Hello everyone!!!
Post 631130 by Couper on 2013-07-31 10:36:34
Hi, My name is Couper, I have just bought a 1997 manual 940 2.3 LPT Estate and need some tuning advice (see my other posts) Our family had 10 Volvos years ago (240,340,740 and 940) but moved onto other cars since. However my parents have both bought auto 940 LPT's in the last 6 months. So I decided to join the party!! (go all retro!?) I am looking to get the same power as my Fiat Coupe's +/- 300 bhp. The plan is to have both front and rear wheel drive QUICK turbo cars. I think a Volvo estate and Coupe ,when tuned, would provide the best real world 2 car garage for practicality, style, performance and driving fun!!!! All advice welcome as to the best and cheapest way to get to 250-300bhp out of my red block I am particularly confused by the wideband AFM / MMR / WIDEBAND LAMBDA - What is it/them? Do I need it/them? and Where do I get them from? At the moment I have money burning a hole in my pocket and want to order everything I need today so I can get my friend to help me fit them this weekend if possible? Thank you
Post 631132 by M-R-P on 2013-07-31 10:57:48
Welcome aboard :) The redblock is a tough motor and doesn't take too much to hit the kind of power you're looking for.I would imagine the wideband stuff would be a good idea if you're planning on running a lot of boost as the average AFM probably wouldn't cope with increased airflow. Plenty of brains to pick here.
Post 631136 by V70 Graham on 2013-07-31 11:26:20
Welcome to the club, looks like an interesting project you have there.
Post 631140 by stribo on 2013-07-31 11:30:36
Hi, welcome to the forum. Smithy knows a bit about 940s, at least how to take them apart.;)
Post 631141 by T5frankie on 2013-07-31 11:33:38
Post 631142 by Biff on 2013-07-31 11:37:58
Welcome. As said smithys your man. His is slightly modified & a bit faster than standard.
Post 631149 by jamesy12345 on 2013-07-31 12:32:12
Hi, AFM is air flow meter? What is MMR.... measles, mumps and rubella?
Post 631150 by WOODY T5 on 2013-07-31 12:39:37
hello and welcome
Post 631151 by T5RatherAmusin on 2013-07-31 12:41:42
he on bout afr- air fuel ratio.... whap it into a o2 bung port tell you your afr- running rich/lean
Post 631152 by jamesy12345 on 2013-07-31 12:48:59
[QUOTE=T5RatherAmusin;631151]he on bout afr- air fuel ratio.... whap it into a o2 bung port tell you your afr- running rich/lean[/QUOTE] thanks, I see that but MMR was a new one. Musa Motors Riga I have it now by jove
Post 631154 by T5RatherAmusin on 2013-07-31 13:05:06
think its a multiple mode resonator. running off 2 02 ports. not realllllly worth setting one up if you have a good custom tuner.... are you thinking, bigger turbo from a later t5 as such?
Post 631163 by Couper on 2013-07-31 14:20:17
Im thinking bigger turbo at a second stage. Dunno what's best. If 850 etc turbos are plentiful cheap and big enough Im more than happy with one :) How much will I need for an 850 turbo?
Post 631168 by T5RatherAmusin on 2013-07-31 14:43:03
hows about this? http://www.ebay.co.uk/itm/Volvo-T5-Turbo-Charger-V70-XC70-V70XC-S60-T5-B5234T3-Petrol-/161060846600?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item257ff97c08 and one of these http://www.ebay.co.uk/itm/2007-VOLVO-V70-2-4-T5-EXHAUST-MANIFOLD-30637921-FREE-P-P-/271222805291?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Car+Make%3AVolvo&hash=item3f2623932b same as used on an s60r. many upgrade to em,....
Post 631186 by smithy on 2013-07-31 15:58:01
[QUOTE=T5RatherAmusin;631154]think its a multiple mode resonator. running off 2 02 ports. not realllllly worth setting one up if you have a good custom tuner.... are you thinking, bigger turbo from a later t5 as such?[/QUOTE] Are you after 300 whp or crank a massive difference
Post 631194 by smithy on 2013-07-31 16:31:21
The reason why ask this because then the turbo choice and maf size and injectors etc etc
Post 631206 by Couper on 2013-07-31 18:03:57
My original thought was 300 at the fly. However 300 at the wheels sounds better. If there is a massive costs difference then I would settle for 300 at the fly. Which is the sweet spot in terms of cost/performance?
Post 631214 by smithy on 2013-07-31 18:20:04
The clutch won't give anything over 250whp mate .19t you will be pushing it hard to get over 300 bhp but a 20g will do it easy if you want to keep with mitsi turbo. Garrett I would go t34 cossie turbo witch is straight bolt on but custom lines .and the downpipe will need doing too but if going turbo change then a 3in exhaust would be good . Then the fuel side Vxr 470 cc injectors with 3 in maf and piping and change the pump if you want to run over 290 bhp .put A or V cam in it if you want high end power but the t cam can keep the torque up very well till it runs out of puff at 5 k rpm .i got over 292 bhp with stock t cam but if I would of changed the cam then that is worth 15 bhp or so .7.5 ton intercooler fits so does rs500 but both need custom piping .if you want fun for now then you could put mbc on turn turbo up to 13/14 psi and then get rid of back box on car and put straight pipe on.also do the air box mod or put a cone on it that little lot will get you over 200 bhp and a very quick motor too .
