Want to fit 5x110 wheels onn an 850
Post 657017 by charlie-r on 2013-10-30 12:53:20
Struggling to find wobble bolts or adapters! Anyone know anywhere that does wobble bolts in m12x1.75 or does 5x108 to 5x110 adapters? Cheers, Charlie.
Post 657037 by partsforvolvos.com on 2013-10-30 13:51:06
have a look at the h&r listing they do loads of spacers. most of these are always special order so you have to be sure before ordering. http://www.h-r.com/gb/f_sportfedersaetze.php
Post 657084 by p fandango on 2013-10-30 17:15:50
U should get them on, sure claymore had 5x112's on before
Post 657130 by thunderace on 2013-10-30 19:01:10
try [FONT=Arial][SIZE=2][SIZE=4][COLOR=#002cfd][B][FONT=Arial, Helvetica, sans-serif][SIZE=2][SIZE=5][COLOR=#00429a][SIZE=3][SIZE=3][SIZE=3][CENTER][SIZE=5][COLOR=#002cfd]NUTS & BOLTS UK[/COLOR][/SIZE][SIZE=5][COLOR=#002cfd]01274 524 666[/COLOR][/SIZE][/CENTER][/SIZE][/SIZE][/SIZE][/COLOR][/SIZE][/SIZE][/FONT][/COLOR][/SIZE][/SIZE][/FONT][/B]
Post 657137 by claymore on 2013-10-30 19:13:33
I've been using 5 x 110 for 3 years with standard bolts, as long as you use spigot rings to make sure you have a good fit on the hub, you'll be fine.
Post 657205 by charlie-r on 2013-10-30 23:17:12
Can get adapters from america but depends on what they're gonna charge as import tax when they get to the border, will try that number, and when I get the wheels might offer one up on standard bolts and see how it looks, suppose it's only gonna be 1mm out per bolt but still not 100% sold on that idea
Post 657214 by Biff on 2013-10-30 23:44:13
[QUOTE=charlie-r;657205]Can get adapters from america but depends on what they're gonna charge as import tax when they get to the border, will try that number, and when I get the wheels might offer one up on standard bolts and see how it looks, suppose it's only gonna be 1mm out per bolt but still not 100% sold on that idea[/QUOTE] I wouldn't worry too much so long as they're tight. So long as you get the right spigots & tighten them up correctly they will be no difference.
Post 657238 by claymore on 2013-10-31 07:18:47
If 110's can stand the abuse I give them, I don't think you've got anything to worry about, you won't be able to use adapters unless you cut your wings and put wheel arches on.
Post 658443 by charlie-r on 2013-11-06 20:16:29
Just trial fitted the 110's and they don't like going on the 108 hubs, could drill them out mm so they bolts go through easier buy would rather get adapters/spacers and wobble bolts or custom wobble bolts on to fit them.
Post 658445 by claymore on 2013-11-06 20:22:30
I've never had success with wobbly bolts, tried them a few times in the past and wheels always used to work loose, if your problem is the bolt heads to close to the side of the hole, use tuner bolts, that's what I use. Image
Post 658447 by charlie-r on 2013-11-06 20:28:59
Nah its not that, I put the wheel up and the bolt holes are hidden slightly too much to fit the bolt in square unless I drilled the wheels out. Just looks a bit sketchy in general.
Post 658449 by claymore on 2013-11-06 20:32:51
well there's no way that they're 110's then, they are less than 1mm difference, are you sure they're not 112's
Post 658457 by charlie-r on 2013-11-06 20:57:46
Well I was thinking that myself but they're definitely stamped 110 on the back but they do overlap more than 1mm. Will measure the gap between the bolt holes and see.
