Post 632205 by dionbullock on 2013-08-03 17:42:10
Hello all!
Came back to the car the other day and noticed a small amount of liquid under my car. Not power steering fluid, not coolant and deffo not oil.
A mechanic mate suggested it could be the ac weeping excess water???
is this true???
Post 632206 by stephenevans99 on 2013-08-03 17:46:16
The ac will have a drain from the evaporator located behind the dash, on a hot day you will often see a puddle of water under the front of the car - perfectly normal.
Post 632208 by jamesy12345 on 2013-08-03 17:47:41
if you'd only left the car for a short time could be just condensate, if you used the AC just before parking up I wouldn't worry about it
Post 632232 by PHIL V70R on 2013-08-03 18:51:45
i weep when being spank if thats any good mate....:shhh:
Post 632260 by jamesy12345 on 2013-08-03 20:14:14
[QUOTE=PHIL V70R;632232]i weep when being spank if thats any good mate....:shhh:[/QUOTE]
bring out the gimp, he likes a spank
Post 632282 by volvokid on 2013-08-03 21:16:25
As said it will be condensation, its not a leak coming from the inside.
Post 632305 by PHIL V70R on 2013-08-03 22:20:26
[QUOTE=jamesy12345;632260]bring out the gimp, he likes a spank[/QUOTE]
you no me so well lol
Post 637564 by Cam on 2013-08-21 22:24:28
When it's working the a/c removes moisture from the air which is why it clears the screen quicker , so when it's working the water that collects in the heater box empties out a drain tube normally on the drivers side just behind the engine bay perfectly normal
Post 637676 by partsforvolvos.com on 2013-08-22 13:42:36
if you dont get any water under your car, its more a problem because those drain pipes get blocked or become detatched and then fill up the footwells. it can be some time before you see it because the carpet is soo thick , so anybody who doesnt have water ......... check yours!!
we used to get a few of those at one time in the p2's ............