Post 631233 by Couper on 2013-07-31 19:36:22
Will the mitsubish 19T and 20G bolt right up to the exhaust until I was able to get a 3" system? Why do you prefer the T34? Would you recommend an electronic boost controller? Thank you
Post 631236 by Nealevo on 2013-07-31 19:42:54
Welcome along
Post 631242 by theflyingbrick on 2013-07-31 20:13:01
welcome along :)
Post 631250 by hybriduno on 2013-07-31 20:27:51
welcome along! where abouts in cambs are you? as im only in lincs :) like to try and meet a few peeps from here soon!
Post 631289 by Jamest5r on 2013-07-31 20:56:43
Welcome, Yeah Smithy is the bloke to talk to..........expect at least 8 calls a day :)
Post 631350 by no1tosh on 2013-07-31 21:56:28
welcome pal, ive just had a dig around in my mag rack in the bathroom and found this. Get yourself a back issue of PPC magazine April 2008, issue 48. it has a 7 page tuning guide for 700 and 900 seires volvo's. It does tell you all of the common mods, and bits you can do. Its really good. hope this helps
Post 631357 by AndysR on 2013-07-31 22:09:44
Welcome to the fold, sounds like you've had a good car based upbringing... Lol
Post 631363 by andyb1375 on 2013-07-31 22:16:12
Welcome..
Post 631391 by jamesy12345 on 2013-08-01 04:04:49
[QUOTE=smithy;631214]The clutch will give anything over 250whp mate .19t you will be pushing it hard to get over 300 bhp but a 20g will do it easy if you want to keep with mitsi turbo. Garrett I would go t34 cossie turbo witch is straight bolt on but custom lines .and the downpipe will need doing too but if going turbo change then a 3in exhaust would be good . Then the fuel side Vxr 470 cc injectors with 3 in maf and piping and change the pump if you want to run over 290 bhp .put A or V cam in it if you want high end power but the t cam can keep the torque up very well till it runs out of puff at 5 k rpm .i got over 292 bhp with stock t cam but if I would of changed the cam then that is worth 15 bhp or so .7.5 ton intercooler fits so does rs500 but both need custom piping .if you want fun for now then you could put mbc on turn turbo up to 13/14 psi and then get rid of back box on car and put straight pipe on.also do the air box mod or put a cone on it that little lot will get you over 200 bhp and a very quick motor too .[/QUOTE] Smithy, what engine management do you have on the 940? Is it LH Jetronic, if so 2.2 or 2.4...? Cheers
Post 631393 by abdul on 2013-08-01 05:55:47
Welcome to the forum
Post 631407 by smithy on 2013-08-01 08:39:13
[QUOTE=jamesy12345;631391]Smithy, what engine management do you have on the 940? Is it LH Jetronic, if so 2.2 or 2.4...? Cheers[/QUOTE] All later 940 turbos use l.h.2.4 mate .you can run chips from USA or Sweden or you can do other things like run bigger mafs etc .you have to get the goldbox ezk unit to run ignition chips though if you have the later black ezk unit .the is also ostrich too witch lets you map the car .ive been running stock ecus for years though but I'm going standalone next .
Post 631409 by smithy on 2013-08-01 08:50:39
[QUOTE=Couper;631233]Will the mitsubish 19T and 20G bolt right up to the exhaust until I was able to get a 3" system? Why do you prefer the T34? Would you recommend an electronic boost controller? Thank you[/QUOTE] Both the mitsi turbos will need downpipe flange mods same as garrett .the t3/t34/t38 work very well will this engine same as a t28 will too .make sure it has a t3 stamp too .all the mitsi turbos will need clocking for rwd fitment too .
Post 631410 by smithy on 2013-08-01 08:56:02
[QUOTE=Couper;631233]Will the mitsubish 19T and 20G bolt right up to the exhaust until I was able to get a 3" system? Why do you prefer the T34? Would you recommend an electronic boost controller? Thank you[/QUOTE] Both the mitsi turbos will need downpipe flange mods same as garrett .the t3/t34/t38 work very well will this engine same as a t28 will too .make sure it has a t3 stamp too .all the mitsi turbos will need clocking for rwd fitment too .also don't forget the mighty holsets something like a hx35 will give you anything from 300 to 450bhp .
Post 631421 by jamesy12345 on 2013-08-01 09:48:29
[QUOTE=smithy;631407]All later 940 turbos use l.h.2.4 mate .you can run chips from USA or Sweden or you can do other things like run bigger mafs etc .you have to get the goldbox ezk unit to run ignition chips though if you have the later black ezk unit .the is also ostrich too witch lets you map the car .ive been running stock ecus for years though but I'm going standalone next .[/QUOTE] cheers. I am looking at what to do next with the 460. It has LH2.2 and an EZK black box. Fuel mapping is standard so thought I might have a go at that......standalone very nice but well above my budget :)
Post 631539 by smithy on 2013-08-01 16:27:43
[QUOTE=jamesy12345;631421]cheers. I am looking at what to do next with the 460. It has LH2.2 and an EZK black box. Fuel mapping is standard so thought I might have a go at that......standalone very nice but well above my budget :)[/QUOTE] I'm sure you can get chips for them need to check the net mate .i know someone who had a Renault 21 turbo that was modded I'm sure it uses the same system but might be wrong .bbr used to do chips or you can get a piggy back chip for them
Post 631572 by jamesy12345 on 2013-08-01 19:29:29
[QUOTE=smithy;631539]I'm sure you can get chips for them need to check the net mate .i know someone who had a Renault 21 turbo that was modded I'm sure it uses the same system but might be wrong .bbr used to do chips or you can get a piggy back chip for them[/QUOTE] Thanks will have a look. I fancy doing something myself with the mapping as it is pretty much there or thereabouts, not much more to be had out of the engine unless I start changing parts. If I do anything worth reading will make a thread about it.......
