Post 632158 by graemewelch on 2013-08-03 12:43:14
im mega bored so so going to pull my finger out with a little project ive had lying around for months now. not sure how well itll work. im waiting on the turbo flange being lasered then i can jig it up and start cutting pipes. its no use to me i just thought it would be a good idea to build one when i was full of beer. so here it is
hopfully the next pics will be it tacked up ready for welding. need to get a y split for my regulator so can set up a purge when i weld it
Post 632174 by M-R-P on 2013-08-03 13:44:13
Interesting... What sort of y are you after? I may be able to help.
Post 632176 by graemewelch on 2013-08-03 13:52:48
whats the Y for ?
do you mean the bit thats going to connect the turbo flange to the pipe work
Post 632177 by M-R-P on 2013-08-03 14:05:07
For the regulator mate. I run the stores for a big fabrication firm. I have contacts :)
Post 632178 by graemewelch on 2013-08-03 14:08:45
[QUOTE=M-R-P;632177]For the regulator mate. I run the stores for a big fabrication firm. I have contacts :)[/QUOTE]
or now ive got you. im a million miles away. its to go on the gas outlet on the regulator. ive no idea of thread size, im just guessing are standard size. ill try and find out. been a storeman you might know the best place to buy these 1.5" tee's and elbows. i got a mate to get these for me, so up to now its cost me nothing cause got the profiled flange for nothing to
Post 632658 by graemewelch on 2013-08-05 16:54:31
picked this up today. just need to get a another flange like this. then i can build jig. im bidding on one at the minute. the tapped one i have is only 8mm would prefer 12 or 15mm but its only a prototype so im not worried
