Post 658744 by iancho on 2013-11-08 06:11:13
Hi Mike and a VERY warm welcome to VPC, it's great to have you on board at last as your knowledge and skills are much needed in our club! Many thanks from me mate for all your help and advice over the years... You are a very unselfish and helpful chap! :) Ian Stunning Car Mike you have added some great mods! :B_thumb:
Post 658747 by abdul on 2013-11-08 06:17:50
Post 658785 by Santa on 2013-11-08 08:33:22
Post 658802 by abdul on 2013-11-08 11:51:42
where did u get the leds
Post 658808 by mikealder on 2013-11-08 13:10:32
The ones fitted to the rear lights are from e-bay although they are longer than standard bulbs so probably won't fit OEM rear lights, the dash lighting LEDs came from IPD in the USA - Mike
Post 658895 by stephenevans99 on 2013-11-08 20:58:33
Welcome to VPC Mike.....here's a few more pics from the recent Botany Bay meet: Image Image
Post 658927 by iancho on 2013-11-08 23:27:56
[QUOTE=stephenevans99;658895]Welcome to VPC Mike.....here's a few more pics from the recent Botany Bay meet: Image Image[/QUOTE] Cheers for those Steve.... That car really is in a class of it's own, love the wheels and for the price you paid, well it just makes them that much sweeter! :)
Post 658939 by abdul on 2013-11-09 00:56:18
[QUOTE=mikealder;658808]The ones fitted to the rear lights are from e-bay although they are longer than standard bulbs so probably won't fit OEM rear lights, the dash lighting LEDs came from IPD in the USA - Mike[/QUOTE] Any link
Post 658958 by Jim S70R on 2013-11-09 09:30:51
Welcome to the club
Post 658963 by mikealder on 2013-11-09 09:51:02
[COLOR="#0000FF"]Here[/COLOR] for the dash LEDs [COLOR="#0000FF"]Here[/COLOR] For the tail/ stop LEDs, they don't seem to have the others listed theses days but if you ask them for white and yellow versions I am sure they will have them - Mike
Post 659077 by V70 Graham on 2013-11-09 23:44:46
Quite liking the look of those dash bulbs, no drilling or any other use of power tools.....might give it a bash, what could possibly go wrong lol
